Old 02-15-2012, 03:24 PM   #1
VinnieisSouth
Member#: 192214
02 2002 WRX
Angry Car cut off while driving now won't start
I was on the freeway and it died out, figured it was dead battery or something, checked battery and alternator and both were good. A fried suggested fuel pump, so I changed tat and it still won't crank over. When I try cranking it it does nothing, so i had a friend jump it and it starts to turn but won't catch. A friend is saying bad starter but that would cause my car to cut
Out while driving would it? I also have been driving on a blown turbo for a good 500+ miles but finally found a new one so thatll go in today, so any suggestion on what it could be?
VinnieisSouth is offline   Reply With Quote
Old 02-15-2012, 03:27 PM   #2
VinnieisSouth
Member#: 192214
02 2002 WRX
I also heard like a clunk then it cut out, but
I'm not entirely sure it was internal, i could have coincidently ran over something.
Old 02-15-2012, 05:39 PM   #3
hardball75006
Member#: 214319
2009 Legacy 2.5 NA
Diamond Grey Metallic
Are you sure your battery is good? I had a problem with a brand new battery. Anytime I hit a bump in the road my engine and everything electrical would shut off for a split second and come back on again. It turned out to be a short between 2 battery cells. I replaced the battery and that fixed the problem.
hardball75006 is offline   Reply With Quote
Old 02-15-2012, 05:43 PM   #4
Robert Harik
Member#: 308034
Did your timing belt brake?
Robert Harik is offline   Reply With Quote
Old 02-17-2012, 02:32 PM   #5
VinnieisSouth
Member#: 192214
02 2002 WRX
Pulled spark plugs today and they had a bit of oil on the tips of them, they all seemed fried. Would it be possible since I was driving on a blown turbo for so long that oil got inside there with the "air" if my timing belt broke would my crank but not catch? At this point I can't even get any sounds or any form of engine trying to start unless I'm being jumped, but then it quickly dies out. My battery should be good, everything works, radio, air, lights, etc etc.
Old 02-17-2012, 02:42 PM   #6
VinnieisSouth
Member#: 192214
02 2002 WRX
I should check that........
Old 02-17-2012, 04:36 PM   #7
VinnieisSouth
Member#: 192214
02 2002 WRX
Checked it's fine.
Old 02-17-2012, 06:03 PM   #8
hardball75006
Member#: 214319
2009 Legacy 2.5 NA
If your battery is good, I don't understand why you are having to jump start it.
When you jump start it you say it quickly dies out. Does it die out before or after you remove the jumper cables?
The reason I ask is if the car dies after removing the jumper cables then your battery might not have enough power to run the electronics to keep the engine running.
Even if you had fouled spark plugs it still doesn't explain why you need a jump to turn your engine over. Also I would think you would have noticed performance problems over a period of time before the engine would shut down due to fouled plugs.
I know you said you checked both, but from what you are describing it still sounds like either alternator or battery.
Old 02-18-2012, 09:42 AM   #9
VinnieisSouth
Member#: 192214
02 2002 WRX
If it was my battery wouldn't it be able to start if it was jumped? My bad let me correct my terminology, it won't even try starting without being plugged to another car, just gives me that "dead batter feel" minus being able to use all the inside electronics. I'm thinking it might be a cam sensor or crank sensor, I'll replace both whenever they get here.
Old 02-18-2012, 09:44 AM   #10
VinnieisSouth
Member#: 192214
02 2002 WRX
My car is about to break 200k miles, if that helps at all :/
Old 02-18-2012, 03:38 PM   #11
VinnieisSouth
Member#: 192214
02 2002 WRX
Battery was bad, replaced it and still wouldn't start, then realized, "oh my tmic isn't attached oh wait and it's turboless, I probably might need some pressure in there to get this thing to crank over" thanks for your help and Hardball you were right.
Old 02-18-2012, 04:08 PM   #12
hardball75006
Member#: 214319
2009 Legacy 2.5 NA
Glad to hear you got it fixed. I did not mean to be so persistant about the battery, but my car was doing almost the same thing.
Old 02-19-2012, 10:43 AM   #13
VinnieisSouth
Member#: 192214
02 2002 WRX
You're the reason I had it replaced since it was only two months ago since it was, but hey it worked in happy now invites finish my swap. I have one more question, my car shouldn't start currently correct? Turbo, tmic downpipe removed.
Old 02-19-2012, 02:22 PM   #14
hardball75006
Member#: 214319
2009 Legacy 2.5 NA
I can't answer that question because I don't have a turbo.
Hopefully someone that does will answer that one.
Old 02-20-2012, 09:01 PM   #15
VinnieisSouth
Member#: 192214
02 2002 WRX
Battery changed starter good alternator good rveything good, it still won't start seems like it's not getting enough power to kick the starter on. Cranksensor
Is good can't imagine what it could be...
Old 02-21-2012, 09:25 AM   #16
masterforce
Member#: 221580
2011 WRX STI
Satin White Pearl
you said you change the spark plugs? are the gapped correctly? also have you tried a push start?
masterforce is offline   Reply With Quote
Old 02-21-2012, 08:43 PM   #17
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
vinnie...ya need a real mechanic
Car shut off while driving... Please Help Tz000 Factory 2.0L Turbo Powertrain 22 01-24-2012 01:17 PM
HELP!!! my Car SHUT OFF while driving Wesly Newbies & FAQs 10 08-17-2007 01:54 PM
car shuts off while driving reeksti Service & Maintenance 5 03-07-2006 10:40 AM
Car shuts off while driving (post for a friend) BlueTDimly Normally Aspirated Powertrain 4 12-30-2002 11:25 AM
car shuts off while driving.... sethiscope Service & Maintenance 3 03-11-2002 02:36 PM
Message Board Statistics All times are GMT -4. The time now is 10:52 AM.
