Welcome to the North American Subaru Impreza Owners Club Tuesday August 4, 2015
Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Closed Thread
Old 03-25-2013, 11:11 PM   #2551
tito sti
Member#: 247648
tito sti is offline
Old 03-25-2013, 11:24 PM   #2552
SGC2CIC
Member#: 286908
2014 EVO X GSR
2000 2.5RS
Originally Posted by tito sti View Post
I couldn't imagine my rsti with that much power
SGC2CIC is offline
Old 03-25-2013, 11:56 PM   #2553
Random LTD
Member#: 343953
2010 WRX LTD. 5 door
Originally Posted by iconone View Post
Post some pics please. I'm interested to see lugs plasti dipped.
As soon an I put pics on my cpu ill post my wheels and put the rest of my pics in the car photos thread
Random LTD is offline
Old 03-25-2013, 11:59 PM   #2554
Random LTD
Member#: 343953
Originally Posted by SGC2CIC View Post
Putting the lugs back on will just get messed up by the lug wrench
I thought that might happen to but it didn't mark them up at all
Old 03-26-2013, 01:27 AM   #2555
johnblahuta88
Member#: 221614
just put bbq paint on them and whale on them
johnblahuta88 is offline
Old 03-26-2013, 08:59 AM   #2556
tito sti
Member#: 247648
You would like it for sure that was at 25 psi going to be on 30 some time soon
tito sti is offline
Old 03-26-2013, 10:29 AM   #2557
backslider
Member#: 43196
1999 STi Type R
93GF 95GC 02GD 01SF-T
NIIIICCCCEEEEEE!!!!!!!
Who is tuning it?
backslider is offline
Old 03-26-2013, 12:43 PM   #2558
07imprezive
Member#: 251703
2007 impreza
satin white pearl
Lol dude I saw ur car in a magazine I purchased earlier this month, man your car is sexy!!!
07imprezive is offline
Old 03-26-2013, 12:56 PM   #2559
johnblahuta88
Member#: 221614
why in that video does it seem like the car is back firing as it revs up. or is it just the quality of the video
Old 03-26-2013, 01:18 PM   #2560
tito sti
Member#: 247648
Who is tuning it?
Thx bro ,Chris delgado from D3 enginiering
Thx man ,What magazine I didnt know
Tuck that video with my phone thats why it sound crazy
tito sti is offline
Old 03-26-2013, 04:55 PM   #2561
Rattsl
Member#: 340348
05 Stage 2 LGT
Aligned my exhaust and had the cut and welded in a better position.
Rattsl is offline
Old 03-26-2013, 05:31 PM   #2562
Imprezed04
Member#: 202396
2004 STi
Had Subaru do a complete check over the car, replaced a leaking steering box and installed the stage 2 map from my COBB AP. Will be headed to Texas soon!
Imprezed04 is offline
Old 03-26-2013, 05:36 PM   #2563
A11
Member#: 344888
2013 STI 5-Door
I saw my car and smiled
A11 is offline
Old 03-26-2013, 06:19 PM   #2564
Chuck2012
Member#: 324568
2005 Wrx Sti
Ordered samco radiator hoses and front&rear shifter bushings.
Chuck2012 is offline
Old 03-27-2013, 09:12 PM   #2565
alkorahil
Member#: 284025
2006 Impreza WRX STI
playing catch up here. I am such a procrastinator!
LATERAL LINK REPLACE/INSTALL - March 16 2013
I had two bent lateral links. My rear would not align perfect so I finally broke down and decided to replace them. I went with the STi lateral link kit with pillowball bushings. Subaru P/N B0250-SA001
Ordered them and got them in, I love instructions in Japanese.
I did a read though of the FSM on replacing them and then while doing a visual inspection of all parts involved prior to install started to look at the bolt heads - they were fairly rounded out from them being adjusted so many times over the years, so I then decided to 'do it right' and ordered all new bolts and nuts. Wait for following weekend-Took the car up to the shop and went to work.
