Welcome to the North American Subaru Impreza Owners Club Friday March 27, 2015
Old 02-20-2012, 11:54 PM   #1
Bpatts
Member#: 288358
2005 Wrx Sedan
Default Blackstone Labs UOA Results
Car: 2005 Wrx
Mileage: 92500
Bone Stock
Just got my first UOA from Blackstone Labs. Bought the car at 86k, previous owner used basic dino oil. I am continuing to do so, I'm afraid that if I switch over to synthetic that the car will start to develop oil leaks.
Anyways, I was a little concerned on the copper amount even though they doubt the levels are anything to worry about.
Would high copper levels be bearing material?
Looks like the UOA is ok for now. Your opinions?
Bpatts is offline   Reply With Quote
Old 02-21-2012, 10:06 AM   #2
68Cadillac
Member#: 95901
Bearing are made from Babbitt. Babbitt is a metal alloy like bronze is a metal alloy.
There are many Babbitt alloys in addition to Babbitt's original. Some common compositions are:
90% tin, 10% copper
89% tin, 7% antimony, 4% copper
80% lead, 15% antimony, 5% tin
76% copper, 24% lead
75% lead, 10% tin
67% copper, 28% tin, 5% lead
Internal combustion motors use Babbitt metal which is primarily tin-based because it can withstand the pounding. Lead-based Babbitt tends to work-harden and develop cracks but it is suitable for constant-turning tools such as sawblades.
For bearing wear in a Subaru UOA you need to look to the lead content. You're good.
68Cadillac is offline   Reply With Quote
Old 02-21-2012, 10:52 AM   #3
Bpatts
Member#: 288358
2005 Wrx Sedan
I learn something new everyday. Thanks for the input. Bearing wear was my biggest concern.
Old 02-21-2012, 12:18 PM   #4
WeldingHank
Member#: 98645
2002 WRX Wagon
unless you think the oil is really sluged, I wouldn't worry about switching to synthetic.
I have switched cars as late as 130K in the past without issue.
WeldingHank is offline   Reply With Quote
Old 02-21-2012, 05:52 PM   #5
bluesubie
Member#: 767
04 FXT
Does the '05 have an oil cooler? I definitely would switch to synthetic. Try Max Life Full Synthetic if available or Mobil1 High Mileage if you're concerned about leaks.
-Dennis
Well, the results are in...my Oil Analysis from Blackstone Labs bjcarter2 Alaskan Impreza Club Forum -- AKIC 43 02-23-2010 01:01 AM
Blackstone Labs UOA - Royal Purple 5w30 6500mi - 04 WRX anfernee Service & Maintenance 11 08-02-2007 09:24 AM
My Syncromesh Blackstone Labs results Got Groceries? Transmission (AT/MT) & Driveline 3 04-26-2006 01:56 PM
Got my 1st Dyson analysis/Blackstone labs restults wayoutwest Service & Maintenance 11 09-01-2005 07:35 AM
cold comp. test & blackstone lab report. gusto Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-09-2005 08:50 PM
