Old 02-21-2012, 06:36 PM   #1
hvp014
Member#: 299137
05 Saabaru
Default How To: R&R spark plugs 2.0L turbo
Just got done changing my spark plugs on my 9-2, little over due at 68k. Here's a helpful step by step...
Instructions are for a 2.0L Turbo engine, but will be similar for all models.
OEM spark plugs are: NGK 4793 or prf6g
Subaru manual recommends a 0.028-0.031 gap
Tools needed:
3/8 drive Ratchet
1/4 Drive ratchet
10" 3/8 drive extension?
3" 3/8 drive extension
10mm deep well socket 3/8 drive
12mm deep well socket 3/8 drive
12mm shallow socket 1/4 drive
5/8" spark Plug socket with rubber grommet
#2 flat head screwdriver
10mm Wrench
Spark plug Gapper
Dielectric grease
Anti seize
1. Disconnect Neg terminal.
2. Working on the passenger side first, unclip air box, MAF, and unscrew inlet hose clamp.
3.Remove 2 12mm bolts holding air box to body.
4.Here are the ignition coils, using the 1/4 ratchet remove the 2 12mm bolts.
5.Using the 3" 3/8 extension and 5/8" spark plug socket, remove both spark plugs.
hvp014 is offline   Reply With Quote
Old 02-21-2012, 06:37 PM   #2
hvp014
Member#: 299137
05 Saabaru
6. Now to re install the new plugs, add a dab of anti sieze on the threads.
7.Before re installing the coils, add a dab of dielectric grease to prevent the boots from sticking to the plug.
8. Re install the coils, air box, MAF and tighten the inlet clamp and move onto the driver side. Here are the coils.
9. Remove the Battery, 2 10mm bolts hold the tie down and the clamps are 10mm as well. Pull the bottom cover up and out.
10.Here are your 2 12mm bolts holding the coils on. Use your 1/4 drive ratchet and 12mm socket.
11.Pull the coils up and out.
Old 02-21-2012, 06:38 PM   #3
hvp014
Member#: 299137
05 Saabaru
12.Once again using your 3/8 drive ratchet, 3" 3/8 drive extension and 5/8" spark plug socket remove both plugs.
13. Apply anti seize and install the new plugs.
14. Grease up the coils. Re install the coils, and re install the battery.
15. Turn the car over, look for a smooth steady idle, and grab a beer, it's all done! :beer:
Old 02-21-2012, 06:38 PM   #4
hvp014
Member#: 299137
05 Saabaru
Save for future updates.
Old 02-21-2012, 06:53 PM   #5
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
another nice writeup... btw No anti-seize needed on the plugs per NGK
http://forums.nasioc.com/forums/show...8&postcount=30
fastnoypi is offline   Reply With Quote
Old 02-21-2012, 10:26 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
if you are gonna remove the battery....that should be included in step 1...waste of time to not do it while you are there
Old 02-21-2012, 11:57 PM   #7
hvp014
Member#: 299137
05 Saabaru
Thanks, I took the easier side first, and that's why I didn't remove the battery earlier. Either way its gotta go!
Thank you for the heads up!
Hope this guide helps someone out!
Old 02-22-2012, 12:21 AM   #8
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Nice write up and pictures.
Old 02-24-2012, 02:15 PM   #9
Gro Harlem
Member#: 165782
2015 WRX Limitd Stg2
'02 Stg4 & JSW TDI Stg2
awesome, i'ma do the plugs when i change out my air filter this weekend. thx for the article! good pics & writeup
Gro Harlem is offline   Reply With Quote
Old 03-17-2012, 01:07 PM   #10
bigbadbronxy2k5
Member#: 260708
Awesome write up, thanks. Doing the plugs on my Gf's 05 WRX and 'till now have only done the plugs on my 06 2.5 work car. Looks to be the same except for the battery removal. Thanks for listing the tools as well.
bigbadbronxy2k5 is offline   Reply With Quote
Old 03-17-2012, 01:13 PM   #11
juventus1983
Member#: 183534
12 sti
How long did this take you?
juventus1983 is offline   Reply With Quote
Old 03-17-2012, 03:37 PM   #12
ianison
Member#: 143134
2003 Impreza WRX
Sonic Yellow
Good Writeup. Took me about 2 hours alone to replace the plugs on my 03. First time to do it on my car. This includes some some time took to clean my battery and around the filter area. I was slow with my ratchet though, I gotta get it fixed.. I'm sure there are speedier people there.
I did most everything on the engine with a 3/8" ratchet, but I removed windshield reservoir and battery with my 1/4". A flex head 3/8" would have made things easier, but I did mine with my regular ratchet.
