Old 02-21-2012, 09:56 PM   #1
Omegared99
Member#: 277965
2007 WRX
Grey
Default Datalog COBB AP w/Perrin Stage 2 Map
Omegared99 is offline   Reply With Quote
Old 02-21-2012, 10:04 PM   #2
hutch959
Member#: 267463
wrong forum (needs posted in ecu forum)
no DAM. we need to see the DAM
that one log has some nasty knock as you lift.
the rest of them are long and not really usefull.
3 or 4th gear pulls is what we need to see.
hutch959 is offline   Reply With Quote
Old 02-21-2012, 10:49 PM   #3
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
1. What year and model I'm on my android and can't see
2. Data logs should be done in third gear starting from ~2500rpm wide open throttle to near redline if you can do so safely.
3. Set your datalogging parameters to default. This way we have all the critical information.
4. What are the current mods to the vehicle?
5. Get a proper log or two and post back.
2Fast4U1DAY is offline   Reply With Quote
Old 02-21-2012, 10:50 PM   #4
Omegared99
Member#: 277965
2007 WRX
Grey
will get 3 and 4 pulls and DAM. BUT H
BAD IS THS KNOCK. how do u fix it
Old 02-21-2012, 10:51 PM   #5
Omegared99
Member#: 277965
2007 WRX
Grey
2007 wrx
Old 02-21-2012, 10:52 PM   #6
Omegared99
Member#: 277965
2007 WRX
Grey
thanks will do and get back asap
Old 02-21-2012, 10:59 PM   #7
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
You need a protune or switch to a less aggressive map if it really is knocking bad. But your knock corrections are fairly minor. Get a good log following the instructions I stated above and we can see what's going on for real.
Old 02-21-2012, 11:00 PM   #8
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
Also what map are you running their OTS stage two? What modifications are done to the car? What octane fuel are you using?
Old 02-21-2012, 11:52 PM   #9
Omegared99
Member#: 277965
2007 WRX
Grey
SPT intake SRS downpipe and cat back perrin stage 2 tune
Old 02-21-2012, 11:53 PM   #10
Omegared99
Member#: 277965
2007 WRX
Grey
93 octane
Old 02-22-2012, 09:37 AM   #11
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
There is your problem..... ^^. SPT intake is not compatible with the OTS maps.unless Perrin tweaked the map to suit your intake. I bet your knock will be non existent if your load calculations, MAF, and injector Scaling was correct.
Old 02-22-2012, 01:21 PM   #12
Omegared99
Member#: 277965
2007 WRX
Grey
Dam spt
Old 02-22-2012, 02:51 PM   #13
Omegared99
Member#: 277965
2007 WRX
Grey
Well I've gotta get cash unless they can fix it or I fix it in access tuner race
Old 02-22-2012, 02:52 PM   #14
Omegared99
Member#: 277965
2007 WRX
Grey
I may switch it back to the Cobb ots map
Old 02-22-2012, 03:57 PM   #15
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
There's no support for SPT with the Cobb ots map either. You either need a protune (or fix it in ATR if you know how to tune a Subaru) or to sell the SPT and get the Cobb SF intake and airbox, or revert back to the stock airbox. It also doesn't help that you have a SRI. Higher intake temps can cause knock.
Old 02-22-2012, 05:39 PM   #16
Omegared99
Member#: 277965
2007 WRX
Grey
What's an SRI
Old 02-22-2012, 06:34 PM   #17
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
What's an SRI
Short ram intake
Old 02-22-2012, 07:30 PM   #18
Omegared99
Member#: 277965
2007 WRX
Grey
Dam I'm retarded I thought about a still intercooler cause I know this map supports it and also perrin cai or maybe a AEM
Old 02-22-2012, 07:31 PM   #19
Omegared99
Member#: 277965
2007 WRX
Grey
Sti Inter Cooler
Old 02-22-2012, 07:42 PM   #20
2Fast4U1DAY
Member#: 250152
2006 WRX Limited
You could sell your SPT and get one of the supported intakes and go that route. The COBB OTS Map supports the AEM CAI (but not the Perrin CAI), and I would imagine Perrin's maps support the Perrin CAI (unsure if it supports the AEM or other intakes but you would have to contact them and confirm)
FS : Cobb Accessport with Perrin Stage 2 (17.5psi) for 2008 WRX!!! Map for mikeWRX920 Engine/Power/Exhaust 13 09-29-2011 12:07 AM
Cobb ap v2 autocross stage 1 map New-to-the-Old Off-Topic 6 04-11-2011 12:36 AM
FS-CT: 08+ WRX/STi Cobb Accessport w/ Perrin stage 1 map SvSTi Engine/Power/Exhaust 3 05-26-2010 11:39 AM
Cobb AP 1 - stage 2 map with my mods? Ultimateone AccessPort 3 12-09-2007 02:56 PM
Cobb AP comes with stage 2 map already? dodiox General Community 5 03-06-2006 11:25 PM
