Old 02-15-2012, 07:00 PM   #1
roccrew585
Member#: 91840
Default Royal Purple XPR vs Motul Gear 300v
I have a 04 Sti with fully built engine using methonal injection, and currently using Royal Purple Racing Motor Oil 10W40 XPR. But I hear rumor from people, saying RP kills your gasket and seal. Is this statement is true? Has anyone use this oil? any issue? It runs great in my car right now. should I change it to Mutol gear 300v?
roccrew585 is offline   Reply With Quote
Old 02-15-2012, 10:00 PM   #2
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
Motul Gear300 is for the transmission. 300V is for the engine.
RP doesn't kill seals. Poachers kill seals.
Run whatever synthetic you'd like, there are a ton of good choices out there, and the XPR line from RP is fairly stout.
JamesWilson2 is offline   Reply With Quote
Old 02-16-2012, 07:07 AM   #3
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
Old 02-16-2012, 05:16 PM   #4
roccrew585
Member#: 91840
Thanks for the advice, I'll stick with RP XPR since I just change the oil recently.
Old 02-27-2012, 09:00 PM   #5
roccrew585
Member#: 91840
has anyone else tried using RP XPR?
Old 03-16-2012, 02:18 PM   #6
Jermaine2011wrx
Member#: 280095
i use it in my 11 wrx no problems with it, temp is a little lower actually
Jermaine2011wrx is offline   Reply With Quote
Royal Purple VS Motul Engine Oil TheEugeneKam Service & Maintenance 5 12-11-2011 12:19 AM
FS: Royal Purple Max Gear Synthetic Gear Oil - 75w90 (5) slowguy VIC Private Classifieds 2 09-02-2008 02:01 AM
Royal Purple Max Gear?? JoeBloggz23 Transmission (AT/MT) & Driveline 15 05-07-2003 10:45 PM
Can I use Royal Purple 75w90 Max Gear in the rear diff? Robmat Transmission (AT/MT) & Driveline 8 08-06-2002 06:44 PM
Can Royal Purple Max Gear be used in the rear diff? Robmat Service & Maintenance 1 07-03-2002 11:20 PM
