Old 02-20-2012, 05:49 PM   #1
Evans2point5RS
Member#: 310409
2005 2.5 RS
Question cam shaft sensor position?
I recently got my check engine light checked and the camshaft sensor is bad.
where is it located?
and how long should the repair take?
Evans2point5RS is offline   Reply With Quote
Old 03-21-2012, 07:27 PM   #2
bmxwannabepro
Member#: 302810
having exactly the same problem here
bmxwannabepro is offline   Reply With Quote
Old 03-24-2012, 12:12 PM   #3
Elbert Bass
Member#: 283429
Camshaft sensor is on the bank 2 head (drivers side). It is in the rear of the timing cover, bolted to the top outside corner of the head. The sensor bolts to a bracket, the bracket is bolted to the head and the bracket is aligned by fitting over a sleeved dowel.
Elbert Bass is offline   Reply With Quote
Old 04-04-2012, 10:13 AM   #4
gdogg16
Member#: 105304
2005 Legacy GT ltd
1998 V70T5M
I got a CEL this morning and then the car would no longer boost and is making a whirring noise. Pulled over, checked codes and got 4 bank A CPS codes and one o2 codes. No smoke etc out exhaust, so it doesn't seem as though the turbo is bad. Anyone have any idea what I'm dealing with here?
gdogg16 is offline   Reply With Quote
cam shaft position sensor ckb1985 Service & Maintenance 6 07-24-2008 07:20 PM
cam shaft sensor ?? pierce188 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-30-2007 12:11 AM
Cam Shaft Sensor Question marcus12 New England Impreza Club Forum -- NESIC 4 03-16-2004 11:47 PM
Cam Shaft Sensor help matt6669 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-05-2004 11:53 AM
cam shaft positioning sensor?????????? Harrison Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-23-2002 06:20 PM
