Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Old 02-01-2013, 05:13 PM   #1526
sqc151
Member#: 51432
w/ help from Octain.
racing brake oversized
2 piece front rotors 332x32 w/ hawk pads
290mm rear rotors w/ hawk pads.
before and after
07 5x114 hubs going on next.
full view.
how many subies do you see?... :P
sqc151 is offline   Reply With Quote
Old 02-01-2013, 05:22 PM   #1527
08OBS
Member#: 274397
2005 WRX
1992 Legacy SS
Nice! I should've stopped by on my way home. I pass your place every friday.
08OBS is offline   Reply With Quote
Old 02-01-2013, 07:21 PM   #1528
octain11
Member#: 298800
they look even better in person
octain11 is offline   Reply With Quote
Old 02-01-2013, 07:34 PM   #1529
blue sedan
Member#: 311622
2010 WRX
Very nice!They look Huge inside the wheel.No brake fade Ever!
blue sedan is offline   Reply With Quote
Old 02-03-2013, 01:16 AM   #1530
pushnpounds
Member#: 207683
02 bugeye
wrb
they do look better in person. not very productive but good day today. had a fun drive home in the snow.
pushnpounds is offline   Reply With Quote
Old 02-03-2013, 08:15 AM   #1531
slaytalera
Member#: 163816
1999 Legacy Outback
jeez, the brakes practically 1/4 of the car
slaytalera is offline   Reply With Quote
Old 02-03-2013, 11:39 AM   #1532
sqc151
Member#: 51432
rear rotor sizes.
small rotor is a stock vented SS rotor.
medium rotor is a stock 06 WRX rotor.
large rotor is a racing brake 318mm rotor.
after searching what the rotors, brackets and pads go for new, it came to about 800$ for the rear brake setup.
gonna sell this kit to get the correct kit for my car. so if you have an LGT and want to upgrade your rear rotors... THIS is the kit.
Old 02-04-2013, 05:04 PM   #1533
Gyges
Member#: 297111
2006 STi
did some exploring the other day.
Gyges is offline   Reply With Quote
Old 02-04-2013, 06:21 PM   #1534
turbos make me smile
Member#: 327662
2011 wrx hatch
black
When is the next tri-state run going to be?
turbos make me smile is offline   Reply With Quote
Old 02-04-2013, 06:27 PM   #1535
robsuerto
Member#: 331899
2012 WRX
John Shafer tuned
Check the first post in the future. Feb 10th
robsuerto is offline   Reply With Quote
Old 02-04-2013, 06:33 PM   #1536
Member#: 327662
2011 wrx hatch
black
Thanks. Still new to this.
Old 02-04-2013, 08:49 PM   #1537
pushnpounds
Member#: 207683
02 bugeye
wrb
i got my light bar today!! i got new tires mounted on my stock wheels for now too.
Old 02-04-2013, 09:32 PM   #1538
08OBS
Member#: 274397
2005 WRX
1992 Legacy SS
what light bar did you get?
Old 02-04-2013, 10:06 PM   #1539
kingkai23
Member#: 344120
15 sti limited
wrb
Count me in on sunday
kingkai23 is offline   Reply With Quote
Old 02-04-2013, 10:41 PM   #1540
pushnpounds
Member#: 207683
02 bugeye
wrb
the rally innovation rally skid bar. it's the small hoop with the skid plate with holes in it.
Old 02-06-2013, 01:16 PM   #1541
octain11
Member#: 298800
pics or i don't believe you lol
Old 02-06-2013, 04:28 PM   #1542
ranpastrana
Member#: 323108
2012 wrx sti
BLK
I should be able to make this one. Looks like it will snow on Friday should be fun over the weekend
ranpastrana is offline   Reply With Quote
Old 02-06-2013, 07:39 PM   #1543
sqc151
Member#: 51432
im probly missing a couple things but this is how my last few days went.
long story short.
last week one of my radiator fans cut the rad. so i replaced it with a spare i had.
a week later this....
started monday morning.
from new jersey to albany ny, upper radiator hose blew.
go to 3 auto stores before getting a hose that was in stock.
replace in parking lot at night in the cold.
drive from albany to saratoga ny.
radiator cracked at exit 16 on the northway.
make it to store and add coolant.
drained radiator for the next morning.
tues:
call around looking for radiator, but are all a few days away. (NO ONE STOCKS RADIATORS FOR THESE CARS!!!!!!!)
remove radiator and fix crack with plastic weld.
