Welcome to the North American Subaru Impreza Owners Club Thursday July 2, 2015
Old 02-18-2012, 05:56 PM   #1
engelman27
Member#: 273311
2002 Mazda miata
Default Do I HAVE A BOOST LEAK?? Datalog info
So Ive been Datalogging and From what i see things dont look bad?! I dont really know much about the parameters but I know what a good one looks like for the most part. the only thing was my boost. I never reached target boost (target= 19.5, I got to 16ish) also my boost was somewhat all over the place building (non linear, up and down) and then on the taper to redline it was up and down. I think my topmount might be slowly leaking. what do you think?
engelman27 is offline   Reply With Quote
Old 02-18-2012, 08:53 PM   #2
hutch959
Member#: 267463
i dont see the log.
hutch959 is offline   Reply With Quote
Old 02-21-2012, 08:45 AM   #3
AWDPWR12
Member#: 303314
Need a Log
AWDPWR12 is offline   Reply With Quote
Old 02-23-2012, 11:16 PM   #4
engelman27
Member#: 273311
2002 Mazda miata
sorry i couldnt figure out how to post my datalog. i have a spread sheet on microsoft excel 2010...??? where do i go from here?
Old 02-23-2012, 11:20 PM   #5
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
upload it to google docs, share the doc then post a link here.
Bishop is offline   Reply With Quote
Old 02-26-2012, 07:19 PM   #6
engelman27
Member#: 273311
2002 Mazda miata
Old 02-26-2012, 07:23 PM   #7
engelman27
Member#: 273311
2002 Mazda miata
Damm I feal computer savy right now! did i mention Im not to swift w the computer box?
Also im getting a p0037 code?? ho2s heater control circuit low (bank 1 sensor 2)
only thing done is the downpipe, and i moved the sensor to the cat? I did stretch the wire a little when i was doing the work? I dont know. I read its no big deal but its kindof irritating.
hows the log?
Old 02-26-2012, 08:47 PM   #8
AWDPWR12
Member#: 303314
Originally Posted by engelman27 View Post
U need to give us permission!
Old 02-26-2012, 09:16 PM   #9
Dartholomew
Member#: 208771
2009 WRX
Go to the doc in Google Docs, click on "share in the upper right, and set it as either publicly available, or viewable by whoever has the URL.
Dartholomew is offline   Reply With Quote
Old 02-28-2012, 12:10 AM   #10
engelman27
Member#: 273311
2002 Mazda miata
https://docs.google.com/spreadsheet/...WhMMmNwOXp1V3c
my goood what a pita!!! my google acct is through my school so the shariing is a little different! i think??!!! couldnt make it shareable outside of my school... either way i just made another one through my own account and changing the sharing was simple. thanks for your patience!
Old 02-28-2012, 02:58 AM   #11
Airboy
Member#: 72829
2006 WRX
2015 WRX
How did you determine that boost target is 19.5psi? In any case, boost target changes with elevation and air temperature. If you check the data item "TD Boost Error (PSI)" in your log, the error is <1psi once you hit full boost. It looks like boost target is ~17psi tapering to 15psi.
Airboy is online now   Reply With Quote
Old 02-28-2012, 11:28 PM   #12
engelman27
Member#: 273311
2002 Mazda miata
im hearing everything your saying airboy! I dont know how to read a datalog, except for the minut info i saw on the cobb video... i got 19.5 because thats what the stage 2 map states. does the log look good? I think its ok. I keep getting p0037 code. is it the dp o2 sensor?
Old 02-29-2012, 01:07 AM   #13
Airboy
Member#: 72829
2006 WRX
2015 WRX
There is a bit of Fine Knock Learning above ~5000rpm but doesn't look like anything serious. P0037 is related to the rear O2 sensor in the downpipe. It could be the sensor or a small exhaust leak at the gaskets.
Old 02-29-2012, 02:19 PM   #14
engelman27
Member#: 273311
2002 Mazda miata
ok that makes sense. you mean the gasket between the turbo and dp? rightt?
Do I have a boost leak TurmultTee Newbies & FAQs 4 03-22-2008 05:13 PM
So i think i have a boost leak, how do i test this? jefersun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-20-2004 09:58 PM
should boost hold on 3 and 4 at high rmps? or do I have an uppipe leak? vapore0n Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 07-16-2003 10:12 AM
how do i tell if i have a boost leak?? WRxednEffect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 03-10-2002 02:26 AM
Do I have a boost leak? Dude Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-03-2002 04:48 PM
