Old 02-15-2012, 05:24 PM   #1
JBPSTI04
Member#: 273343
2004 Wrx STi
Java black pearl
Default 2004 sti data logs
hey guys, i have a 2004 sti that i did some logging in this morning, and i wanted to get some feedback on them. any help is appreciated.
2004 sti, cobb stage 2 93 octane, cobb short ram intake, invidia catless bellmouth downpipe, stock midpipe, genome axleback.
35 degree outside temp, elevation...somewhere in flat ohio
JBPSTI04 is offline   Reply With Quote
Old 02-16-2012, 01:19 PM   #2
Cobb Tuning
Member#: 4803
You are on the high end of the target boost range (17.5 psi +/- 1 psi) and there is some Feedback Knock Correction at higher RPM. Is the filter clean? How old are the spark plugs? I would recommend using the 91 octane LWG map and taking a few more logs.
Ian
Old 02-16-2012, 01:46 PM   #3
JBPSTI04
Member#: 273343
2004 Wrx STi
Java black pearl
Thanks Ian,
My car only has 25k on it, so plugs are stock. I Dis a 3rd gear pull and experiences no knock at all, then switched to 91 and did 1 4th pull with similar knock to the 93 map, and did 2 3rd gear pulls with only knock feedback on acceleration and spool, which from what I understand is normal.
After some more reading of threads with similar problems to mine, I have since switched to the 91 ACN map, but have not logged with it yet, since the car needs to get used to it.
Old 02-16-2012, 02:03 PM   #4
JBPSTI04
Member#: 273343
2004 Wrx STi
Java black pearl
Also, the filter is a cobb short ram, and its brand new since December. Is it possible the high boost levels are causing the problem?
I'm not able to easily post logs online (a friend posted the above ones for me)
Is there am email is be able to more easily send you logs on?
Old 02-17-2012, 11:29 AM   #5
Cobb Tuning
Member#: 4803
Yeah! You can email them to me directly: [email protected]
Please be sure to include information about your car, and we'll figure it out from there!
Ian
Old 02-17-2012, 11:46 AM   #6
JBPSTI04
Member#: 273343
2004 Wrx STi
Java black pearl
Thanks again! I loaded the LWG 91 map on my car last night, so I might not get a chance to log for a couple days (I work weekends), but I'll mail you some with car info as soon as I get a chance.
FS : CA: 2004 WRB 2004 STI 53K miles mnavarro Private Vehicle 'For Sale' Classifieds 17 03-06-2012 01:13 AM
05 STi Data Log GromsKillA AccessPort 4 02-13-2012 11:02 PM
2004 WRX vf39+ mods swap data log - advice appreciated! tittykaka7 AccessPort 7 12-15-2010 10:01 PM
Data logging gurus, need your help reading log. vortectoy AccessPort 5 05-22-2006 01:19 AM
05 Sti Data Log, What Does It Mean? RIRENTER Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 05-20-2006 12:24 AM
