Old 02-17-2012, 12:42 AM   #1
SynME
Member#: 282245
2008 Impreza WRX
Graphite
Default Steering Angle Sensor Bad - DTC C0054/C0071/C0047 - Help?
Hi all,
I have an '08 WRX. I had PDX Tuning replace the power train with an STI power train, and install a DCCDPro controller. Beyond that, the power train and electronics are stock.
I recently started seeing the following light combination on my dash:
The Hill Start Assist disabled, the traction control, and the ABS lights all come on together. This would happen after about 25 minutes of driving, though tonight it happened within a couple as I made a left turn.
I tried to pull the error codes with the AccessPort, but it said there were not active error codes. I then did the light/odometer button trick and pulled the following:
A - P ----
B - P (blink)
A - C0054 / C0071 / C0047
I looked these up, and it seems to be pointing to a CAN bus issue (C0047) with the steering angle sensor (C0071). The C0054 indicates a bright light switch open, so maybe that's unrelated?
I'm not sure where to begin troubleshooting this as I've not dealt with the electronics of the car before. Any ideas?
SynME is offline   Reply With Quote
Old 02-22-2012, 02:21 AM   #2
SynME
Member#: 282245
2008 Impreza WRX
Graphite
So, anyone?
Old 02-22-2012, 11:35 PM   #3
CosmoTheCat
Member#: 3409
Whoa. Fun.
Check the wiring from the ABS module back to the firewall. Make sure the connection at the ABS module is good and free from corrosion, and then look at the wire loom to see if the split on the loom is up. Make sure there isn't any water pooled up in the wire loom.
I've heard of some odd ABS codes popping up due to water in the wire loom.
The diagnostic procedures for this have you checking to verify that the brake switch is functioning properly, as well as the steering angle sensor, the yaw sensor, and then verifying the ABS module. It could be an intermittent open in the system, or a malfunctioning ABS module.
All of these codes are related and I've got money on it being a common problem. They all tie into the ABS control module (integrated with the ABS pump) which talks with the steering angle sensor, yaw sensor, lateral G sensor, brake switch - it's all tied together with the VDC which communicates with the ECM&BIU.
Call PDX and find out if anything they did with your car would have an impact on the wiring for the VDC system. I haven't been over there to PDX in eons, but I've got nothing but good things to say about them.
CosmoTheCat is offline   Reply With Quote
Old 02-26-2012, 01:29 AM   #4
danetrainer
Member#: 101076
I'm about to chase down a similar issue with my friends 09 Forester (ABS/VDC).
His issue started when his wife banged a curb with the right front and threw the steering off.
The Yaw and G sensor are determining if the car is going strait and level, the steering angle has to be less than 5-7 degrees of what "zero" was set at when it was centered and recorded.
Your problem may be as simple as re-centering & recording the zero point.
I've done this on the Forester twice, yet within about a week or so, it sets the fail code again.
My next step is to run figure 8's and determine if I have an intermittent wheel speed sensor signal, I may need to replace or the bearing/reluctor assy.
Or what the previous post stated a communication error in the Lan/Can bus.
One thing that is important to consider is ANY added sound system or electronic components that can create RF "noise", dissconnect them until your problem is resolved...or determine they may be causing the problem.
danetrainer is offline   Reply With Quote
Old 02-26-2012, 03:38 AM   #5
danetrainer
Member#: 101076
Ran across several posts that stated that replacing the brake switch cured the codes you have.
Old 03-18-2012, 12:59 PM   #6
SynME
Member#: 282245
2008 Impreza WRX
Graphite
So... odd thing. A few days later, the errors went away. I still haven't seen them show up. Maybe there was some water somewhere shorting it out. Not sure. Sorry I couldn't provide some more concrete feedback to the solution. Maybe it will show up again?
Old 04-12-2012, 11:55 AM   #7
Calboy
Member#: 316628
Default c0071
My 2010 Subaru Impreza is throwing a c0071 code too and I cannot figure out what is wrong with it. I bought the car wrecked and rebuilt it. The drivers airbag did blow so I had to replace it along with the clockspring and the steering angle sensor. I took it to Subaru and they said I needed to replace the steering angle sensor because the one I put is was bad. So I replaced it AGAIN and $300 later I got the same story from the dealership!
I replaced the sensor with a brand new OEM one and I know I did it correctly. I've been rebuilding cars for nearly 10 years so I know what I'm doing. I found another shop with a scanner that would read the code and he said that for some reason the sensor wasn't changing when the wheel was turned. When I first installed the sensor the traction control light went off for about 100 yards then came back on so I know it works.
Does anybody have any more ideas on what it could be? I've tried everything I can think of so any input would be much appreciated.
Calboy is offline   Reply With Quote
Old 03-14-2014, 03:00 PM   #8
G1nkgo
Member#: 301686
2008 WRX
white
did anyone here that had steering wheel angle sensor problems have a really rough idle or stall?
G1nkgo is offline   Reply With Quote
Old 03-15-2014, 05:57 PM   #9
Elbert Bass
Member#: 283429
C0071 has 19 detail codes that direct you to 4 different diagnostic procedures. You would be looking for C0071 followed by something like 2143H. You probably need to use an SMIII or some other high dollar scan tool to read that detail code.
