Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Texas Impreza Club
Go Back   NASIOC > NASIOC Chapters > Texas Impreza Club Forum -- TXIC
Closed Thread
Old 11-01-2012, 08:29 AM   #1551
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
Originally Posted by Excision View Post
no, the fluid level remains the same. ill try the gravity thing today. thanks for you help man
Sorry about the two bleed screws advice...i just saw four-pot and figured they were aftermarket...guess i should read.
You certainly have something going on that's not right...You said that you took the bleeder screw out and no fluid came out, even when you pushed the pedal, that's really strange.
Could be a bad master cylinder...if the primary circuit fails in there it could cause brake dragging if the piston does not return all the way back to the first position. This would cause the right front and left rear to drag (i'm pretty sure the primary circuit in that year car was right front/left rear)
Could also be that you're not getting pressure past your ABS module. Never seen anyone bleed the system with the engine running. It may have gotten some pressure inside the BAS unit where it shouldn't be.
Have you tried bleeding it without the car on? Same results?
Squidz is online now
Old 11-01-2012, 11:04 AM   #1552
wcflush
Member#: 336708
2009 WRX
about to go get a detail and an oil change. Been too long....
wcflush is offline
Old 11-01-2012, 01:22 PM   #1553
TOI
Member#: 238230
98 impreza sedan
mocked up my hella hot JDM GF8 skirts
TOI is offline
Old 11-01-2012, 04:26 PM   #1554
sars101
Member#: 280420
2005 2.5 rs
silver ish
turned my black stock belt moldings to stock chrome belt moldings
sars101 is offline
Old 11-01-2012, 06:08 PM   #1555
alkorahil
Member#: 284025
2006 Impreza WRX STI
Originally Posted by TOI View Post
got closer to painting the wagon, the driver side is all ready for paint!
But that paint scheme it has is classic!
Gives it character!
alkorahil is offline
Old 11-01-2012, 06:09 PM   #1556
alkorahil
Member#: 284025
Installed a Mishimoto Ancillary Hose Kit last night.
Old 11-01-2012, 10:24 PM   #1557
TOI
Member#: 238230
98 impreza sedan
Gives it character!
it was repainted, improperly... i'm sticking with subaru colors code 30 for those that get all hot and bothered by subaru technical terms. or aspen white for you boring folks. it'll be white with unpainted trim, skirts, lips, aeroguards spats etc etc. oh yea i finally did my DIY garden edge lip, and it looks pretty good.
TOI is offline
Old 11-01-2012, 10:33 PM   #1558
05subysti
Member#: 268190
2005 STi
Disassembled my rods from crank shaft.
Removed arp studs from case halves.
Also let my mahle pistons soak in purple power to clean off the carbon on them.
Welp I hope I get a job soon so I can start saving and buying parts to rebuild.
05subysti is offline
Old 11-02-2012, 01:40 AM   #1559
TOI
Member#: 238230
98 impreza sedan
oh and a flat black hood cause i just got done painting it...
TOI is offline
Old 11-02-2012, 09:27 AM   #1560
backslider
Member#: 43196
1999 STi Type R
93GF 95GC 02GD 01SF-T
Getting ready to put this in, still lacking a passenger side bracket.
backslider is offline
Old 11-02-2012, 12:38 PM   #1561
Squidz
Member#: 142608
2003 Sonic Yellow
Awesome freaking intercooler man!
We're running them on both of our cars and have loved them.
Old 11-02-2012, 02:09 PM   #1562
Subie2.5i
Member#: 216472
'05 Legacy GT Wagon
95 WRX/L
Pulled out the vf46 getting ready for the new pnp vf52 to go in this weekend then a tune on Tuesday
Subie2.5i is offline
Old 11-02-2012, 03:07 PM   #1563
Excision
Member#: 294622
2007 STI - WRB
Perrin GTX3076r, Slow
eww. why??
Excision is offline
Old 11-03-2012, 12:34 AM   #1564
8thWonder
Member#: 230366
2005 STi
it's motor buildin' time!
Washed it, and continued fighting with my power steering. I need some help here.
Somehow, air is getting into my steering system. I've replaced the pump, replaced every old clamp with a new screw-type clamp, and bled the system like 5 times. I also replaced the crush washer and the o-ring at the top of the pump. If I get under the car and move the wheels by hand, I can hear the fluid sloshing around in the rack, like air is being forced into it. Could air be getting in through the rack somehow (seals)? Running out of options.
8thWonder is offline
Old 11-03-2012, 09:56 AM   #1565
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
It seems like I remember one of your lines running from the tank to the pump was swelling...and bleeding a little
If it is not a line made just for transmission fluid it will swell and pass fluid and air
I had to get line from a local shop that makes hydraulic lines
The only line that autozone,napa,orileys had in the massive 5/8 was a red line.... and I didn't want that
shilohb is offline
Old 11-03-2012, 07:59 PM   #1566
BugeyeGroceryGetter
Member#: 225067
2004 Forester XT
Platinum Silver Metallic
Today I took the snorkus off my Forester and realized that the dealership that I bought my car from never installed an air filter. My car always sounded more aggressive and I had thought that maybe the previous owner had already done the snorkus mod. After I took the snorkus off I went to Auto Zone and bought an air filter. After all was said and done my car sounds the same as before, and feels the same. So maybe the two things cancelled each other out, but it should run better now.
BugeyeGroceryGetter is offline
Old 11-03-2012, 09:50 PM   #1567
aggie113
Member#: 146311
Saab '05 HTA68 Built
2.5L E85 6MT > STI :)
Cleaned crude off the battery terminal with lots of baking soda and water. Hopefully the petroleum jelly will keep it at bay, otherwise Redtop waiting in the wings.
aggie113 is offline
Old 11-04-2012, 11:01 PM   #1568
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
raced the **** out of the bugeye today...toasted a rotor. got to pay to play.
scby rex is offline
Old 11-04-2012, 11:19 PM   #1569
TOI
Member#: 238230
98 impreza sedan
in before ban! haha
TOI is offline
Old 11-05-2012, 12:56 AM   #1570
05subysti
Member#: 268190
2005 STi
Painted my valve covers and baked them for 1 hr @ 250 degrees.
Came out decent for spray paint lol
Old 11-05-2012, 03:03 PM   #1571
Kastley85891
Member#: 127704
2015 Boosted Stang
MAP tuned
^Likey
Washed my DD after 600 miles
Kastley85891 is offline
Old 11-05-2012, 03:13 PM   #1572
8thWonder
Member#: 230366
2005 STi
Did you change the fittings on the Mishimoto reservoir? The thread pitch on them is M12x1.0" but I can't seem to find any adapter from that size to the correct hose size. I think the Mishimoto outlets are 1/2" but our hoses are 5/8" and 3/8".
Old 11-05-2012, 04:47 PM   #1573
m0nkey
Member#: 142325
2002 WRX Wagon
MBP
Got my STI key cut at gillman for $10 and yes thats a turbo keychain hahahha
m0nkey is offline
Old 11-05-2012, 05:42 PM   #1574
scby rex
Member#: 104878
02 wrxbastardchild
10$ to cut a key?? what a ****ing rip off!
scby rex is offline
Old 11-05-2012, 05:45 PM   #1575
m0nkey
Member#: 142325
2002 WRX Wagon
MBP
I went to home depot and they said that they could not cut it. Than I realized that maybe homdepot or any other hardware store was not the place to go cut a $20 key.
m0nkey is offline
Closed Thread
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 03:08 AM
What did you do to your subie today?! 07imprezadrifter General Community 277 06-14-2009 11:42 PM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 12:02 PM
