![]() Texas Impreza Club Forum sponsored by Gillman Subaru Houston and Gillman Subaru San Antonio |
#26 |
Member#: 263961
TXIC
Vehicle:06 wrx sti wrb |
I've been talking to turn in concepts about blacks or yellows and have been torn between the two.. Curious to see how she sits!!!
#27 |
Member#: 306289
TXIC
Vehicle:1995 impreza-L AWD red but will be white |
took off all the trim, filled and sanded all holes and dings....bought some clear base and hardener....i went ahead and got a gallon of house of color candy blue and clear......and saturday im buying a wrx sti wing and throwing it on there and get it painted sunday.....but i plan on running a 20g turbo with a front mount intercooler and a k&n apollo 13 intake system....its going to be killer......should also be gettting new tires soon for the summer from the grand parents!
#28 |
Member#: 142325
TXIC
Vehicle:2002 WRX Wagon MBP |
I installed my v-limited s204 front lip on my 02 wrx wagon
![]() ![]() Last edited by m0nkey; 02-25-2012 at 04:42 AM. |
#29 |
Member#: 238230
TXIC
Vehicle:93 impreza L wagon junkyard camo |
changed my sparkplugs.
riddle me this, hotter plug better performance or colder plug better performance? |
#30 |
Member#: 115986
TXIC
Vehicle:2004 WRX Aspen White |
changed from Hawk HP Plus pads back to normal daily pads on the 6/4 stoptechs ----- on my z
Subie needs rear wheelbearings replaced and throwout - anyone done the rear wheel bearings on an 04 before? is it as easy as taking them in and getting them pressed out/in? ![]() chrz |
#31 |
Member#: 204121
TXIC
Vehicle:2005 WRX Wagon CGM |
Attempted to install fender braces on the wagon. I'll try a 14mm straight ratchet next time otherwise the fender is coming off. That top right bolt makes me
#32 |
Member#: 43196
TXIC
Vehicle:1998 2.5 RsT 93GF 95GC 02GD 01SF-T |
Angela blacked out my headlights for me while I was at work!!
From ![]() To ![]() |
#33 |
Member#: 238230
TXIC
added more to the list of need to get replaced:
ballpoints, pass. axle AWD conversion lowering springs GET MORE BACK PRESSURE! fix shifter bushings. |
#34 | |
Member#: 216472
TXIC
Vehicle:'05 Legacy GT Wagon 95 WRX/L |
#35 |
Member#: 238230
TXIC
got the exhaust shop around my corner to weld up my apexi axle back. sounds good, and there is a noticeable difference in how it runs.
#36 |
Member#: 224322
Vehicle:2013 Scion FR-S 10 Fxt Limited. DGM |
Cleaned interior, and dirtied up the exterior.
You know how it is. |
#37 |
Member#: 93798
TXIC
Vehicle:2005 WRX Hybrid Crystal Grey Mettalic |
#38 |
Member#: 130223
TXIC
Vehicle:05 9-2x Aero Blk, 2.5i Silver, 01 altima |
removed 200lbs of junk in the trunk. back to handling normally
#39 |
Member#: 127704
TXIC
Vehicle:2013 Leggy Scooby no4 - huntin for 5 |
Filled the WRX on E85 for the first time and got it dialed in 4 flashes, now gotta get a new intake (on way from Spider pig) and new injectors... 19psi at redline 11:5.1 = 100% duty, ouch, but power sliding a 10 YO wagon when boost hits rocks.
Backslider - your car is SEX |
#40 |
Member#: 142325
TXIC
Just broke my polyurethane front lip driving up my drive way. I had it for one full day
#41 |
Member#: 306227
TXIC
Vehicle:1999 Dubya Rawr Rex pu$$y pink |
a friend helped me put in a invidia Bellmouth downpipe and a Grimmspeed Boost control and then we bricked the ecu flashing a map. Oh well will be up and running mid next week.
#42 |
Member#: 296043
TXIC
Vehicle:02 WRX White |
Turbo inlet, wasn't as bad as I expected. Took 2 hours and wasn't to terrible. Everything I heard made it sound like a giant pain.
Better response and the extra noise is a big plus, I love hearing my turbo |
#43 |
Member#: 224322
Adjusted hella horns and mounting, plugged a few plastic areas with new replacement rivets, remounted front bumper, cleaned air filter and cleaned engine bay out a little...
On the 08fxt. Nothing special, things were just loose from previous owner. I'm guessing small front end collision. Gonna order parts this afternoon for the 08 and maybe order some for the 2010 fxt. |
#44 |
Member#: 302855
TXIC
Vehicle:2008 WRX DGM/CF |
Cleaned the crap out of it and installed sti rear seats. Ready for IFO tomorrow.
#45 |
Member#: 224233
TXIC
Vehicle:2007 STi "Sally" Blk |
Cleaned out the interior. Attempted to vacuum but STi carpet doesn't vacuum well. Waxed inside of doors & such.
#46 |
Member#: 166085
TXIC
Vehicle:2010 STI OBP S.E. 05 FXT Stg.3|06 LGT Stg.2 |
Installed Whiteline Steering Rack Bushings in the FXT.
#47 |
Member#: 216472
TXIC
Did a compression test on the legacy and did spark plugs numbers were all good. Did spark plugs and downpipe on the GC yesterday as well
#48 |
Member#: 248642
Vehicle:2008 STI Aspen |
Reflashed ECU to stock.....only to get a CEL. Troubleshot and ordered a new O2 sensor.....only to find out that I had the Innovative Motorsports LM-1 hard wired into my car.....
Flashed back to stage 2 and trying to find an inspector with old software.... |
#49 |
Member#: 23556
TXIC
Vehicle:04 WRX STi Java Black Pearl |
Spent yesterday afternoon going through the front brakes cleaning, re-applying some caliper grease, and just checking the pad level since they seem to have lasted forever! (Pagid pads.) Also finally had time to just simply wash the car. Then of course, it barely sprinkled today, so I wiped it back down this evening. Took a few pics. (And yes, I'm back on stock springs and struts until I decide what's next after having just sold my KW V3s.) Not looking too bad for an '04 STi I've had since new and now with 91,500 miles! Replaced the radiator with a Koyo a couple weeks ago. A couple projects coming up though...timing belt service with valve cover gaskets and then the clutch. Still on the original clutch. It slipped for the first time the other day in 6th gear at full throttle on the highway. Not really looking forward to either of those projects!
#50 |
Member#: 115454
TXIC
Vehicle:My PSM WRX Wagon shall rise again. |
I paid my car off a week ago, and I received my title today. I OWN IT.
| Thread Tools | |
| Display Modes | |
| what did you do to your car today? | Schrecken | Bay Area Impreza Club Forum -- BAIC | 11 | 09-25-2012 03:08 AM |
| What did you do to your subie today?! | 07imprezadrifter | General Community | 277 | 06-14-2009 11:42 PM |
| What did you do to your Scoob today? | Sheehan | North West Impreza Club Forum -- NWIC | 27 | 11-23-2007 12:02 PM |
