Old 03-20-2015, 08:24 PM   #1
cueballsi
Member#: 202736
2002 WRX- 6spd - MBP
1992 Civic VX 40MPG
Default Kamak twinscroll turbo not boosting pass 15psi
I installed a twin scroll kamak turbo, and it won't boost past 15psi. Ran the car straight with no boost solenoid still same. There is a 20lb spring in the actuator.
No boost leaks
We tested the actuator with an air compressor and it doesn't move till 20 psi.
The wastegate flapper does have some play, but it goes seem it is sealing...
Any ideas????
cueballsi is offline   Reply With Quote
Old 03-20-2015, 08:37 PM   #2
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
pre exhaust leak?
nate_fisher is offline   Reply With Quote
Old 03-20-2015, 11:30 PM   #3
04ScoobyWtf
Member#: 287974
04ScoobyWtf is offline   Reply With Quote
Old 03-22-2015, 12:22 AM   #4
binny
Member#: 198108
MY98 WRX
As above + do you have some preload on the waste gate ?
Sent from my iPhone using NASIOC
binny is online now   Reply With Quote
Old 03-28-2015, 01:23 PM   #5
cueballsi
Member#: 202736
1992 Civic VX 40MPG
The arm hd been preloaded as well.
Car seems to idle well and doesn't seems to be a pre-exhaust leak.
Old 04-08-2015, 12:02 AM   #6
cueballsi
Member#: 202736
1992 Civic VX 40MPG
Took the oem header off today, there was A small leak off the flange to the head. Resurfacing and putting it back on. I hope this solves the problem
