Old 02-19-2012, 06:27 PM   #1
WRB19
Member#: 302898
2011 WRX E85 1.5XTR
Default 2011 wrx stage 1 + sf not reaching peak boost
I re did some logs please check them out
This is my normal wastegate stage 1 + sf 3rd gear pull as you can see boost is low
https://docs.google.com/spreadsheet/...npVWDFtb3pBVUE
I switched to the HWG map and did a log and I got around the target boost
https://docs.google.com/spreadsheet/...HhCTk9kYmU5Z3c
I am at 6000 feet above sea level too.
The normal stage 1 map worked fine when I didn't have the intake. Now that I have the intake I have to run the HWG map to get peak boost. Could someone explain to me why? Also do the HWG logs look good? Thanks
WRB19 is offline   Reply With Quote
Old 02-19-2012, 11:39 PM   #2
skabat
Member#: 272303
2011 WRX
You'll need to make your spreadsheets public so we can see them, BUT make sure all your connections are tight and try the High Wastegate map off Cobb's site.
skabat is offline   Reply With Quote
Old 02-20-2012, 06:45 AM   #3
WRB19
Member#: 302898
2011 WRX E85 1.5XTR
I made them view able thanks
Old 02-20-2012, 03:26 PM   #4
skabat
Member#: 272303
2011 WRX
You'll need to change some settings on the AP to log more things. Your logs now don't show much at all. Setup your AP to log these…
A/F Correction 1
A/F Learning 1
A/F Sens 1 Ratio
Boost Target
Boost
Calculated Load
Dyn. Adv. Mult
Feedback Knock
Fine Knock Learn
Gear Position
Ignition Timing
Inj. Duty Cycle
MAF Volt
MAF
TD Boost Error
Throttle Pos
Wastegate Duty
From there, do two different driving logs.
One - Normal driving, day to day type stuff.
Two - Do a few pulls in 3rd gear. From 2000rpm to redline.
Old 02-20-2012, 07:22 PM   #5
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
A/F Correction 1
A/F Learning 1
A/F Sens 1 Ratio
Boost Target
Boost
Calculated Load
Dyn. Adv. Mult
Feedback Knock
Fine Knock Learn
Gear Position
Ignition Timing
Inj. Duty Cycle
MAF Volt
MAF
TD Boost Error
Throttle Pos
Wastegate Duty
There is no need to log gear position, or boost target.
There is also no need to log normal driving. If there is an issue it will be present no matter how you drive.
Logs should be done in third from 2500-near redline if you can do so safely.
OP just set your logging parameters to the default. They are the ones you need to be looking at.
2Fast4U1DAY is offline   Reply With Quote
Old 02-21-2012, 07:07 PM   #6
WRB19
Member#: 302898
2011 WRX E85 1.5XTR
Old 02-21-2012, 10:41 PM   #7
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
I can't see Cobb notes to verify at the moment. Can you post up the section about boost targets for your Maps?
That shouldn't have changed your actual boost levels by.changing the intake.
Altitude will certainly have an effect on boost numbers.
Old 02-21-2012, 10:58 PM   #8
WRB19
Member#: 302898
2011 WRX E85 1.5XTR
Boost targets are 16psi on both the HWG map and the normal one. I ran the HWG map and got 15.8 psi which is good. The normal map worked fine before I put my SF intake on. Now with my SF intake I need to use the HWG map to hit the boost target, whats up with that?
Old 02-22-2012, 08:26 AM   #9
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Not sure lol
Old 02-22-2012, 03:08 PM   #10
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
There are a few small differences in the maps which is causing your car to boost a bit lower. We made changes to the 2012 WRX SF maps and will be updating the earlier model year maps with those changes soon!
Ian
Old 02-22-2012, 10:04 PM   #11
WRB19
Member#: 302898
2011 WRX E85 1.5XTR
Ian
Alright sweet. So should I still be using the HWG map? Did the log look okay?
2011 wrx stage 1+sf cliff_11WRX AccessPort 8 01-31-2012 09:53 AM
Datalog - 2011 WRX Stage 1 + SF Intake matt2WRX AccessPort 21 01-30-2012 11:06 AM
Not reaching peak boost. grimm5577 Factory 2.0L Turbo Powertrain 6 08-03-2006 01:09 PM
not reaching peak boost grimm5577 North West Impreza Club Forum -- NWIC 1 08-03-2006 10:59 AM
Boost Gauge not working...not reaching peak boost. mnwrx78 Factory 2.0L Turbo Powertrain 0 06-29-2006 10:20 AM
Message Board Statistics All times are GMT -4. The time now is 03:02 AM.
