Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 02-20-2012, 11:24 PM   #1
Member#: 285650
2008 WRX Hatchback
Default P1071 check engine light. HELP!!
2008 WRX Automatic Transmition with 45,000 miles
Tsudo downpipe & exhaust
AP Short Ram intake
Forge BOV
Boost Solenoid
Stage 2 tune
I have a P1071 check engine light (as well as traction control and cruise control light) that comes on repetidly every 200 miles or so at idle or a cruising speed. I've checked all possible lines for a boost leak. I cleaned the MAF sensor in the intake about 1 week 1/2 ago, and deleted the code. Today the light came back on coming home from work while cruising at about 45 mph. Any ideas what the cause can be of the repeated check engine light?
rocklandrfc12 is offline   Reply With Quote
Old 02-20-2012, 11:25 PM   #2
Member#: 283537
Accidental post
SubieWRX605 is offline   Reply With Quote
Old 02-21-2012, 12:40 AM   #3
Member#: 308265
2008 WRX
I have the 2008 Subaru factory service manual and I don't see a P1071 in the list.
dead_eye is offline   Reply With Quote
Old 02-21-2012, 09:21 AM   #4
Member#: 306170
2004 Impreza WRX STi
Maybe he meant P0171, Running lean. Happend to me as I was cruising sometimes and it was a dirty MAF and a messed up o2 sensor. A lot of person experiment this problem and can help you out in the diagnostic of your problem, but make sure you have the good Code #
Jayzord is offline   Reply With Quote
Check engine light help WRobX Service & Maintenance 6 12-30-2005 11:46 AM
Check Engine Light Help Topshelf Normally Aspirated Powertrain 6 12-13-2004 12:45 PM
check engine light HELP!!!! subarublu Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-26-2004 02:27 PM
Check Engine Light Help HpiRally Normally Aspirated Powertrain 1 03-01-2002 12:15 AM
check engine light !!! help! jhoffmann Technical Forum Archive 2 08-13-2000 12:17 AM
