Old 02-15-2012, 09:42 PM   #1
outlaw2252
Member#: 264670
2002 Subaru WRX Wago
Default 02 wrx stage1+sf data logs
Hey all, I just got an AccessPort and flashed to the Stage1 93 Map. The car has been running pretty good so far. I just logged a 3rd gear pull and was hoping to get some feedback. Pretty new to the whole tuning scene and I want to make sure there is nothing weird going on. Appreciate any input!
Relevant Mods:
Invidia Catless up-pipe
Cobb SF Intake
TurboXS Type-H Bov (i know...it was on the car when i bought it)
AccessPort Stage 1 93 map.
https://docs.google.com/spreadsheet/...k1zeHRHb195Q2c
outlaw2252 is offline   Reply With Quote
Old 02-16-2012, 01:30 PM   #2
Cobb Tuning
Member#: 4803
There is some very consistent Fine Knock Learning correction and the DAM is at 11 when it should be learning up to 16. How many miles are on the car? Have you checked for air intake tract leaks? How many miles are on the spark plugs?
With the older Suabrus, its very important to make sure the car is in good mechanical shape and that the maintenance is up to date. After you have done that, I would also suggest downloading the v310 maps from our website and Reflashing your car. Also, here is a video we have made to help teach some simple things to look for in logs.
Ian
Old 02-16-2012, 03:48 PM   #3
outlaw2252
Member#: 264670
The car has 176,000 miles on it. I recently had it smoke tested and it checked out fine. The spark plugs could probably use changing and im planning on doing that today. I also need to clean the IACV because my idle has started to wonder so to speak. Got the gasket just waiting on a nice day.
Car is not throwing any codes or anything like that, doesn't burn ANY oil, haven't done a compression test yet but i plan on it very soon.
I saw the fine knock learning which is why i decided to log a pull and post it.
Old 02-16-2012, 11:31 PM   #4
outlaw2252
Member#: 264670
So i logged another 3rd gear pull and i ended up with a pretty clean run. Im not sure what to think... DAM is at 16 with no knock logged at all. What could cause these two logs to be that much different?
I am running the V.310 map as well.
New log
https://docs.google.com/spreadsheet/...XF1eFdnbm95eVE
Old 02-17-2012, 11:37 AM   #5
Cobb Tuning
Member#: 4803
The A/F Learning 1 values seem to be a bit high. How recently has the filter been cleaned? Is the MAF sensor the original MAF sensor?
Ian
Old 02-17-2012, 11:54 AM   #6
outlaw2252
Member#: 264670
Yeah I was looking at that and decided to log just a normal drive mostly out of boost. For most of the time i am in the 14% correction range which i take to mean that the computer is having to add more fuel indicating i am running lean.
Filter is new.
When i bought the car the dealer (not subaru) told me that they had just put a new MAF sensor in. If thats true or not i have no idea, if it was replaced i can probably say that its not an OEM maf sensor.
I was looking into scaling my MAF sensor and have a pretty good scaling spreadsheet that was recommended on another forum. However i don't want to start messing with that until I change the plugs and the 02 sensor. Overall tune-up.
2012 WRX Stage 1+SF Data Logs KitKatJim AccessPort 14 02-22-2012 10:45 AM
2004 sti data logs JBPSTI04 AccessPort 5 02-17-2012 11:46 AM
2011 wrx stage 1 data log mixnmike2005 Newbies & FAQs 7 02-09-2012 10:52 PM
DATA LOG 93+sf HWG 2011 wrx .. please LOOK giroyac Engine Management & Tuning 2 01-15-2012 09:11 AM
04 WRX breaking up. Data log included darksc00by Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 03-13-2009 08:01 PM
