Old 02-20-2012, 10:38 PM   #1
flat_four_sti
Member#: 296539
05 impreza sti
white
Default help asap engine crank no start
can anyone help me !!!!! my sti got into an accident front end.the wreck was so bad it hit the cam and broke it and jumped timing caused it to bent a valve. so i fixed everything put the engine back and pluged everything back up and it doesnt start but i hear the pump go on and it cranks. what can be the problem any help
flat_four_sti is offline   Reply With Quote
Old 02-20-2012, 10:43 PM   #2
Kris.is.awesome
Member#: 256840
2000 BMW ///Mcoupe
Silverrrrrrr
Did YOU rebuild it? Do you know what you were doing?
This is extra vague.
Kris.is.awesome is offline   Reply With Quote
Old 02-20-2012, 11:07 PM   #3
flat_four_sti
Member#: 296539
05 impreza sti
white
yea i ended up rebuilding it and when i was timing it i used some sheet of paper my friend from a repair shop printed me that showed me the timing on it how it goes
Old 02-20-2012, 11:45 PM   #4
AREA1320
Member#: 112508
Welp. Do the obvious. Check the timing again. Pull the avcs gears off and make sure you have them pinned right.
AREA1320 is offline   Reply With Quote
Old 02-21-2012, 09:36 AM   #5
flat_four_sti
Member#: 296539
05 impreza sti
white
i think that is what i am going to end up doing check the timing belt
No crank, no start itwillboost Newbies & FAQs 3 12-30-2011 02:35 AM
No Crank no start mmkay? Trogasarus Electrical & Lighting 3 11-19-2009 11:45 PM
Crank/no start - no spark - ideas? PeteDucati Built Motor Discussion 12 04-29-2007 04:29 PM
Stock STi: crank, no start, flashing CEL. cnstman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-28-2004 11:18 PM
XT6 (92), Does anyone have a illustration of the timing belt(s) Crank No Start. munkis Normally Aspirated Powertrain 0 10-20-2002 11:25 PM
