Old 02-17-2012, 02:50 PM   #1
steveomiami
Member#: 309883
Default New to me 1992 JDM WRX ?s
I just bought the car a couple of weeks ago with a bad water pump so I'm going to replace that but in the meantime I want to know what all the previous owner may have upgraded/changed. What all should I check/look to see what all he modified? I was told it has 300 hp which is fine but i want it to be safe hp so i want to look at everything to make sure nothing is ghetto. I'm not new to mechanics but this is my first turbo car.
steveomiami is offline   Reply With Quote
Old 02-17-2012, 05:16 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
didnt you just make this thread?
pictures.
eg33GC is offline   Reply With Quote
Old 02-18-2012, 06:00 AM   #3
steveomiami
Member#: 309883
I have a similar one, I'm really just looking for key things to look for under the hood. where would I find a mbc or abc? How can I tell if the waste gate/turbo are stock? It has a big hks bov, what does that affect? It has what looks like 3 inch exhaust from the turbo back. How can I tell if it has been chipped?
Old 02-18-2012, 08:12 AM   #4
steveomiami
Member#: 309883
also how can i tell if my injectors are stock or not?
Old 02-18-2012, 04:00 PM   #5
eg33GC
Member#: 206851
56 Belair
Pro Street
p i c t u r e s
Old 02-18-2012, 06:38 PM   #6
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Check general maintenance. Look for tool marks or areas of the engine cleaner then the rest. The factory boost controller is mounted to the driverside strut tower. The factory turbo is internally wastegated so in order to check it out you have to pull the turbo to check for porting. Its alot of work with little payout. Its worth checking the turbo shaft for play though.
The ECU is located under the passenger side footwell. again check for toolmarks or evidence that the previous owner was in there. The jackass who had my car before me left 3 snickers wrappers under the carpet next to the ecu. I can be certain he tried other ecu's.
If the work were done by a professional shop they likely wouldnt have left much evidence
Honestly I would be more concerned with the state of the clutch and mtx. That is a far more likely area of abuse by the previous owner.
TommyAtomic is offline   Reply With Quote
Old 02-22-2012, 01:52 PM   #7
steveomiami
Member#: 309883
I checked the ECU and it has a Z4 ecu. I see some wires spliced in to the harness by the ecu so i guess i better trace those and see what they go to, maybe guages or something? Is there something specific I should be looking for to go along with this Z4? The car still has the grey injectors in it and a 3 inch turbo back with no cat. I don't see any signs of a boost controller. Is the stock boost regulator a DENSO brand? Thats whats on there.
Old 02-22-2012, 01:53 PM   #8
steveomiami
Member#: 309883
Also where can i look to see what turbo is on there? Where are the numbers?
Old 02-22-2012, 02:01 PM   #9
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Might be worth figuring out where the spliced wires go.
I'm confused you dont see any boost controller or you dont see the factory boost controller. You would either have the factory controller or an aftermarket; not both.
It will be mounted to the strut tower rhd driver side.
Old 02-22-2012, 02:27 PM   #10
steveomiami
Member#: 309883
I'm assuming that its the factory controller, its on the strut tower and it looks old and it had 2 vacuum lines going to it. It had DENSO on it I think, I figured it was the original boost solenoid or an old replacement
1992 Jdm Wrx Questions steveomiami Pre-2002 Factory Turbo Powertrain 12 02-20-2012 11:40 AM
FS : 1992 Jdm Wrx - $5900 Obo jstbstn VIC Private Classifieds 2 09-27-2011 05:29 PM
FS: 1992 jdm WRX sedan $9700 (<-nasioc price!) 92-GC8 VIC Private Classifieds 10 06-14-2008 01:57 PM
Just bought a 1992 JDM WRX, noob questions! Flat6 Newbies & FAQs 3 05-20-2008 12:56 PM
1991 legacy fwd manual -> 1992 jdm wrx Sojuuk Subaru Conversions 10 10-30-2005 01:11 PM
