Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 02-20-2012, 03:37 PM   #1
BigRob74
Member#: 305107
2012 wrx
360/386 E85
Default can you datalog the factory map with the accessport?
i am about to pull the trigger on the accessport since all i read was how bad the factory maps are. does anyone have a log of stock vs stage 1?
BigRob74 is online now   Reply With Quote
Old 02-20-2012, 04:07 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
No you can't log the factory map with the AP, you need to marry the AP to the cars ECU which copies it and stores it, and then you load another map onto it from the AP... The closest is loading a stock like map that you can datalog...
wrxdrvr is offline   Reply With Quote
how often can you change real time maps with Cobb access port? dish5 Newbies & FAQs 5 09-21-2011 10:18 AM
Can you check valve lash / clearance with the heads unbolted? Bad Noodle Built Motor Discussion 15 04-08-2011 10:33 PM
Can you tune utec fuel map with negitive jhull UTEC 9 11-27-2007 08:12 PM
Can you do an ecu reset with the utec still plugged in? waitandbleed92 Engine Management & Tuning 4 03-31-2003 03:49 PM
Can I run TXS stg-2 map with the HKS DP? Mitsuby Engine Management & Tuning 14 01-23-2003 03:43 PM