The FSM states to remove the rear axles from the differential because the CV boot is in the way of two of the camber bolts using special tool XYZ- You dont need to do this.
I got the bolts in and out no problem just had to work and think though it properly.
Remove both the wheels, then remove the long outer bolts first and allow the links to fall down. Using a jack stand flex the control arm back up a few inches, this will change the orientation of the drive axle enough to pull the bolt out from between the inner CV boot.
Installation is simple...just the reverse.
I did this with a lift at the shop, only took an hour and a half but I work slow and methodically on my vehicle.
Here are the old pieces and the bend links I removed.
Before I put the front wheels back on I decided to check the balance on all my wheels since I had been a naughty boy and not done it in awhile, I had no balance problems I could feel but decided why not while I am here and have time and already have the rear tires off. Tire pressure was good as well. All of them just 1 pound low, so that was nice since the last time I had checked the tire pressure was early December 2012.
I then put the car on the alignment rack to get it all into specs. Got the car up and did the initial readings withthe alignment machine.
Fifteen minutes or so later I had all the specs all at 0.0 or 0.1 and all green. I was happy and looking forward to taking it for a test drive with it properly aligned.
While I had it up on the lift I also replaced all the sagging exhaust hangers with pretty blue poly ones. that took longer than the links....with all the grease I could find they were very tight going on.
I also ordered and installed the Impreza trunk net. Took 10 minutes. Fits nice. Subaru P/N F5510-FS000
alkorahil is offline
Old 03-27-2013, 09:50 PM   #2566
backslider
Member#: 43196
1999 STi Type R
Still stripping down the gc....
Old 03-27-2013, 10:04 PM   #2567
johnblahuta88
Member#: 221614
So I am going to plasti dip my car has anyone done this and give me some advice.
Old 03-27-2013, 10:11 PM   #2568
iconone
Member#: 174883
135i 05 CGM WRX
2006 Yamaha R1
^ Look up plasti dips channel on YouTube. Tons of vids with good tips and info.
iconone is offline
Old 03-27-2013, 10:12 PM   #2569
SWP is Sexy
Member#: 302389
2011 WRX
I'm a stormtrooper pewpew
If youre in the Houston area check out DipTex
SWP is Sexy is offline
Old 03-27-2013, 10:27 PM   #2570
johnblahuta88
Member#: 221614
im going to buy a14 ounce can and use my gravity fed air sprayer and try it this weekend. I hope it comes out ok
Old 03-27-2013, 10:37 PM   #2571
iconone
Member#: 174883
135i 05 CGM WRX
2006 Yamaha R1
You are going to need way more that that. About 3 gallons from what i have seen.
iconone is offline
Old 03-28-2013, 12:48 AM   #2572
Rattsl
Member#: 340348
05 Stage 2 LGT
Drove around and went to Sonic....
...not even an exciting day considering I thought about washing it, until I looked at the weather.
Rattsl is offline
Old 03-28-2013, 06:21 AM   #2573
johnblahuta88
Member#: 221614
well I am just doing the trunk for now
Old 03-28-2013, 07:06 PM   #2574
Damned_Yankee
Member#: 278251
2008 WRX
I fixed a charge pipe issue. Also since I already had my tools out I went to troubleshoot the reason behind the P0301 code to no avail. Everything checked out fine and now I'm confused.
Damned_Yankee is offline
Old 03-28-2013, 07:11 PM   #2575
johnblahuta88
Member#: 221614
raced a white civic that was putting 180hp to the wheels. smoked him from a 65 roll and I was economy mode lol. he wouldnt race me from a stop. only pushed it to 80 and I was 2 cars ahead of him. It didbt have a exhaust and sounded really ricey
Closed Thread
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 03:08 AM
What did you do to your subie today?! 07imprezadrifter General Community 277 06-14-2009 11:42 PM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 12:02 PM
