Old 02-20-2012, 06:17 PM   #1
guygettnby
Member#: 298231
2011 WRX
Default new log, possible issue.
car has been feeling abit sluggish, so i did a log. im running stage 1 +sf 93 on a 2011wrx and have been for awhile now. car felt stronger then just stage 1 when it was reflashed and went downhill from there.
only mods i have done right now would be the AP, SF intake w/box and turboXS catback. this log seems to have some knock and low boost levels. tell me what ya think of it.
https://docs.google.com/spreadsheet/...lo0ZWF5TEtuV3c#
guygettnby is offline   Reply With Quote
Old 02-20-2012, 06:22 PM   #2
renosubby
Member#: 152576
2009 GTR 10.7@ 133
Mayhem Tuning!!!!!
doesn't look to bad
renosubby is offline   Reply With Quote
Old 02-20-2012, 06:31 PM   #3
Cobb Tuning
Member#: 4803
Your boost levels seem a bit low, so it might be worth trying the HWG map. There is a correction at higher levels, but it is in the Fine Knock Learning. I would recommend doing an ECU reset and Reflashing a HWG map. Then, we can take a look at another log to see how your car is doing.
Ian
Old 02-21-2012, 08:06 AM   #4
guygettnby
Member#: 298231
2011 WRX
Ian
i was thinking about doing this. but wouldnt switching to the HWG map increase the chance for knock if it is already there? by increasuing the boost i would think that would increase the knock issue?
guess it wont hurt to make a few more log runs then switch over to the HWG map and see how it does. think i may check for boost leaks before i do though, just to make sure everything is ok.
thanks
Old 02-21-2012, 02:22 PM   #5
Cobb Tuning
Member#: 4803
The Fine Knock Learning is a correction that will default back to zero after an ECU reset. Otherwise, it will stay there until the ECU determines the correction is not needed anymore. Doing an ECU reset and then trying another log on the NWG map would be a better start, and then from there you can determine if you need the HWG map or not.
Ian
RomRaider Logging Data Issues FastHackem Engine Management & Tuning 5 04-07-2011 07:15 AM
Built motor. 30r. Logs and Issues. Nickcrsx Built Motor Discussion 9 08-26-2010 10:13 PM
New Log, Interesting results? dlh1999 Open Source Reflashes 7 06-07-2008 04:29 AM
Tweaked my map, new logs, thoughts? Overlord2kx Commercial ECU Reflashes 1 05-31-2007 08:54 AM
Log, boost issues..... rallytim888 AccessPort 8 07-26-2006 10:11 PM
