Alaskan Impreza Club
Old 02-16-2012, 02:06 AM   #1
Quasimodo_ak
Member#: 310012
Default 16.7 psi boost??
SHould I be worried if I'm only stage 1 and have hit 16.7 psi?
Quasimodo_ak is offline   Reply With Quote
Old 02-16-2012, 02:25 AM   #2
Carter
Member#: 156708
2004 Mini Cooper S
Invader 125 Shifter Kart
We're gonna need a little more to go on than that...
Carter is offline   Reply With Quote
Old 02-16-2012, 02:44 AM   #3
Quasimodo_ak
Member#: 310012
All I have is a Cobb cai and an AP. Sorry I'm still new didn't know more info was needed. My bad...
Old 02-16-2012, 12:49 PM   #4
edo2000
Member#: 68709
2012 WRX
red
You have no mods other than the CAI? No exhaust? You are running a Cobb stage 1 map? Does Cobb recommend/allow this with their S1 map? How are you measuring your boost, with the AP or an analog gauge? How does the manifold pressure act, does it build smoothly to 16.7 psi and hold, or does it bounce around? Are there any other symptoms that might indicate the ECU isn't happy( power fluctuations, etc).
These are some of the things I would look at.
16.7 does seem high for stage 1.
edo2000 is offline   Reply With Quote
Old 02-17-2012, 02:57 PM   #5
P3Auto
Member#: 241881
2014 P3 Import Auto
AWD Dyno, Mods, etc
Take a look at DAM/IAM and let us know what that number is.
If your feeling really adventurous log feed back knock correction, rpm, and calculated load during a 2nd gear pull or 3rd gear if you can find a safe spot. Start at 2800rpm and take it to 5500 or so.
Odds are you are fine but to fix the problem try going to cobbs site and downloading the LWG stage 1 tune. If that doesn't bring the boost down then you need to investigate more.
P3Auto is offline   Reply With Quote
02 wrx - only putting out 7 psi boost While At Rome Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 39 12-06-2014 10:14 PM
Only 7 psi/boost Fluctuation SiAwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 06-08-2011 06:12 PM
My car is also pushing 7 psi boost Jerembo47 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 06-15-2010 08:22 AM
just went stage 2, 16.7 PSI in 3rd gear! SketchINoc Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-23-2005 02:29 PM
Only 7 PSI boost with STi Tanman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 12-03-2004 11:26 AM