(this process was done several times and went thru 100 dollars worth of coolant before i got the leak to stop)
few min later, sprung another leak. upper coolant under pressure.
removed thermostat (its dark out) test in boiling water to make sure it works. (it works)
re-install stat. another leak, drain coolant for the 100th time. fix stat again.
another leak again... more plastic weld.
weds:
top off with fluid check for leaks.
leave saratoga, with a stop in albany to check radiator. (so far so good)
get to exit 16 on the thruway and temp gauge started to move, i pulled over and added more coolant.
head to matamoros pa to avoid traffic on rt 80 in jersey and stop at autozone for more coolant.
add coolant. its leaking. i find leak at bottom of radiator in the fins. (after i saw this i just stopped trying to fix leaks)
top off again with coolant and head from matamoros pa to jersey.
made it home with no issues. put drain pan under rad so my garage doesnt fill up with coolant.
replacing with:
new radiator
new coolant temp sensor
new thermostat
new radiator cap
new upper and lower hoses
its been a rough cold dark 3 days. i cant wait to crash in my own bed tonight.
Old 02-06-2013, 07:48 PM   #1544
robsuerto
Member#: 331899
2012 WRX
John Shafer tuned
Dam mark. Sorry for your troubles
Old 02-06-2013, 11:16 PM   #1545
pushnpounds
Member#: 207683
02 bugeye
wrb
damn that sucks mark. here are some quick pics of the wagon. oh yea i had to take the fogs out for inspection since they weren't working. turns out the bulbs were blown,simple fix but 5 of 6 mounting bolts snapped.
snaggle tooth
Old 02-07-2013, 08:51 AM   #1546
ridenepa612
Member#: 274107
2003 impreza 2.5i
sedona red pearl
Well, won't be making the drive anyway. The ex decided to have a weekend get away with her new boyfriend instead of spending the weekend with our son. Maybe ill be there next month, and maybe with a new car.
ridenepa612 is offline   Reply With Quote
Old 02-07-2013, 10:13 AM   #1547
CoSTiSS
Member#: 341810
2006 STi
Gray
Wont be able to make this one either. Got a big software upgrade going on. Maybe ill do some donuts in the parking lot since we getting all this snow.
CoSTiSS is offline   Reply With Quote
Old 02-07-2013, 11:13 AM   #1548
etl003
Member#: 176806
2006 sti
cgm
i wanted to come by on this months run to show mark the installed bags, but it seems like 2013 is a problem year.
my meth kit (i think) is not working. was gon get diagnosed this saturday but i still have on summers so i wont be going very far.
i got aquamist hfs6, if anyone here is pretty knowledgable with it, maybe i can get some help
etl003 is offline   Reply With Quote
Old 02-07-2013, 12:29 PM   #1549
jking1202
Member#: 345945
04 WRX
Wait when is the drive? And how does it work, sorry new to this forum.
jking1202 is offline   Reply With Quote
Old 02-07-2013, 12:54 PM   #1550
sqc151
Member#: 51432
In the future check 1st post.
Its this Sunday the 10th.
Whos a good tuner in the tri-state area? (NY NJ CT) qban32 Tri-State Area Forum 2 07-02-2008 11:26 AM
WTB/WTT wrx sideskirts for STI (NY,NJ,) stiizy Private 'Wanted' Classifieds 2 09-26-2007 10:12 PM
FS: TurboXS Stealthback (NY/NJ/CT preferred) nizz Tri-State Area Forum 29 08-02-2005 01:36 PM
FS (NY/NJ/CT)... Front Strut Bar for 97-01 Impreza New $35.00 willfong Private 'For Sale' Classifieds 2 01-16-2005 10:11 AM
FS (NY/NJ/CT): Stock 02 ECU RIwrx Private 'For Sale' Classifieds 12 08-13-2004 11:56 AM
