Old 02-21-2012, 10:07 PM   #1
Beauchemin
Member#: 267077
Default Ej22t leggy swap ??
I have a ej22t block and ej22 heads
Can i bolt them up and put it in my 98 leggo without having to deal with wiring issues?
If so id used the ej22t HG right?
Id also be running
Td04
Wrx tmic
Custom up/dwn pipes
Oil feed from oil press sensor and return to tapped oil pan
Coolant feed from ej22t water pump? And return to?????
Best engine manage for this??
Not looking for crazy power.. Just a fun little daliy driver
Any imput would be great
Beauchemin is offline   Reply With Quote
Old 02-21-2012, 11:40 PM   #2
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
The heads go to the ECU....so what ever heads you use you need their corresponding ECU to make things go the easiest.
ej22t HG....unsure what your talking about??
Sounds like your looking at stand alone ECU tuning and some harness merging. Like AEM or Mega Squirt
My Legacy SS build:
http://forums.nasioc.com/forums/show...light=crap+box
dangerousatom is offline   Reply With Quote
Old 02-22-2012, 07:13 AM   #3
Beauchemin
Member#: 267077
Ok cool.. I currenly have ej22 in the car but the are single ported.. I planned on useing dual ported ej22 heads though..
And HG.. Im talking head gasket.. I would just the ej22t HG to match the block not the other way around??
Old 02-22-2012, 10:28 AM   #4
dangerousatom
Member#: 70710
Oh "HG" ...duh
For the most part the head gasket hole patterns are all the same. You can widen the holes in the gasket a bit to more accommodate the block. You should use HG to heads IMO, because the block is going to be same/same weather 2.0-2.2-2.5. The heads IMO determine the end result turbo or NA gasket.
If your looking for an easy head swap onto the 2.2 with a turbo in the mix, and dont want to do a harness swap or merge. There are few things you need to confirm:
- what year is your car and are you OBD1 or OBD2
- are you SOHC or DOHC now.....I assume SOHC since your single port
- how many cam position sensors do you have ....1 or 2
Just an FYI.... changing heads and turbo charging an NA platform is quite and undertaking.
For any real tech-y questions Id call www.metricmotorsxtreme.com they do suby sand rails and crazy turbo to head combos.
Old 02-22-2012, 12:37 PM   #5
RallyColtTurbo
Member#: 16819
Head gaskets match the BORE. Always.
The stock EJ22T pistons protrude past the deck a few thousanths. A proper/OEM EJ22T head gasket is thicker than normal to deal with this. So, unless your going to use custom pistons, use a stock EJ22T head gasket or do lots of math to prevent piston to head contact.
RallyColtTurbo is offline   Reply With Quote
Old 02-22-2012, 01:00 PM   #6
dangerousatom
Member#: 70710
Yes^ I should have explained that far better.
The HG is to the bore, I should have said the water passage holes are basically the same on the HG no matter the motor size, and can be widened to accommodate the blocks passages.
Cometic makes a thicker HG for the Turbo 2.2L
Old 02-22-2012, 06:38 PM   #7
Beauchemin
Member#: 267077
Its obd2, its a 96 2.2 single cam in a 98 legacy. It has one cam sensor on the driver side head
Old 02-22-2012, 06:53 PM   #8
vica153
Member#: 76586
2006 9-2x Aero
Why not use newer 2.0L heads, harness, ECU? At this point they are just as cheap as any other heads and you will have a car that runs well and is tunable.
Using the old stuff and a mish mash of NA parts will work, but it's not going to run particularly well and you won't really be able to tune it. You'll go thru a lot of hassle and won't really be saving any money.
vica153 is offline   Reply With Quote
Old 02-22-2012, 08:01 PM   #9
Beauchemin
Member#: 267077
I just have all the parts for the build i was thinking of but did not think about tuneability.. So will probably wait on it and find some wrx heads, harness and ecu... Make it worth while
FS: (ONTARIO) 91 ej22t leggy engine part out cribbie Engine/Power/Exhaust 14 04-06-2009 05:36 PM
Ej22t engine swap cjfike Newbies & FAQs 2 05-29-2004 08:15 AM
EJ22T head swap EJ22TGC8 Pre-2002 Factory Turbo Powertrain 2 12-09-2003 01:11 PM
93 EJ22T direct swap into 93' impreza? ^jynx^ Subaru Conversions 2 10-27-2003 10:35 PM
Future EJ22t Engine Swapping Question ejicon Normally Aspirated with bolt-on Forced Induction Powertrain 11 05-20-2002 10:37 PM
