Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Closed Thread
Old 03-16-2013, 11:34 PM   #2476
05subysti
Member#: 268190
2005 STi
if you're crazy enough do 38mm in front, 25mm spacers on rear
05subysti is offline
Old 03-17-2013, 12:43 AM   #2477
Rattsl
Member#: 340348
05 Stage 2 LGT
Washed it, and went to work, then back home.
In the lookout for tints as well.
Rattsl is offline
Old 03-17-2013, 04:12 AM   #2478
johnblahuta88
Member#: 221614
helped gave birth to a stage 2 wrx 2013
johnblahuta88 is offline
Old 03-17-2013, 12:51 PM   #2479
backslider
Member#: 43196
1999 STi Type R
93GF 95GC 02GD 01SF-T
Removed the body from the subframe. Next weekend, cutting and welding...
backslider is offline
Old 03-17-2013, 01:30 PM   #2480
HonduHunter
Member#: 28408
2002 vf48ed WRX
Wow...
HonduHunter is offline
Old 03-17-2013, 04:34 PM   #2481
07imprezive
Member#: 251703
2007 impreza
satin white pearl
Hmmm.. really, would that b enough to b somewhat, flush to the body.
07imprezive is offline
Old 03-17-2013, 08:48 PM   #2482
juandering
Member#: 330389
05 Saabaru
Hung out with Todd over at TNA while he installed TGV deletes and injectors on my saabaru, great guy and does great work
juandering is offline
Old 03-17-2013, 09:21 PM   #2483
05subysti
Member#: 268190
2005 STi
Yes if you want some flushness with stock BBS do 38mm in front with a tad of camber. 25mm rear is fine.
If you don't want it as aggressive in front just do 25mm all around.
Might need to roll fenders and trim rear flares. Depends how low you are and if you have stock tire size.
Old 03-17-2013, 09:50 PM   #2484
laxman2001
Member#: 268558
2008 STi
Picked up a replica v-limited lip and a group n tranny mount.
laxman2001 is offline
Old 03-17-2013, 09:54 PM   #2485
Excision
Member#: 294622
2007 STI - WRB
Perrin GTX3076r, Slow
^do you trust them when putting down 400whp and drive hard? they seem freaking sketchy
Excision is offline
Old 03-17-2013, 10:04 PM   #2486
laxman2001
Member#: 268558
2008 STi
Is that directed at me?
Old 03-17-2013, 10:27 PM   #2487
Boosted Up
Member#: 154828
04 & 12 WRX 06 STI
Ordered some goodies for the Leggy:
Works 18x9.5 11R in bronze
245/40 Dunlops
H&R Springs
Boosted Up is offline
Old 03-18-2013, 02:07 AM   #2488
Excision
Member#: 294622
2007 STI - WRB
no, that was too 05suby. sorry for the confusion
Excision is offline
Old 03-18-2013, 08:27 AM   #2489
20_sec.hatch
Member#: 238655
2015 So many subies
Custom colors
Wrapped my a/c vents, center radio/ac control bezel and shift boot plastic in carbon fiber. Still needing sanding, epoxy, sanding, a few coats of clear coat, wet sand and buff. Hopefully I will have some pics up in a few days.
20_sec.hatch is offline
Old 03-18-2013, 09:36 AM   #2490
TheTallOne
Member#: 302855
2008 WRX
DGM/CF
Thanks, good luck with the tune today.
TheTallOne is offline
Old 03-18-2013, 01:23 PM   #2491
07imprezive
Member#: 251703
2007 impreza
satin white pearl
Hmmm.. will look into that, and right now I'm not on stock tire size, I'm running just a tad wider, 245/40. Maybe will go down and raise'er a bit when I get the spacers. Thnks for the info man. Preciate it.
Old 03-18-2013, 06:47 PM   #2492
Themmhmmmm
Member#: 309476
2011 WRX
Snagged an outback loaner while my bumper is getting fixed. Really missing my WRX whilst getting on the highway. :/ although I do have to say the interior is very nice.
Themmhmmmm is offline
Old 03-18-2013, 06:49 PM   #2493
2_fast
Member#: 237523
2008 WRX Wagon
Still breaking the new South Bend Stg3 clutch kit and ACT Streetlite flywheel. I'm ready to floor it already!!!
2_fast is offline
Old 03-18-2013, 07:06 PM   #2494
SWP is Sexy
Member#: 302389
2011 WRX
I'm a stormtrooper pewpew
Ordered an AEM filter sock
SWP is Sexy is offline
Old 03-18-2013, 09:12 PM   #2495
CashmanRay
Member#: 266652
2009 2.5i hatch
A/C filter swap wh-whut!
CashmanRay is offline
Old 03-19-2013, 01:22 PM   #2496
atomicfire
Member#: 136296
2005 STi
GF's 08 STI:
Removed turboback because failed visual on inspection (?? I got the ONE inspector that checked for cats)
Installed stock downpipe, realized after I already bolted everything back together that I missed a bolt
Removed stock downpipe, pulled the bolt out
Reinstalled stock downpipe
Installed a stock exhaust because the Perrin one is getting sent out to be powder coated
Zip tied reverse lockout cable away from drive shaft
On my 05 STi:
Changed the reverse lockout cable - old one got eaten by the driveshaft
Adjusted parking brakes (the right way)
On a friend's WRX:
Changed timing belt and idlers.
Found out his power steering pump is vomiting fluid everwhere
Bled his brakes with fresh fluid
Adjust parking brakes
Whew, it was a productive weekend, AND I managed to spend a ton of time out at TX2K
atomicfire is offline
Old 03-19-2013, 07:32 PM   #2497
m_clark54
Member#: 224322
2013 WRX Spec Ed
Tangerine Orange
Wife ****ed up her new outback and I got to learn how to fix garage doors.
She forgot we left garage partially open after work. About 100 degrees outside and two hot engines made it impossible to work in here.
Back her brand new 2012 outback right into the door. ****ed the paint up. Huge chunk. Decent sized dent.
Then tries to open garage with opener button and it gets stuck. Facepalm.
She told me shes gonna fix it..???
Idk.
Yeah. That kinda day.
m_clark54 is offline
Old 03-19-2013, 08:46 PM   #2498
MyCousinTookMyName
Member#: 337701
2013 WRX
PBP
Just got my SPT boost gauge in today. Can't wait to install it.
MyCousinTookMyName is offline
Old 03-19-2013, 10:13 PM   #2499
do0ki3_pwn5
Member#: 349244
2003 impreza wrx
wr bp
drove it, hood was not closed properly.... FML need a new hood now...
do0ki3_pwn5 is offline
Old 03-20-2013, 12:25 AM   #2500
johnblahuta88
Member#: 221614
^did you forget to fill it up with oil and leave the can still in the fill line
Closed Thread
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 03:08 AM
What did you do to your subie today?! 07imprezadrifter General Community 277 06-14-2009 11:42 PM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 12:02 PM
