Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Closed Thread
Old 10-25-2012, 06:09 PM   #1501
Dougwitt92
Member#: 310390
2014 Hatchback STi
Cobb adjustable short shifter. Way nicer
Dougwitt92 is offline
Old 10-25-2012, 09:20 PM   #1502
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Smacked off 218 miles to half a tank - awesome
Kastley85891 is offline
Old 10-26-2012, 01:17 AM   #1503
TOI
Member#: 238230
98 impreza sedan
primed more of the wagon, bought some jdm gf8 skirts with aero guards, and a sandwhich adapter for future turbo fun.
TOI is offline
Old 10-27-2012, 02:07 PM   #1504
mrardente
Member#: 288778
2013 STI
Invidia downpipe and whiteline rear sway last night. Today is time to get clean!
mrardente is offline
Old 10-27-2012, 03:40 PM   #1505
ptr149
Member#: 330952
2005 STI
Just installed a TWM short shifter, the shifts are soo much shorter and more precise. Definitely worth it
ptr149 is online now
Old 10-28-2012, 05:02 PM   #1506
TOI
Member#: 238230
98 impreza sedan
i think i'm gong to go RWD with a welded rear diff or vlsd...
TOI is offline
Old 10-28-2012, 10:21 PM   #1507
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
I don't even get that with a full tank and a two gallon surge tank!!
shilohb is offline
Old 10-28-2012, 11:00 PM   #1508
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Ive been there dude, my worst was 85 miles on a tank...
DD time, currently 365 miles with over a quarter to go ;-) its paying for itself for sure
Old 10-28-2012, 11:13 PM   #1509
93GC8AWD
Member#: 245268
1993 Impreza L Wagon
Boooooo, Shiloh, talk him out of it
93GC8AWD is offline
Old 10-28-2012, 11:37 PM   #1510
TOI
Member#: 238230
98 impreza sedan
the trans has blown syncros, plus i plan on a USDM wrx swap later down the line. and do i need more reason then because racecar?
TOI is offline
Old 10-28-2012, 11:44 PM   #1511
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
22mm sway? how is it post fit?
I personally like Whiteline, mine is on route ;-) did u do end links also?
Old 10-29-2012, 12:54 AM   #1512
Ptown_finezT
Member#: 308190
2012 wrx hatch
dgm,2010 swp legacy prem.
Installed catless downpipe and installed smy cluster and aem wideband,tired ass hell,thanks for the help magnum.
Ptown_finezT is offline
Old 10-29-2012, 03:37 PM   #1513
05subysti
Member#: 268190
2005 STi
Removed front end. Pulled motor, put on stand. Reinstalled front end.
Now in process of tearing down motor to check condition.
Have slightly lower compression in cyl 4 and fail leak down test.
05subysti is offline
Old 10-30-2012, 12:09 AM   #1514
Br0wnb0y
Member#: 109147
2005 LGT Not
BSM
I borrowed tape from our shipping dept and taped the center of my front lip to my bumper.
Br0wnb0y is offline
Old 10-30-2012, 12:12 AM   #1515
HonduHunter
Member#: 28408
2002 vf48ed WRX
Not at all. Should have mentioned this sooner. Lol
HonduHunter is offline
Old 10-30-2012, 01:11 AM   #1516
93GC8AWD
Member#: 245268
Pulled mine a few weeks ago. Yesterday and today Wagaru and I tore it apart. Headed to machine shop Monday. #3 cylinder bearing and rod were toasty cakes.
93GC8AWD is offline
Old 10-30-2012, 01:41 AM   #1517
Excision
Member#: 294622
2007 STI - WRB
Perrin GTX3076r, Slow
Attempted to bleed the brakes but for some reason brake fluid isn't squirting out of the bleeding nipple on all four calipers. does any know what it can be?
*2006 WRX Limited 4 Pot Breaks*
1: the brake reservoir thing is filled all the way up with brake fluid
2: i Bled in this pattern about 5 times and the pedal is still spongy and no brake fluid comes out. Passenger Front, Driver Rear, Driver Front, Passenger Front.
3: i bought a new brake master cylinder
any help would be very much appreciated. Thanks
Excision is offline
Old 10-30-2012, 01:49 AM   #1518
93GC8AWD
Member#: 245268
Longest lines first. So find where your abs module is
93GC8AWD is offline
Old 10-30-2012, 03:46 AM   #1519
Wagaru
Member#: 169297
1996 Impreza Coupe
96 LSi Sedan/97 Outback
Put a wrx muffler on my coupe. Noticeable difference in top end power and sounds nice and bass-y. Stock muffler was the same one they use on the 1.8. The wrx muffler was almost bolt on. I had to modify my stock mid pipe just a little and one hanger isn't used. It sits a little off level but overall is a kick ass free upgrade. I am equal length so I cannot upgrade to a can style yet because it will just sound like a Honda...
Wagaru is offline
Old 10-30-2012, 09:25 AM   #1520
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
Bought an 'OEM' decklid spoiler and attempted to fit, opened it to find its actually a knock off and didnt even have a template, already sent back via RMA, why do suppliers attempt to miss inform? pisses me off.
Old 10-30-2012, 10:05 AM   #1521
mrardente
Member#: 288778
2013 STI
Yup, its 22mm with the braces. Haven't really been able to tell much of a difference yet mainly because I haven't gotten on it much. When I was doing the install I noticed how flimsy the stock endlinks looked and made me want to upgrade. I had a $200 credit to whiteline so I ended up not getting them but I will upgrade the first chance I get. Install went much easier than I expected so that was nice.
Old 10-30-2012, 10:54 AM   #1522
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
If they are 4-pot/2-pot (aka fixed calipers) brakes then there will be a bleed screw on the inside and outside of the caliper (one for each 'pot'). You have to bleed them both, first bleed the inside pot, then othe outside pot...sounds like you got some air dragged back into the system as you were bleeding them.
Squidz is offline
Old 10-30-2012, 11:14 AM   #1523
Smokin' Joe
Member#: 219679
2011 Impreza WRX
Oil/filter change and a bath today. Some major underbody washing and regreasing after that. Air filters are getting swapped as well.
Smokin' Joe is offline
Old 10-30-2012, 12:29 PM   #1524
Wagaru
Member#: 169297
1996 Impreza Coupe
don't be offended but are you trying to do this by yourself or is someone else pumping?
Wagaru is offline
Old 10-30-2012, 12:33 PM   #1525
backslider
Member#: 43196
1999 STi Type R
93GF 95GC 02GD 01SF-T
Ummm, what about passenger rear???
Also, I have to ask the obvious, but do you know how to bleed brakes?
backslider is online now
Closed Thread
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 04:08 AM
What did you do to your subie today?! 07imprezadrifter General Community 277 06-15-2009 12:42 AM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 01:02 PM
