Old 04-10-2012, 08:40 PM   #26
eg33GC
Member#: 206851
56 Belair
Pro Street
The only time I weighed it was about 2690, but I've fattened it up a bit.
I was not going balls to the wall, but 12.35 is pretty quick for a stock longblock G.
Car did trap a 114 the first run of the day, with a 14.9 ET
eg33GC is offline   Reply With Quote
Old 05-01-2012, 01:57 PM   #27
subywag
Member#: 239731
90s ejs
rainbow
pretty cool stuff man! staying tuned...
subywag is offline   Reply With Quote
Old 05-07-2012, 11:26 PM   #28
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Ugh. Don't get me thinking about E85 again! My pursuit for E85 is the reason i'm replacing my motor now
And you're in the same state as me? Ugh!
tenchu is offline   Reply With Quote
Old 05-08-2012, 12:41 AM   #29
eg33GC
Member#: 206851
56 Belair
Pro Street
It's on pump now, for DD purposes. I would average 20-22mpg on the corn, but now I hit 27.27mpg on 92e10. that 5mpg adds up! That and I don't flog it at all anymore, so it's a waste of fuel and money to keep using it.
Old 05-08-2012, 10:44 AM   #30
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Word. I don't intend on dailying mine. Nice to know its a possibility though maybe one day I'll get squirrely again and hit you up for info.
Intrigued about svx MAF for sure
Old 05-08-2012, 04:18 PM   #31
pmugabi
Member#: 280926
1st. I thought E85 makes up for worse MPG by a lower price?
2nd. You seemed to be getting so much extra power from the fuel conversion, I didn't expect you to revert. Remember your post that 12psi on corn beats 18psi on gas? With even better spool.
I'm very interested in your reasons for switching back to ordinary gas.
pmugabi is offline   Reply With Quote
Old 05-08-2012, 04:29 PM   #32
eg33GC
Member#: 206851
56 Belair
Pro Street
The cost difference is half a USD per gallon. It is also only E70 until late June.
My only other gripes were cranking fueling, and cruising afrs. Because I changed mafs, used injector scaling instead of just modifying fuel cells, it seemed like cruising stuff had an issue with finding the proper load values.
I also only drive the car 2 days each week, and that happens to be at each weekend. So the fuel sits and collects moisture for 5 days at a crack. It was getting to the point with our weather that you could notice the fuel becoming diluted with water.
I'm also becoming a little more responsible with the car, I don't feel that making the power to trap 114mph in the quarter mile (~320whp by the standards discussed in the PPB section) is a smart idea on this 20 year old engine with stock components and composite gaskets.
I should have noted that this is only a very temporary "switch", by the way. I will ultimately be going back to the fuel when the time (K heads, reverse G manifold, 207 shortblock, small efficient intercooler, evo3 compressor wheel) permits.
As you can see, it was getting out of hand
Old 05-11-2012, 03:28 AM   #33
pmugabi
Member#: 280926
Unbelievable!
That is insane timing. I can only imagine what the car feels like. I see you've still got the low load timing for the pops and bangs. How are those working out? In my case, it simply means that exhaust gaskets have a 2 month service life.
Old 05-11-2012, 11:58 AM   #34
eg33GC
Member#: 206851
56 Belair
Pro Street
It's nuts, because with the fueling mixed with the low timing and the throttle kicked ever so slightly, the boost gauge goes from -25hgmm to like 3psi every BANG. On gasoline, it is just a noise maker.
I wish we could set timing to a negative value, and then add oh, 30% more fuel at those values
Let me in on your rotating idle code!
Old 05-12-2012, 10:01 AM   #35
pmugabi
Member#: 280926
The timing is actually negative. I wrote a function that modifies what I have understood to be 'time till next spark event'. You can adjust that parameter to make the timing more negative, I didn't have the courage.
Rotational idle is still in development. Hopefully in 2 weeks it will be done, laziness permitting.
Old 05-13-2012, 01:29 AM   #36
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Am I the only one who doesn't want to blow their motor anymore?
Hey Paul I have an idea for negative ignition timing that might be easier (and SAFER) than modifying the current crank position or next event timer. I will send via email.
-Rob
rob is offline   Reply With Quote
Old 05-13-2012, 10:13 AM   #37
eg33GC
Member#: 206851
56 Belair
Pro Street
Let's get some real antilag going!
I'll be test bitch
I've tested 5,10,20 for the timing values. From my prev experience with DSM als, the loudest and best results occur at ~30, a kicked plate, and ~20% fuel
Old 09-24-2012, 01:01 PM   #38
luka
Member#: 194742
1993 Impreza WRX JDM
what ECU are you running to use RomRaider? looking at the site it only support OBDII
luka is offline   Reply With Quote
Old 09-24-2012, 01:03 PM   #39
eg33GC
Member#: 206851
56 Belair
Pro Street
u8 socketed 4 plug
you use RR as an interface for modifying the rom
Old 09-24-2012, 01:20 PM   #40
69subaru360
Member#: 159682
1995 WRX
2015 F150
Romraider only edits the rom. You need to purchase chips and a chip burner and use other software to burn the rom to the chip. You also need to download and install the EJ20G definitions to romraider.
Old 09-24-2012, 02:10 PM   #41
REECERS
Member#: 259958
im lost, how do you guys learn on this stuff
REECERS is offline   Reply With Quote
Old 09-24-2012, 02:30 PM   #42
eg33GC
Member#: 206851
56 Belair
Pro Street
I've decided to stick it out with the ej20g ecu, unless I could make esl use rotating idle. I don't think they ever will do a als/ri. I think lc and ffs is on the way.
Old 09-24-2012, 07:56 PM   #43
tenchu
Member#: 64147
1993 STi RA V LTD
Green
So you're giving up on E85? Thats sadness, I want my GC to run on corn
Old 09-24-2012, 09:23 PM   #44
eg33GC
Member#: 206851
56 Belair
Pro Street
no?
I did switch off it while my car was my dd though, for mpg purposes.
Old 11-29-2014, 07:31 PM   #45
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Y u no progress!?
Any OTers into Android Development? timskyline86 Off-Topic 8 02-19-2012 03:04 PM
FS/FT : wrong thread echoe09 Private Vehicle 'For Sale' Classifieds 3 02-19-2012 10:10 AM
The please read first Stock ECU Reflash Thread Broxma Commercial ECU Reflashes 9 10-27-2007 02:55 PM
Best ECU Wiring threads speedman110 Subaru Conversions 3 11-24-2003 08:10 PM
Opinions wanted: AMR Kit - ECU Development & future of 2.5 turbo kgb Technical Forum Archive 31 08-02-2000 06:46 PM
