Old 02-17-2012, 07:14 PM   #1
niko87
Member#: 303677
Default Newbie: needs hell with Access Port v1
Hello
Im VERY new to this so please bare with me.I just recently purchased a 2002 WRX and the previous owner gave me the Access Port with car. The car has been modded. Mods include: Cobb Intake,STI TMIC, STI pink injectors ; Bloch 18G turbo and HKS cat back exhaust.
Planning to pick up the Cobb downpipe.
The previous owner stated all I have to do is flash the ECU with the Access Port and I will see significant HP/Torque gains.
My question is, can I use the Access Port even though I have all those after market parts? This all new to me so any help/info would be great.
Thank you
niko87 is offline   Reply With Quote
Old 02-17-2012, 07:48 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Hmmm... If he has all those mods doesn't he already have a non stock DP? As for the AP you need the EXACT mods to flash an OTS map on there, what map does he have on there right now?
wrxdrvr is offline   Reply With Quote
Old 02-17-2012, 07:55 PM   #3
niko87
Member#: 303677
Before I bought the car he removed and sold the non stock downpipe (go figure) and he also said he "un-married" the AP and put it back to factory settings.
What does OTS mean?
Old 02-17-2012, 08:26 PM   #4
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
OTS means, off the shelf.. He un-married the AP? That's strange, as then the car shouldn't even be able to run with the Pink injectors and 18G turbo...
Old 02-17-2012, 09:51 PM   #5
niko87
Member#: 303677
Then it must some kind of tune.
Any way to find out with the AP?
Old 02-17-2012, 11:54 PM   #6
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I'm not really sure, with the APv2 when I plug it in it tels me what map is on the ECU but I don't really remember what the APv1 shows...
Old 02-18-2012, 03:20 PM   #7
jnmarshall
Member#: 40500
16 Forester XT
With the exception of the turbo, it sounds like you could have an OTS stage 2.5 or 3 map? If the AP was unmarried the car would probably start, but not run very well. Go to cobb tuning support and get a copy of the appm from http://www.cobbtuning.com/info/?ID=3061 and see what's on you AP. If you didn't get the serial cable, you should also be able to plug the AP into the car and just scroll thru the loaded tunes and write down what you see.
jnmarshall is offline   Reply With Quote
Old 02-18-2012, 03:23 PM   #8
jnmarshall
Member#: 40500
16 Forester XT
Yes. If it's already married, plug it into your car and one of the options will show you the base map loaded to your car. This will not show you the realtime map if there is one that could also be loaded. If it's not married, you'll be prompted to select a base map to load.
Access Port V1 need some advice SIKwrx04 Newbies & FAQs 2 03-22-2011 05:12 PM
access port v1 vista connection to pc. problems with connection moorebl AccessPort 4 08-03-2009 06:41 PM
Vf-39 and 06 WRX Cobb access port v1 with street tuner atvracer111 Engine/Power/Exhaust 4 07-15-2007 08:54 PM
Cobb Access Port V1 02/03 mnwrxjoe Engine/Power/Exhaust 13 04-02-2007 08:22 PM
Cobb Access Port v1 (2006 WRX MT) WRXorcism Engine/Power/Exhaust 2 01-23-2007 04:56 PM
