Old 02-17-2012, 02:48 PM   #1
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Default Using 08 Impreza front struts as Koni Cores on a 2011- Issues?
I ordered Konis (loved them in past applications) for my 2011 WRX. Car is mostly stock, though I will have to see whether my wallet will allow for RCE Yellows or Blacks before I actually do the Koni install.
As 2011 donor struts are hard to come by, I searched and found a fairly local set of donor cores from a 2008 Impreza. Seeing as how every indication has been that any Impreza core is fine (WRX or otherwise), I don't see that being an issue. Also, Konis are the same part number for all 08+ WRX models, so fitting the insert in the housing is not an issue.
My question more pertains to aligning the vehicle after the install. I have a 100-mile daily commute and don't need a pure-performance alignment. I want something that won't chew up tires, so a stock-like alighment is preferred.
I read the following quote from GTWorx back when they did their initial install of the GTWorx Bilsteins in the 2011:
Originally Posted by RaceComp Engineering
The holes in the front clevis tabs are spaced 10mm further out than on the GH struts. I did not take additional measurements, but I assume that the front control arms are 10mm wider as well. What this means is that when using 08-10 struts on the 2011, you gain a ton of front negative camber. With the car on the alignment rack, it maxed out at -2.8 with OEM strut top mounts It can also be dialed back as far as -1.2 for a more conservative alignment.
With all of these mods done and the camber dialed in to max negative, the car feels absolutely amazing. [Y]ou might gain a large advantage (in competition)with the additional camber capability.
I found these alignment specs but (honestly) don't know what they mean:
Originally Posted by jonklein611 View Post
Camber (Difference between RH and LH 30′ or less):
–050′030′
Caster:
630′
Steering Angle:
Inner wheel: 36.61.5
Outer wheel: 32.21.5
Front Toe-in:
02 mm (00.08 in)
Rear Toe-in:
02 mm (00.08 in)
Thrust angle 020′
Less than 20′ when “L” is 15 mm (0.6 in) or less
Given the camber ranges that were reported above, and assuming that Konis (when properly installed) do not drive any changes in the alignment potential of the vehicle, is it going to be possible for my car to be aligned to non-tire-eating specifications after installation of Konis in 2008 Impreza housings on a 2011 WRX?
Thanks in advance.
phenryiv1 is offline   Reply With Quote
Old 02-17-2012, 03:36 PM   #2
rexassian
Member#: 183717
1999 2.5RS
BRP
-1.2 with zero toe will not present any issues with tire wear. Even -1.5 should still be fine as long as you have zero toe.
rexassian is offline   Reply With Quote
Old 02-18-2012, 08:57 AM   #3
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Thank you. If I am reading the specs correctly in the RCE post that I quoted, those values are within the range that they found for '08-10 struts in an '11, so I should be good.
Old 02-19-2012, 09:06 AM   #4
jrose29
Member#: 279481
2011 WRX
I have the 08 wrx strut bodies on my 2011. You will be just fine if you take as much camber out of the front as you can. I was running about 2 to 2.5 up front last year a noticed some inner tire wear but the car drove just fine.
Like said above keep it less the 1.5 in the front and you should be good.
jrose29 is offline   Reply With Quote
Old 02-21-2012, 03:03 PM   #5
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Did you run these on stock springs?
Old 09-12-2013, 11:37 AM   #6
STI-impreza
Member#: 45871
1995 impreza
Red
Did the 08 struts require any kind of modification to bolt up to the wider track of the 2011? I bent the front driver strut on my 2011 and found a local guy that had the entire oem strut/spring/top hat set from his 08. I plan on just swapping the 2 fronts and just swapping my 2011 springs onto them and since I don't have the money right now to change anything else I have to use the oem inserts even though I know they aren't as stiff which I know will effect my ride quality but I'm on a budget and just want to get rid of the bent strut for now. Is this a feasible thing to do?
STI-impreza is offline   Reply With Quote
Old 09-12-2013, 11:56 AM   #7
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Your natural negative camber will be greater due to the different widths, but they physically bolted up just like the 2011 ones. Just dial out ALL of the negative camber that you can to minimize inner tire wear.
I would NOT run different ones (2008 v. 2011) on different sides, but that does not sound like an issue.
What did you bend on your 2011 strut?
Old 09-12-2013, 12:41 PM   #8
STI-impreza
Member#: 45871
1995 impreza
Red
I'm a newb so I'm not sure how to dial out negative camber. I bent the strut body between the lower spring perch and the bottom
Old 09-12-2013, 12:53 PM   #9
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
Damn, I was hoping that you had bent the piston. I'd have bought them from you.
There are 2 bolts that attach the strut to the knuckle. One of them is for adjustment of camber- it has an oblong shaft design that moves the bottom of the strut in or out. It will be pretty obvious which way you are moving it. You want to use the setting that is as close to straight up and down as possible.
Old 09-12-2013, 12:57 PM   #10
STI-impreza
Member#: 45871
1995 impreza
Red
Awesome thanks for the feedback I appreciate it. I'm just hoping swapping my 2011 springs onto them will help stiffen them up a bit since I know the 08s aren't as stiff which kinda sucks because I love the stock ride feel in the 2011
08+ Perrin Front Strut Bar install Fun5iz3 Newbies & FAQs 8 11-05-2011 01:33 PM
WTB : 08+ WRX front struts, Koni yellows, Inserts! slowgrey08 Private 'Wanted' Classifieds 0 07-06-2011 06:05 PM
Whiteline Com C Front Strut Mounts and lower ball Joint a Fittment Issue??? 02wrxin Brakes, Steering & Suspension 2 12-17-2010 05:14 PM
FS: 08+ Cusco Front Strut Bar talsnic VIC Private Classifieds 4 08-17-2009 10:23 PM
08 STI Front Struts, Same as 07? Impreza_AWDriver Impreza Forum 1 01-04-2008 03:21 PM
