Old 02-20-2012, 08:54 PM   #1
newscoobboob
Member#: 119956
2006 wrx waggin
Lexus White w/ Pink pearl
Default 06 WRX having boost issues
i have posted on cobbforums and only had one response so i thought i would drop the link here and see if any of you could help me out, i have a 06 wrx wagon with Cobb SF Intake, Cobb Intake box, Cobb XLE By-Pass Valve, Invidia UP-PIPE, Invidia DP, Invidia G200. All catted.
And Cobb AccessPORT i just flashed Stage 2 ACN91 i live in Reno Nevada, i went for a few slow steady drives just getting used to my different suspension, and then i drove about 25 miles, having my gf watch target boost and boost. it was about 62 degrees and i was hitting 10.98 target boost in 3RD gear and 14.87 actual boost in 3RD gear.
here is that log. https://docs.google.com/spreadsheet/...0VSdlVHREd4WXc
i also took 3 more logs the next day with throttle pos. and td boost error logging
https://docs.google.com/spreadsheet/...2MzTDkteG8yc0E
https://docs.google.com/spreadsheet/...0Q2dFRLckpaYlE
https://docs.google.com/spreadsheet/...DVqQ3lLZzFJa2c
thx guys i love my car and dont want it hurt any help would be great!! please no comments like "go get a protune" i am saving up to go visit the socal cobb guys in a few months!
newscoobboob is offline   Reply With Quote
Old 02-20-2012, 10:07 PM   #2
art@grimmspeed
Member#: 301037
2004 Forester XT
Try using the Cobb HWGDC map that they have if you are not able to hit target boost. You may also have to adjust the WG arm a couple turns to get where you need to be. Let me know if you need some more help
art@grimmspeed is offline   Reply With Quote
Old 02-20-2012, 11:00 PM   #3
jerbull88
Member#: 248089
2011 wrx premium
metallic grey
10 psi target is really low for a stage 2 map. why is the target so low to begin with. with an open downpipe its really easy to surpass that low of a target. also your dam is at .5, in a happy with no knock it should be 1.0. your car apparently does not like that map.
jerbull88 is offline   Reply With Quote
Old 02-21-2012, 12:00 AM   #4
newscoobboob
Member#: 119956
2006 wrx waggin
chris@grimmspeed- i cant find a high waste gate duty cycle map from cobb for my 06...
Old 02-21-2012, 12:29 AM   #5
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Email cobb
Old 02-21-2012, 01:53 AM   #6
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
That's because we don't have separate maps like the 08+.
Your car hasn't learned to use 100% of the timing advance yet. That may be why you are targeting such a low boost target. Drive around normal for a few days, and see if it doesn't learn to 1.0. If it does, run another datalog and see if your targets have changed.
On a side note, is this a new AP? Is it on the latest firmware? You can update it via the AP manager.
How long had you driven on the flash before pulling those datalogs?
2Fast4U1DAY is offline   Reply With Quote
Old 02-21-2012, 10:17 AM   #7
newscoobboob
Member#: 119956
2006 wrx waggin
3 days driven on map before logs were made
the ap is a year old and has been updated before map was flashed
Old 02-21-2012, 11:09 AM   #8
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Something is DEFINITELY wrong here. Your DAM should have learned to 1 already, and your boost targets are about 5psi too low.
I'm going to take a stab and say that the engine knocked causing DAM to fall off and disabled the boost control system.
Try flashing a less aggressive map.
Edit: I see you are already on the least aggressive of maps. I think its time to reflash and see if the ECU is learning or if DAM is just staying at .5
Old 02-21-2012, 11:38 AM   #9
newscoobboob
Member#: 119956
2006 wrx waggin
reflash to what map?
Old 02-21-2012, 12:16 PM   #10
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Flash back to stock and then back to your ACN91 map. Do a bunch of city driving today and tomorrow, and monitor your DAM. If it learns up to 1, pull a datalog.
Also monitor your boost targets.
Old 02-21-2012, 12:52 PM   #11
newscoobboob
Member#: 119956
2006 wrx waggin
i got in touch with cobb and they are helping me figure it out thx for all your help guys
still having boosting issue sormeroid Newbies & FAQs 6 03-28-2010 05:57 PM
Having boost issue corzy666 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 08-12-2009 05:16 PM
Just installed FMIC, having boost issues now. BiggSean Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 02-03-2007 07:19 PM
having boost issues 1alexR6 Newbies & FAQs 3 10-04-2006 01:02 PM
