Welcome to the North American Subaru Impreza Owners Club Sunday September 21, 2014
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 02-20-2012, 09:34 AM   #1
KillerBMotorsport
Vendor Sales Rating: (43)
Member#: 198281
2005 WRX/STi
WRB of course
Default Killer B Motorsport WRX / STi HOLY HEADER
Killer B Motorsport WRX / STi HOLY HEADER - Patent Pending
The Killer B Motorsport Holy Header was developed using state of the art CAD software & simulations to determine optimal design to increase power in the mid to high RPM range. Short as possible primaries with a single secondary significantly decrease header volume allowing exhaust gas pressure to build quickly. Symmetrical 4-1 design maintains high and consistent exhaust velocity as RPMs rise. You can expect faster spool up time compared to long primary/double secondary designs. A difference you will immediately notice in throttle response and the ability to hold more power higher into the revs.
Features include:
Short Equal Length Primaries. The shortest possible length primaries you can have on an Equal Length header. Short means less header volume and quick spool up.
Symmetrical Primary Design. All primaries have a similar tube length AND bend geometry. This keeps the pulse velocities high and consistent compared to equal length headers with different (non-symmetrical) primary tubing geometry.
Smooth Mandrel Bends. All of the bends utilize a mandrel for smooth non-restrictive flow. Not only that, we use the largest bends possible at every location. It would be cheaper to use 2” bends everywhere, like others do, but that’s not going to give the best performance.
Thick Walled 321 Stainless Steel Construction for Long Life. 321 is alloyed with titanium, costs more, a lot more, but it’s the ideal material for high temperature turbocharged applications. Would 304 stainless work, yes, but the temperatures on our turbocharged cars can exceed the limits of 304 stainless enough to make them brittle and crack. 321 stainless steel has higher strength and toughness at elevated temperatures. It was developed by the aircraft industry specifically to address 304 stainless manifolds that were cracking. Killer B Motorsport is the only company that manufactures full 321 headers.
High Heat Retention. 321 stainless steel conducts less heat than 304 stainless steel. The short primaries and properly sized secondaries also pull less heat from the exhaust gasses increasing turbine efficiency. Large tubing headers expose the exhaust gasses to more surface area transmitting more heat and reducing exhaust energy. You can also ceramic coat or wrap our headers (and keep the warranty) without exceeding the temperature range like you can with 304 stainless.
V-Band Up-Pipe Connection. Why V-Band? Fast, easy, no gasket, no leaks, perfectly concentric alignment of tubes for no disruption of flow, what’s not to like!
Up-Pipe included. Of course it comes with an Up-Pipe! This header was designed as a complete system. Using other up-pipes would only compromise performance, and nobody wants that.
Weights only 16 pounds (vs. OEM weights 25 pounds)
Works with OEM EJ25 Oil Pans, and Killer B Motorsport Performance Aluminum Oil Pan!
Made in the USA and Killer B quality! Every Header setup is inspected, assembled and pressure tested before it ships to assure a leak free setup!
We now have Swain Tech Coating available as a pull down option. This is the ONLY coating we recommend due to its thermal capability, ability to protect the base material and durability.
Gaskets also available as a pull down option.
See website for independent shop reviews, dyno plots and video clips.
NASIOC members: Free Shipping - PM for details!
__________________
- Highly Advanced and Full of Awesomeness - Patent Pending
vs.
V2 High Performance Aluminum
Brushed & Polished Delrin Shift knobs!
KillerBMotorsport is online now
Old 04-10-2012, 01:01 PM   #2
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Back in stock in ~2 weeks
__________________
vs.
Old 04-10-2012, 10:37 PM   #3
Subie-Zilla
Member Sales Rating: (30)
Member#: 204267
2007 wrx
How much for the header ??
Subie-Zilla is offline
Old 04-17-2012, 09:36 AM   #4
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
PMs replied
New batch coming through soon and taking pre-orders.
__________________
vs.
Old 07-17-2012, 11:34 AM   #5
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Sold out! Demand for this product has exceeded our expectations! We are (again!) waiting of 321 material to be available from the mill. We are told ~8 more weeks
We'll be starting a list, and as always the shipping order will be first pay first ship.
Thanks guys for the orders and awesome feedback!
__________________
vs.
Old 07-31-2012, 07:23 AM   #6
Jumpy
Member Sales Rating: (1)
Member#: 48235
Pm on a price with the coating, please.
Jumpy is offline
Old 08-26-2012, 12:52 PM   #7
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Sorry for the delay. PM heading your way!
__________________
vs.
Old 08-27-2012, 08:29 AM   #8
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Back in stock, soon....
__________________
vs.
Old 09-10-2012, 12:54 PM   #9
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Anyone notice something different...
__________________
vs.
Old 09-10-2012, 07:50 PM   #10
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
here is another hint...
__________________
vs.
Old 09-10-2012, 10:18 PM   #11
Drewbie
Member Sales Rating: (5)
Member#: 309709
99 Rs coupe
Um... You build one in titanium? That what your hinting at?