When you have replaced the SAS have you had the thing zeroed? That will definitely screw you up - a new sensor must be calibrated and codes cleared.
Elbert Bass is offline   Reply With Quote
Old 03-19-2014, 11:15 AM   #10
Noprettygrl
Member#: 315298
2012 WRX PREMIUM
BLACK
Default Traction Control/hill assist lights staying on
Hey this looks familiar to me. Help! I have a 2012 Premium WRX and the traction control and hill assist dash lights come on and stay on when starting only when its below zero. The dealer has been trying to fix the problem since January. The have replaced the battery,Yaw sensor, VDC Control module and Hydraulic Control Unit, none of these 'fixes' worked and the car is now back at the dealer. They are telling me now they are going to replace the angle sensor. Has anyone else had any of these multiple issues? This is the 4th time i have had to drive around in a rental while they try and figure out whats going on with it.
Noprettygrl is offline   Reply With Quote
Old 03-19-2014, 11:18 AM   #11
Noprettygrl
Member#: 315298
2012 WRX PREMIUM
BLACK
My car starts hard for a 2012 when its below zero, and dash lights hill assist and traction control lights stay on and the dealer has replaced many things trying to figure out whats going on with it. They are currently replacing the angle sensor to see if that works.
Old 03-27-2014, 12:04 AM   #12
dirtysti05
Member#: 248577
2010 wrx sti
blue
how do you zero the steering angle sensor? I had a new steering rack put in my car and now i have lights galore on the dash. dealer tells me steering sensor but want 579 to replace it. can it be recalibrated? or zeroed back without crazy dealer pricing?
dirtysti05 is offline   Reply With Quote
Old 04-22-2014, 02:42 PM   #13
HyG3nx
Member#: 355826
09 WRX hatch
So it just happened to me as well. About two weeks ago had my steering rack replaced along with ABS module (damn abs unit is crazy expensive). Then just yesterday my vdc light and hill assist light are stuck on. uuhhgg. no codes from AP, however, found out how to pull the DTC on dash board and these popped up:
0071
0072
0047
Joy.
HyG3nx is offline   Reply With Quote
Old 06-10-2015, 12:22 AM   #14
gregnauman
Member#: 97453
2005 Outback XT
Atlantic Blue
I have the same issue on a VDC 07 Outback C0052, C0054 and C0071
I replaced the brake light switch tonight and it did not fix it. Checked the old switch with a meter and it seemed to match what it should do according to the service manual.
I have no clue whats causing this and the VDC/ABS ECU is $369
gregnauman is offline   Reply With Quote
Old 09-15-2015, 11:08 AM   #15
08SubbiePR
Member#: 430162
I wonder if you have had this problem happen again? I am starting to have problems with my 08 WRX to the point it turns off.
08SubbiePR is offline   Reply With Quote
Old 12-20-2015, 12:56 PM   #16
Jam12288
Member#: 340011
2008 WRX Hatch
Has anyone replaced there steering wheel angle sensor and had success clearing these codes?
Jam12288 is offline   Reply With Quote
Old 12-21-2015, 10:08 AM   #17
gregnauman
Member#: 97453
2005 Outback XT
Atlantic Blue
After replacing brake light switch, which i understand can cause this issue, (Subaru Mechanic and service manual) my codes would not clear.
I took my car to my Subaru Mechanic buddy at the dealer and the only way ABS codes can be cleared is with the Subaru Select Monitor.
Disconnecting the battery, or using pretty much any other device will not work.
So my recommendation is to have it cleared by Subaru and then see if it comes back.
The service manual for the Legacy has some good information on these codes and what to do.
Old 01-01-2016, 08:15 PM   #18
j5_sti
Member#: 434478
09 STI
I'm going to try using FreeSSM to clear these codes. I just ordered the cable needed, stay tuned..
More info on FreeSSM here..
http://www.subaruoutback.org/forums/...r-ecm-tcu.html
j5_sti is offline   Reply With Quote
Old 01-23-2016, 11:56 AM   #19
j5_sti
Member#: 434478
09 STI
So FreeSSM wasn't able to access the TCM only the ECM. I ended up taking a chance and ordering an AllScanner VxDiag that claimed to come with SSM-III from eBay for about $350 from China. And what do you know, it's exactly what I needed! It came with what's prolly a boot leg ver of SSM-III but this software is sweet, you have access to absolutely everything. I was able to see the TCM codes, clear them, check and reset the steering angle. Problem solved without needing to replace any sensors.
WTB : CA - 06 sti steering angle sensor livinlocal Private 'Wanted' Classifieds 8 01-10-2016 02:48 PM
WTB : 06 sti steering angle sensor livinlocal Private 'Wanted' Classifieds 0 03-19-2011 05:01 PM
Replacing the Steering Angle Sensor/ Clock Spring nvrenufsti Brakes, Steering & Suspension 0 12-11-2008 06:38 PM
WTB Steering angle sensor Blue beard Private 'Wanted' Classifieds 0 05-08-2008 03:43 AM
DCCD not working after quick rack install,steering angle sensor? Supraru gt Transmission (AT/MT) & Driveline 0 07-18-2007 05:00 PM