I then did my gf's elantra and that took 20 min. geesh.
ianison is offline   Reply With Quote
Old 03-19-2012, 09:46 AM   #13
hvp014
Member#: 299137
05 Saabaru
All in all, a little over an hour.
Thanks for all the feedback, it will be different for every model, but this is a good general idea.
Old 03-19-2012, 04:37 PM   #14
04subiewrxCobbstg2
Member#: 311485
2004 WRX
Thanks for the info changed my plugs last night and this was a big time saver thanks
04subiewrxCobbstg2 is offline   Reply With Quote
Old 03-21-2012, 03:39 AM   #15
travlingnome
Member#: 253579
Great pics, nice detailed explanation. I assume that this will not be much different for an '02 2.0? I just bought my WRX 9 days ago with 117k on the car. Timing belt will be done next week by an Indy shop and I will be doing the rest of the major service my self this weekend.
As an aircraft mechanic I appreciate your attention to detail.
travlingnome is offline   Reply With Quote
Old 03-26-2012, 09:18 AM   #16
hvp014
Member#: 299137
05 Saabaru
Thanks again, I'm happy if this guide can help at least one person out.
Yes, they should be very similar, you will have the washer tank on the drivers side though. But we both have the 2.0L motors, so engine wise it will be the same.
Old 04-09-2012, 11:07 PM   #17
scottjua
Member#: 2937
2013 BMW 335i
2006 STi Aspen White
Thanks for this post... just tackled mine with great success.
One tip... I put some grease on the porcelain part of the plug, so I could easily remove the socket... otherwise it gets stuck and is a real mutherbitch to remove.
scottjua is offline   Reply With Quote
Old 04-10-2012, 12:44 AM   #18
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Never over tighten plugs - it can turn into a nightmare easily if it snaps.
Old 04-10-2012, 10:37 AM   #19
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
My solution to this is to use a length of air compressor hose to install the plugs instead of a spark plug socket, then tighten with a regular socket (no rubber retainer thingy).
It's easier to feel the threads engage and avoid cross threading.
Thanks for the write-up by the way.
gpshumway is offline   Reply With Quote
Old 04-17-2012, 01:52 PM   #20
Ham02wrx
Member#: 255937
02 Impreza WRX
WRX Rally Blue
quick question did you have to jack the motor up any to clear the plug housings
Ham02wrx is offline   Reply With Quote
Old 04-23-2012, 09:34 AM   #21
hvp014
Member#: 299137
05 Saabaru
Not in the 2.0, might be different for the 2.5, I cant say because I haven't done plugs in one yet. But again as for the 2.0L I did NOT have to jack the motor up.
Old 07-28-2012, 10:17 AM   #22
emjp4
Member#: 290926
2005 WRX
Subscribed for future use, and resurrection for a great guide.
emjp4 is offline   Reply With Quote
Old 07-29-2012, 10:40 AM   #23
itospeedz1
Member#: 314534
2003 WRX
its easy'er to get them from the bottom on the drivers side you dont have to take the battery out. or jack to motor. also recommend using the snapon double swivel spark plug socket.
itospeedz1 is offline   Reply With Quote
Old 01-09-2013, 08:49 PM   #24
Frankh21
Member#: 295776
2005 SAAB 9-2x Aero
Thanks for posting up this walk through, especially the tools required for the job. I just did mine with your help and only had a bit of trouble with the one closest to the drivers side. Went with the same OEM NGK plugs. I snapped a couple pics of the old plugs.
[IMG][/IMG]
Frankh21 is offline   Reply With Quote
Old 01-10-2013, 10:14 PM   #25
Elbert Bass
Member#: 283429
No, Only Suby you really need to jack up for plugs is an H6. It's even easier of you use Snap-On S9721A socket - you can get all 4 from the bottom.
http://buy1.snapon.com/catalog/item....re&dir=catalog
Elbert Bass is offline   Reply With Quote
Confused about copper spark plugs... 2.5L turbo garretts77 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-04-2008 10:33 PM
How to change spark plugs in an 05 Legacy 2.5 Gondi Service & Maintenance 3 12-11-2007 06:48 PM
ne1 here know how to change spark plugs on wrx? Benjamin Tang Vancouver Impreza Club Forum -- VIC 12 05-30-2004 12:50 AM
Help, how to change spark plugs Hanzo Service & Maintenance 14 01-21-2002 10:57 AM
How to Change spark plugs on a Phase I DOHC? yebokmj Normally Aspirated Powertrain 5 01-21-2001 04:44 PM
