Welcome to the North American Subaru Impreza Owners Club Sunday August 2, 2015
Old 02-16-2012, 04:47 PM   #1
RACER3251
Member#: 284685
2015 Subaru WRX
Dark Grey
Question How To Clean DIRTY Wheels????
hey guys, just as the title implies. I picked up a set of BBS wheels that I don't think have ever been cleaned and as a result are filthy and coated with miles upon miles of brake dust, hardened road tar and various other bits of hard stuff.
Before I installed I did a quicky clean job with s100 cleaner and a scrub brush via a power washer. that got 80% of the crap off but there is still quite a bit of hardened blacked crud on my wheels.
Does anyone have any tips, tricks or even any insight on miracle cleaners that will help get s my wheels back to looking like new again??????
I am even tempted to buy some paint and just paint over the crud lol
Thanks in advance!
RACER3251 is offline   Reply With Quote
Old 02-18-2012, 12:30 AM   #2
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Spray nine works wonders
wrxlaunch is offline   Reply With Quote
Old 02-19-2012, 04:18 AM   #3
Wolfbane23
Member#: 277101
ArmorAll Extreme Wheel and Tire Works wonders for rims. All you have to do is spray it on then wipe it off
Wolfbane23 is offline   Reply With Quote
Old 02-19-2012, 06:08 AM   #4
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Platinum Silver Metallic
Try a little more concentrated APC, scrub, wash & rinse.
You can also use clay and then some rubbing compound.
EdHilario is offline   Reply With Quote
Old 02-19-2012, 10:17 AM   #5
The Duke
Member#: 264877
Might look into proper use of Acid cleaners. They may be the only thing aggressive enough to do the job without mullions of coats, repeats, etc.
The Duke is offline   Reply With Quote
Old 02-19-2012, 02:40 PM   #6
sizzflair
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
I use Flash Brown Royal. Spray them on, wait a few minutes, scrub them with some wheel brush and rinse with water. Gets MOST of the crap off.
sizzflair is offline   Reply With Quote
Old 02-19-2012, 02:54 PM   #7
A5un
Member#: 174095
2011 EVO X MR
Gasoline.
Only use in small sections at a time of course. And try it in the inside part of the wheel to test it out.
A5un is offline   Reply With Quote
Old 02-19-2012, 03:39 PM   #8
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
I agree. Its certainly one consideration. I believe these types of chemicals do have a place as long as they are used sparingly, appropriately and properly.
Kean is offline   Reply With Quote
Old 02-19-2012, 05:08 PM   #9
Scooby_Wrx
Member#: 257129
2006 Mitsubishi Evo
I use a Car Brite acid cleaner at work. I also use them on my BBS wheels when they collect brake dust. Gets everything off. Just have to be very careful, because the smell is bad for your lungs. Also if it gets on you it will dry out your skin or if left on for too long could burn your skin. Respect it and it will respect you.
Scooby_Wrx is offline   Reply With Quote
Old 02-20-2012, 09:50 AM   #10
00nEgAtIvE
Member#: 203671
2003 wrx sedan
rally blue
Might not work as well on this level of lack of regularly maintained wheels but Sonax is great. Would definitely try it before using the harsher alternatives.
00nEgAtIvE is offline   Reply With Quote
Old 02-20-2012, 10:36 AM   #11
Kean
Member#: 25187
'08 Foz Prem TGM
....and therein lies the problem with the use/abuse of these chemicals IMO/IME. High volume shops, dealership lots, etc will typically resort to using these cleaners on a regular basis rather use safer, alternative methods first. The fact is that they are faster but they can also be quite destructive to the finish they are applied to as well as your health. .....and some of them can do worse than just burn your skin.
Hydrofluoric acid is very nasty stuff that can actually penetrate your soft tissues (think lungs and nasal passages) as well as your skin causing other permanent health issues later in life. You should always wear the appropriate gloves, goggles and respirator when using these types of chemicals. Personally, I have not had the need to use something this strong as of yet but like I said before, I can see these types of cleaners as a good solution if they are used very sparingly, appropriately and properly.
Old 02-20-2012, 10:41 AM   #12
Kean
Member#: 25187
'08 Foz Prem TGM
....definitely what I would do (using safer alternatives first).
An OTC cleaner you might want to try is Eagle One A2Z. IMO, wheel acids should be more of a "last resort" solution rather than the "go to" product some shops/people use them as.
