Old 02-16-2012, 12:09 AM   #1
KootenayWRX
Member#: 119134
04 Fxt
02 wrxwgn
Default Can I leave the access port plugged in?
Will the world end if I leave the access port plugged in ( screen is on)?
Dont want to unplug it daily as the connectors may wear.
thx.
KootenayWRX is offline   Reply With Quote
Old 02-16-2012, 12:30 AM   #2
WrXtaCy2003
Member#: 85036
2013 PBP sti ltd
05 LGT 35r 30psi..busted
It'll burn an image into the screen, and decrease it's lifetime(theoretically), but sure.
DK
WrXtaCy2003 is offline   Reply With Quote
Old 02-16-2012, 02:08 PM   #3
Cobb Tuning
Member#: 4803
The OBDII port always has power, so leaving the AccessPORT plugged in can lead to screen burn-in. Other people have done it though, and the world hasn't ended...yet.
Ian
Old 02-16-2012, 04:43 PM   #4
KootenayWRX
Member#: 119134
04 Fxt
02 wrxwgn
Ian
Thanks, I will unplug (large plug) it when the car is not in use for anytime over a day. That should keep the world tuning!
The Cobb access port is a great tool, I wish I had one for my human body.
Thanks.
Old 02-16-2012, 06:06 PM   #5
Dartholomew
Member#: 208771
2009 WRX
The Tactrix doesn't even have a screen, but it has no power management features so you could drain the battery if you leave it plugged in for several days without driving the car around. Sounds like it's the same situation for the AP?
Dartholomew is offline   Reply With Quote
Old 02-16-2012, 06:31 PM   #6
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Hey COBB, you know my ScanGauge shuts off after about 10 seconds when I turn the key to the off position and automatically starts up when I turn the key to the on position... How about making the AP able to do that...? And oh yea how about an 90*elbow for the OBD2 plug end so that I and others don't pull or push the plug around with our legs snagging the wire while driving or when getting in and out of the car...?
wrxdrvr is offline   Reply With Quote
Old 02-16-2012, 07:21 PM   #7
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Or you could not be lazy and unplug when you get out and plug in after you get in... It takes two seconds!
2Fast4U1DAY is offline   Reply With Quote
Old 02-16-2012, 07:24 PM   #8
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Yes. The thing here is that the OBD port is hot at ALL times. Therefore anything that's plugged in (unless it has a shutoff feature, or something of the sort) is going to be a parasitic draw on the battery.
Old 02-16-2012, 07:27 PM   #9
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
thx.
I've been unplugging and plugging in my AP daily for over 18months. No loose connections, and fits like a glove. It actually takes a good little amount of force to unplug it. I wouldn't be too concerned about it IMO.
Old 02-16-2012, 08:02 PM   #10
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Yes, I "could" do that... Oh, wait a minute... I DO, do that. I'm thinking FEATURES that can make the AP BETTER. JMO You know, improving the product, adding features people are asking for...
Old 02-16-2012, 08:13 PM   #11
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Touche. I would rather have them revamp the 06+ wrx maps first (like they just did for the 02-05 maps) before they start R&D on improving/adding to the functionality of the AP. Maybe keep that in mind for the AP V3 (if they end up making another version)
Edit: you can probably get a pinout from Cobb on the wiring, and put the power wire on a toggle switch, so no more plugging/unplugging of the dongle, and you don't kill your battery or burn your screen from prolonged "use".
Old 02-16-2012, 09:38 PM   #12
Dartholomew
Member#: 208771
2009 WRX
Another option - Tactrix actually sells an ODB extension cable that has the desired 90 degree elbow.
Old 02-16-2012, 10:04 PM   #13
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
I'm not concerned with it, however other people may be.
Old 02-16-2012, 10:16 PM   #14
olive4ce
Member#: 296479
2011 WRX
Grey
This is a bit off topic... Does the AP have to be plugged in every time you drive the car? I just purchased one for my 2011 WRX (still waiting on shipping).
olive4ce is offline   Reply With Quote
Old 02-16-2012, 10:23 PM   #15
hutch959
Member#: 267463
a power switch on the ap would be a nice feature... just sayin.
hutch959 is offline   Reply With Quote
Old 02-16-2012, 10:23 PM   #16
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
No it doesn't need to be plugged in ever, once you flash a base map... Until you want to change maps or datalog, check codes or use the AP as a gauge, (boost gauge for example)...
Old 11-26-2012, 07:49 PM   #17
RallySoob
Member#: 74872
2006 STi
White/Black
Why not make an aftermarket cable with on/off switch sum1? How hard would it be to wire one into existing cable? I just got a cobb ap and i want mount it on pillar like a boost gauge, then tuck all wires and put toggle switch in one empty switch ports on left side of steering column
RallySoob is offline   Reply With Quote
Old 11-26-2012, 08:02 PM   #18
RallySoob
Member#: 74872
2006 STi
White/Black
For now i unhooked the cars female obd port from the underside of colum so it floats, then i run wire thru hole i drilled in my ashtray and use a iphone mount that plus in 12v socket like so
Old 11-27-2012, 04:11 AM   #19
RallySoob
Member#: 74872
2006 STi
White/Black
Now i got it up top like i wanted
Old 11-29-2012, 12:58 AM   #20
7CATALYST
Member#: 221770
WRBLUE
AMEN BROTHER!!! ITS ONLY BEEN ABOUT 10 YEARS WORTH OF R&D
7CATALYST is offline   Reply With Quote
How far can the access port go twigg08wrx AccessPort 6 07-28-2008 12:54 AM
For Sale: 04 STI Access Port and 05 STI Access Port NEW in Box $569 Shpped 4 Each!!! mrtrex Engine/Power/Exhaust 10 09-18-2006 08:43 AM
Can I leave the boost controller install in the car when install Cobb AP? smootth Engine Management & Tuning 7 03-12-2005 09:37 AM
Can I leave the serial cable plugged in my UTEC all the time? Davenow Engine Management & Tuning 6 02-25-2003 04:43 PM
Where can I buy the NGK platinum plug in Bay area? kendo Bay Area Impreza Club Forum -- BAIC 6 09-28-2002 12:35 AM
