Old 02-18-2012, 12:41 PM   #1
CanHas
Member#: 255158
2012 STi
Plasma Blue Pearl
Default Would someone like to take a look at my log? (Stage 1 2012 STI 4th gear wot pull)
Gentlemen,
Here at VIR today with NASA holed up in the T&S tower as usual, but I poked my head out to grab a log on the back straight:
https://docs.google.com/spreadsheet/...lhOWWFGMnUtQ0E
Car:
2012 STI
Mileage:
1027
Map:
Stage1 93 Octane Boost Select 93 Stock 3.10
Outdoor Temp:
59F
Basically my concern isn't power, just reliability, and I am wondering if the fine knock learning @ 3557RPM (and also, the 19.03 psi boost measurement) is something to be concerned about? I am tempted to run the 91OCT map until I can get a protune, just for safety's sake.
Thoughts?
Thanks in advance.
-Rex
CanHas is offline   Reply With Quote
Old 02-20-2012, 06:00 PM   #2
Cobb Tuning
Member#: 4803
Rex,
You are on the high end of the boost targets for that map. If you are going to track the car, I might recommend the LWG map or the 91 octane map to have an extra "margin of safety". A track day pushes the car harder, so having a slightly less aggressive map is probably what you're looking for. Besides that small correction after peak boost, the log looks good!
Ian
Old 02-20-2012, 07:16 PM   #3
CanHas
Member#: 255158
2012 STi
Plasma Blue Pearl
Originally Posted by Cobb Tuning View Post
Rex,
Ian
Ian, thanks. The most excercise this car is likely to see is at an autocross, I time the races, not run them. Digging into this data on sunday, I loaded the 91oct map, which still has plenty of power for yours truly. I was more concerned about the stock map awfulness...I drove my buddy's '11 wrx before buying this STI, and pinging at 4k made me pretty leery of all the "ZOMG I busted my ringlands!" disease that is semi-endemic of the 3G's.
But thanks very much Ian, I appreciate your assistance!
Could someone take a look at my logs for me? robwormald AccessPort 37 11-14-2011 12:19 PM
Can someone take a look at my logs? Tyrus3 AccessPort 3 08-26-2011 09:27 AM
WRX02 stage2, take a look at my log pls KENT56 Open Source Reflashes 15 10-31-2008 01:41 AM
Please help take a look at my logs... spitfirezip100 Engine Management & Tuning 22 04-27-2007 03:12 AM
Can someone take a look at my logs? cr125r Engine Management & Tuning 51 01-22-2007 06:36 PM
