Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Closed Thread
Old 08-31-2012, 04:37 PM   #1151
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Originally Posted by Kastley85891 View Post
Thanks ;-)
FP TD06 20G 8Cm on smelly juice
Sorry to Hijack, but your spool impresses the chit out of me. Any idea how much it would change with pump gas? (93 octane)
Subian is offline
Old 08-31-2012, 05:54 PM   #1152
HonduHunter
Member#: 28408
2002 vf48ed WRX
If its not a lot this may be the way to go.
Otherwise a 16/18g...
HonduHunter is offline
Old 08-31-2012, 06:42 PM   #1153
RudeBoi0427
Member#: 323934
2012 WRX Premium
Just installed my KB STS. Loving it.
RudeBoi0427 is offline
Old 08-31-2012, 07:51 PM   #1154
OneBadPig
Member#: 181858
2016 WRXcwp,04WRXsrr
15Outbacktungstenmtallica
Paid it off
OneBadPig is offline
Old 08-31-2012, 08:18 PM   #1155
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
From my own vehicle stand point TBH not a lot, if I get time here shortly Ill convert to 93 and check
16G on this set up had full spool at 32-3400 (22 psi +) 20G is fun though up top and keeps the V8's wondering what the **** just flew away
18G will be soon if plans fall in place.
Kastley85891 is offline
Old 08-31-2012, 08:28 PM   #1156
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Originally Posted by OneBadPig View Post
Paid it off
Awesomeness
Old 08-31-2012, 08:58 PM   #1157
Excision
Member#: 294622
2007 STI - WRB
Perrin GTX3076r, Slow
Originally Posted by 8thWonder View Post
Loaded her up and hit the road to Nashville. Goodbye Texas, I'll miss you guys.
Goodbye fellow subie owner. have a safe trip
Excision is offline
Old 08-31-2012, 09:38 PM   #1158
HonduHunter
Member#: 28408
2002 vf48ed WRX
So you'll be downsizing a bit??
Old 08-31-2012, 09:47 PM   #1159
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Not really, I want to run an 18GXT as have not run an 18G yet, the XT is a better turbo then the current 20G although 20G's are really bargain power!
I want to see how fast I can get it to spool, I want to see how much TRQ I can get from the 2.0
If I can get full boost <3600 from an XT and load the timing curve safely it will be an awesome street machine - Ill probably run a good amount of timing up top and shoot for 22psi up top with 25 psi peak
Old 08-31-2012, 11:56 PM   #1160
HonduHunter
Member#: 28408
2002 vf48ed WRX
That's gonna be an awesome build... What injectors are you running?
Old 09-01-2012, 12:13 AM   #1161
Pencils
Member#: 152726
The 2003 pwrFAP
thing
hacked up an 04/05 bumper beam to fit my bugeye with a fmic
Pencils is offline
Old 09-01-2012, 12:25 AM   #1162
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
IDC 1000's currently on a standard WALBRO 255 and stock fuel rails. Idle at 700rpm and drive like stockers, 82% duty on E
Id recommend them for sure
Old 09-01-2012, 12:26 AM   #1163
Chuck2012
Member#: 324568
2005 Wrx Sti
New subwoofer box. Trying out sealed until I get a bigger amp. Then maybe if I get ports calculated right I port it and finish gluing everything then maybe rhino line it.
Chuck2012 is offline
Old 09-01-2012, 07:34 PM   #1164
Likeorasgod
Member#: 247465
2008 WRX
Satin White Pearl
Went from these
To these
When I pulled into the apartment complex I scrapped the rears on the fender, looks like I'm going have to get my finders rolled.
Likeorasgod is offline
Old 09-01-2012, 08:31 PM   #1165
Damned_Yankee
Member#: 278251
2008 WRX
Originally Posted by Likeorasgod
Went from these
To these
What's offset are you running?
Damned_Yankee is offline
Old 09-01-2012, 08:33 PM   #1166
Likeorasgod
Member#: 247465
2008 WRX
Satin White Pearl
Enkei RPF1 18x9.5 +38 5x100
I haven't been back out side to better inspect it since I got home cause I'm getting things ready to go out of town to Lousiana tomorrow for work. The old rims where 18 x 8 45 and I didn't have any problems with them, but I hard the scrap and notice a white line on the rubber when I parked.
Old 09-01-2012, 09:11 PM   #1167
Damned_Yankee
Member#: 278251
2008 WRX
Hmm. Maybe go to a lower aspect ratio. I'm running 17x9.5 +30 no rolling and no rubbing.
Old 09-01-2012, 09:21 PM   #1168
atomicfire
Member#: 136296
2005 STi
bolted the new pressure plate, clutch, and flywheel to the engine, put the engine in the engine bay, bolted it up to the tranny, installed the starter, then realized I needed to put the plug in for the clutch fork pivot. FML. Time to stop today.
atomicfire is offline
Old 09-01-2012, 10:58 PM   #1169
twistedskillz
Member#: 315596
So i aint said much since had car so far ive got rid sti wing am full cf trunk wingless i add is nice...dis that few months ago...last week i just put on coil over changed tores and rimms...front lip kit...wensday i put stage 2 clutch in with light weight fly wheel bye clutch masters....and friday i ordered everything for e-85 pump lines rails injectors stainless lines yup and also for got mention i picked up aem ecu...just figure i update every one and say hi
twistedskillz is offline
Old 09-02-2012, 12:10 AM   #1170
TOI
Member#: 238230
98 impreza sedan
i day dreamed about a small block V8 lifing under the hood of my wagon. does that count?
TOI is offline
Old 09-02-2012, 01:49 AM   #1171
aggie113
Member#: 146311
Saab '05 HTA68 Built
2.5L E85 6MT > STI :)
Another trip to Lubbock for another two weeks worth of e85. Also got stopped by Tx DPS for no front plate, stupid no-purpose warnings.
aggie113 is offline
Old 09-02-2012, 04:32 AM   #1172
Jester808
Member#: 166085
1990 Skyline GTR
Jet Silver Metallic
Installed Tanabe Sustec Pro Five Coilovers in the GRB STI...
Jester808 is offline
Old 09-02-2012, 12:44 PM   #1173
atartol
Member#: 321926
2007 STI Limited #22
UGM
Tried this last night, rushed to see how it would turn out, not everyone's style but for some reason I really like it. Redoing in two weeks and will actually take my time doing it.
Here's the book I used:
Amazon.com: Stickerbomb 2 (9781856696623): Studio Rarekwai: BooksAmazon.com: Stickerbomb 2 (9781856696623): Studio Rarekwai: Books
atartol is offline
Old 09-02-2012, 01:17 PM   #1174
2006 crystalblue sti
Member#: 263961
06 wrx sti
wrb
Love how it says tits at the back by the shifter! Win!!
2006 crystalblue sti is offline
Old 09-02-2012, 02:59 PM   #1175
m_clark54
Member#: 224322
2013 WRX Spec Ed
Tangerine Orange
I've never owned that many stickers to try that out, but have always appreciated the artwork.
m_clark54 is offline
Closed Thread
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 03:08 AM
What did you do to your subie today?! 07imprezadrifter General Community 277 06-14-2009 11:42 PM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 12:02 PM
