Old 02-20-2012, 02:55 PM   #1
yman
Member#: 199051
04 sti
psm
Default 02 Forester EJ205 WRX engine/bulkhead harness swap - Help/Advice/Guidance needed
I recently picked up a Forester after selling my STI and I absolutely love it. There are a couple of minor things that I wish I could change, but overall, this is one of those cars that I just loved from the first minute I drove it.
Currently, I'm in the middle of trying to get the parts together to install an EJ205. I've got a build thread going on my local chapter, but now that I'm coming up on actually doing the deed I've got more questions.
Here is the build thread
http://forums.nasioc.com/forums/show....php?t=2306123
And some questions I have:
Do I need to use the WRX a/c system?
Do I need to use the WRX radiator?
yman is offline   Reply With Quote
Old 02-23-2012, 12:34 AM   #2
yman
Member#: 199051
04 sti
psm
Bump. I'm trying to stay on track- after talking to iwire I have a little bit more confidence in this swap. Just curious about the little things like a/c, from looking at it I would guess that the a/c would work fine...same with the radiator. It is an aluminum one with slim fans I think.
Old 03-01-2012, 01:41 AM   #3
yman
Member#: 199051
04 sti
psm
Bump. Anyone know if I can use the stock forester heater core?
Old 04-01-2012, 04:05 AM   #4
huntingchen
Member#: 315321
i have a 02 wrx engine and trans, need a car to put it in. hoping your swap get going cuz i need help too lol
huntingchen is offline   Reply With Quote
Old 04-01-2012, 04:13 AM   #5
yman
Member#: 199051
04 sti
psm
It's going, I have a thread in the southwest region forum. Motor and wiring harness is going in tomorrow, subframe is in, merged harness is done, gonna have an issue using the wrx rack though.
Old 04-03-2012, 11:07 AM   #6
X Mon
Member#: 156443
2006 WRX Wagon WRB
2001 Forester S, EJ205/5m
What issue with the WRX rack? Which steering column are you using? Did you get the HVAC stuff sorted?
I'm running the Forester Dash, EDM STI Cluster with a custom cluster harness (made it from pieces of a WRX and Forester Harness from the junk yard) and the Forester HVAC stuff. The AC Compressor from the EJ251 in the Foz will bolt onto the EJ205 with some slight bracket modification.
Rack is STI, u-joint and column are WRX without the riser blocks in the trans crossmember or the engine subframe. Radiator is 04 WRX with custom top mounts.
X Mon is offline   Reply With Quote
Old 04-03-2012, 12:31 PM   #7
yman
Member#: 199051
04 sti
psm
My issue is that the column is SF forester like a gc rs, and has rough splines and needs the linkage modified. I didn't see that coming so the car is spending another week in the garage.
Got the interior HVAC stuff sorted, anxious to see what happens with the compressor. Did you grind the bracket down or what?
Old 04-03-2012, 02:33 PM   #8
X Mon
Member#: 156443
2006 WRX Wagon WRB
Band saw, CNC sand belter....
Old 04-04-2012, 09:35 PM   #9
az02wrx
Member#: 206463
1999 ej20tfozzy
you can use the forester radiator
mine is still running it and i haven't had any temp issues .
you can pick up a aftermarket gc8 rad . they use the same mounts
az02wrx is offline   Reply With Quote
02 wrx engine wiring harness help! AndrewCastellini Electrical & Lighting 1 02-06-2012 11:58 PM
'98 2.5RS with hybrid swap - help is urgently needed! tavarish Subaru Conversions 1 04-26-2010 08:56 PM
02 Dash 05 Gauges and bulkhead harness fantomas Interior/Dressup/Audio & Security 29 10-02-2009 05:33 PM
WTB: Engine Bulkhead Harness/cam sensor DrewDeezy Private 'Wanted' Classifieds 4 10-03-2008 04:57 PM
Bulkhead harness swap difficulty? BBBsti LTD Subaru Conversions 9 12-04-2007 04:07 PM