Old 02-20-2012, 12:16 PM   #13
alt14
Member#: 271928
2014 WRX Limited
Crystal Black Silica
Try soaking them in dawn first, I did that with my winter wheels before I painted them, they were really bad too but it got almost everything off the first time
alt14 is offline   Reply With Quote
Old 02-20-2012, 12:32 PM   #14
wantsti
Member#: 134764
04 sti
java black pearl
Prosoco 300 maybe 600 don't remember its the only thing I have found that works. Look it up on here.
wantsti is offline   Reply With Quote
Old 02-21-2012, 12:04 PM   #15
Scooby_Wrx
Member#: 257129
2006 Mitsubishi Evo
I don't use or abuse this chemical? I was simply stating an alternative to a chemical that the OP could use in my opinion. We do use this cleaner properly and do not re-use it on every car without trying a degreaser first.
Old 02-21-2012, 12:05 PM   #16
Scooby_Wrx
Member#: 257129
2006 Mitsubishi Evo
Apologies, obviously I do "use" the chemical. What I meant to say was using on all cars without trying different alternatives.
Old 02-21-2012, 06:31 PM   #17
wrc_tunedwrx
Member#: 279502
Maybe a soft scrubbing pad with a well-trusted wheel cleaner. I would avoid wire brushes and/or steel wool.
wrc_tunedwrx is offline   Reply With Quote
Old 02-21-2012, 06:40 PM   #18
Busurkin
Member#: 310871
Mother's mag and aluminum polish always worked well for me.
Busurkin is offline   Reply With Quote
Old 02-28-2012, 02:40 PM   #19
zachstork
Member#: 288782
don't use engine degreaser like i did, unless u like your brakes not to work haha.
zachstork is offline   Reply With Quote
Old 02-28-2012, 02:58 PM   #20
IAMDABROODWICH
Member#: 306280
Scooby_Wrx is right. If you're going to use an acid-based cleaner, wear safety glasses, gloves, and a mask, too.(You can buy that stuff at home depot for like 10 bucks. Your health is worth the $). Also, I believe www.DetailersDomain.com has some less harmful stuff than wheel acid.
http://www.detailersdomain.com/Adams...ner_p_239.html
Also, the help of a manly pressure washer will assist you quite a bit. If your dust problem is that bad, you could always talk to a high-end detailing shop and pay them to do it.
IAMDABROODWICH is offline   Reply With Quote
Old 03-01-2012, 09:04 AM   #21
subarowe
Member#: 301364
2009 WRX
Lightning Red
I have used a 3M non-scour pad before on my wife's accord wheels and it got off all of the stuck on crud without scratching
subarowe is offline   Reply With Quote
Old 03-01-2012, 09:15 AM   #22
Doobis
Member#: 309112
2012 Mustang GT
racer..I see you are in pittsburgh..I am to. i am an avid Detailer and I have alot of High end products..I have a few bottles of Sonax FE wheel cleaner that is very very good on extremely dirty and baked on wheels. I can give you half a bottle of it to clean your wheels.
http://www.autogeek.net/sonax-wheel-cleaner.html
shoot me a PM
Doobis is offline   Reply With Quote
Old 03-01-2012, 09:41 PM   #23
R32R1
Member#: 312148
04 R32
Meguires is my choice
R32R1 is offline   Reply With Quote
Old 03-01-2012, 10:13 PM   #24
itstony
Member#: 253911
1999 2.5rs
black
ive seen great results with ironx either in spray or paste form or even meguiars wheel brightener if something simple like APC or sonax isn't cutting it.
itstony is offline   Reply With Quote
Old 03-01-2012, 10:20 PM   #25
Doobis
Member#: 309112
2012 Mustang GT
megs wheel brightener is powerful stuff but ts an acid and has to be handled carefully and not safe for all wheels.
How to clean brake dust off wheels (Off the inside) lavid2002 Car Care & Detailing 31 07-06-2011 01:00 PM
how to clean cobb ct-1 wheels Bad Dogg Car Care & Detailing 1 08-18-2008 01:03 AM
How to clean bronze Volk wheels? moss Interior & Exterior Modification 15 03-07-2006 12:47 AM
Need suggestions on how to clean wheels. Jason02WRXCT Interior & Exterior Modification 8 06-17-2005 09:20 AM
How to clean your wheels? ksikyat2000 Tire & Wheel 11 01-28-2004 12:46 PM