Drewbie is offline
Old 09-10-2012, 11:00 PM   #12
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Yeowza that would be expensive! Nope, not titanium.
__________________
vs.
Old 09-10-2012, 11:51 PM   #13
fxt05
Member Sales Rating: (3)
Member#: 208521
'96 STI Type RA
'05 FXT
Less cutting and welding going into the collector. Do I win a free set? Nice header!
fxt05 is offline
Old 09-11-2012, 02:04 AM   #14
scoops04wrx
Member Sales Rating: (31)
Member#: 150966
04 WRX
Some very nice welds
scoops04wrx is offline
Old 09-11-2012, 07:53 AM   #15
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Correct! I wish we were rich enough to give stuff like this away
Thanks!
__________________
vs.
Old 09-13-2012, 08:55 AM   #16
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
I'll try to get a close-up weld shot today.
__________________
vs.
Old 09-16-2012, 02:12 PM   #17
manitou
Member Sales Rating: (25)
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Chris,
Nice job on the eliminating the separate collector, looks great! I do love my KBHH and the results it produced on my stock EJ255, VF48 & Tial MVR EWG. I am now working on the new motor install with Angel, MPS long rod 2.5 and D25 +1mm pnp heads, Kelford R199-B cams and Blouch 3.5XT-R. Hope fully it will be on break in tune in early October. I will keep you posted.
Ciao
manitou is offline
Old 09-17-2012, 12:42 PM   #18
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by manitou View Post
Chris,
Ciao
Thanks for the kind words!
Sounds like you are looking at quite a big step in power there my friend
Looking forward to seeing the results
__________________
vs.
Old 09-17-2012, 01:01 PM   #19
manitou
Member#: 193757
2006 XTI Limited
No problem! I love the quality of your product's. Besides the Holy Header, I am running the pan, pickup, windage tray and the Q-ball 6 speed shift knob, all most excellent stuff!
Yes sir, definitely a big jump in HP coming with the new motor build and turbo. Probably not gonna see much if any more torque than what the VF produced. 450 ft.lbs. at 3400 was pretty good. Looking forward to good results!
manitou is offline
Old 10-02-2012, 03:29 PM   #20
Chayse
Member#: 86617
2011 WRX STi
Dark Gray Metallic
What is the status on these units? I like the new Collector design. Are these in stock?
Chayse is offline
Old 10-02-2012, 10:40 PM   #21
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
In stock
__________________
vs.
Old 10-03-2012, 01:57 PM   #22
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Great job guys!!!
Originally Posted by BoostInc View Post
This is Vader.
Built at Boost Inc and tuned by Scotty at Motiva here in Abq, NM.
Here you go guys, please enjoy.
Sleeved Block with coated CP pistons, Carrilo rods w/ CARR bolts built by RS Machine
CNC heads w/ +1 Valves
Supertech Valvetrain w/ BC 280 Cams
Killer B Holy Header W/ Boost Inc custom up pipe and rotated set up
Garrett GTX3582R w/ Tial 1.06 SS hotside.
2 Aeromotive 340lph pumps with Full Blown duel top hat set up, -8 feed line
ID 2000cc injectors
AEM EMS
Custom FMIC piping w/ custom Bell huge intercooler
This graph is at 30 psi at 5400" elevation. Turbo is out of breath and had a hard time being efficient after 30 psi.
We had a 1.19 correction factor and i forget what we made uncorrected. Someone has other graphs and videos that im sure will be up shortly.
Any other questions please ask.
Thanks
Great job guys!!!
__________________
vs.
Old 10-03-2012, 02:26 PM   #23
manitou
Member#: 193757
2006 XTI Limited
Wow, that's impressive power and torque! Very quick spool for that big of a turbo, 300 ft. lbs.@ 4300 and 400 ft. lbs.@ 4550 and 500 ft. lbs.@ 4750 rpm's. That and the GTX3582 ran out of breath! That's a good testament to the efficiency of your headers Chris!
Here is a graph from a couple pulls from my stock EJ255, VF48 (baby turbo), Killer B Holy Header w/ custom stock location up pipe, Tial MVR EWG and all the supporting mods. I was very happy with the spool up and power that I made with your header, the EWG on my VF48. Not as much when the stock clutch let go
It's still quite a torque monster.
manitou is offline
Old 10-12-2012, 11:18 AM   #24
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Holy cow that's a lot of torque on a VF48!
__________________
vs.
Old 10-12-2012, 11:33 AM   #25
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Finally have some on the shelves
__________________
vs.
Closed Thread
Killer B 2003-07 WRX/STi Radiator Shroud AND Alternator Cover COMBO - $65 SHIPPED! KillerBMotorsport Vendor 'Group Buy' Classifieds 31 02-18-2012 01:08 AM
FS : P&L Motorsports WRX/STI Tial BoV with STi Flange urabus2 Engine/Power/Exhaust 4 09-20-2011 02:34 PM
WRX/STI Borla header for sale...$200 Camperguy New England Impreza Club Forum -- NESIC 2 09-27-2003 06:51 AM
