Old 02-20-2012, 03:14 PM   #1
860go
Member#: 207795
2005 Wrx Sti
black on gold
Default 03wrx motor in 04 P1491 pcv problem
Hey guys, I recently installed a 03 wrx motor into a 04 wrx. I immediately got a p1491 code for pcv blowby sensor.
The 04 has a different pcv system that the new 03 motor isn't equipped with leaving the ecu confused. Are there any fixes to this problem that would get rid of my CEL? Thanks.
860go is offline   Reply With Quote
Old 02-20-2012, 03:15 PM   #2
darksc00by
Member#: 102140
2016 Herp Derping
Engineer For Hire, yo.
resistor in the sensor... you used the 04 WRX intake manifold right?
darksc00by is offline   Reply With Quote
Old 02-20-2012, 06:08 PM   #3
860go
Member#: 207795
2005 Wrx Sti
black on gold
No, I did a complete swap. I believe if I swap motor wiring harnesses and jump or use a resistor on the Pcv I should be all set. If not I'll have to source a 04 turbo inlet (my 04 came with a Perrin inlet) and install that along with the 04 manifold. Everything runs mint as is, but I did the swap to sell the car, and no one wants a CEl forever. Thanks for the reply
Old 02-21-2012, 12:13 PM   #4
darksc00by
Member#: 102140
2016 Herp Derping
yes you can use the inlet if you still have the sensor.
I have an 03 WRX inlet on my car, 04WRX ecu, I put a resistor in the harness.. reads the constant so no CEL... I hope.
Old 02-27-2012, 09:00 PM   #5
tom bauer
Member#: 310141
put a 1000 ohm 1/2 watt wire wound resistor in and let me know. how the pvc sensor works is still a mystery to me and i don't have an old one to disect. mine read 0 ohms as i recall.
tom bauer is offline   Reply With Quote
Old 12-03-2013, 12:46 AM   #6
ere99932
Member#: 375147
are there any instructions on how to use a resistor? i'm an absolute noob. my mechanic did the installation. what should i tell him to do?
he installed an 03 motor in my 04 wrx. i think he did a straight install. didn't use any parts at all from my 04...
ere99932 is offline   Reply With Quote
Old 12-04-2013, 11:30 AM   #7
KONKILR
Member#: 3190
2004 Impreza TS and
the Suxass racing mobile!
The PCV connector has a shorting connection on the Hose connection. Grab the terminals off the old inlet connector with pliers and removing the shorting bar. You could swap the old engine harness on the new (03) harness and just plug this shorting bar into the connector. DONE! Otherwise you will have to locate the wires for this connector in the main harness and short them together.
Jake
KONKILR is offline   Reply With Quote
blew motor in 04 wrx, install STI motor, ? mx207billy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-09-2009 09:11 PM
P1491 pcv and 1446 fuel pressure -please help!!!! n16ht5 Electrical & Lighting 1 08-11-2007 07:53 AM
06 STi Motor into and 04 STi, what problems will I run into? stillillmatic7 General Community 1 05-01-2007 06:52 PM
PCV Problem Joey_WRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 02-10-2005 06:28 PM
03 engine w/ 04 ECU in 04 WRX, lack of Blow By Sensor causing CEL? P1491 elhalisf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-18-2004 08:52 PM
