Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Closed Thread
Old 10-19-2012, 01:30 AM   #3051
Wiznaz
Member#: 70094
GTR - Hired Driver
Stupor Silver Dassit
Was that the truck's tire? I'll have nightmares now.
Wiznaz is offline
Old 10-19-2012, 08:39 AM   #3052
celosteelo
Member#: 80062
06 STi
Good mornin fellas...
celosteelo is online now
Old 10-19-2012, 09:06 AM   #3053
Donzo
Member#: 95337
2012 Jeep Overland
Yup, truck's tire.
Donzo is offline
Old 10-19-2012, 10:12 AM   #3054
outphase84
Member#: 78485
2005 STi
AW
Originally Posted by Jive Turkey
the sti understeered like a pig through hard corners. the only thing htat got it out is the buttloads of power. futher AWD sometimes is like driving autopilot. the driver input is sometimes so minimal. dont get me wrong i LOVE the sti and it's a monster, but the brz is just more of a drivers car IMO.
Sounds like a case of poorly tuned suspension, combined with inferior chassis you just essentially described my biggest issues with the GR.
Wuw for the wbo2?
outphase84 is offline
Old 10-19-2012, 01:06 PM   #3055
rcny
Member#: 317633
2011 STi 4 Dr
I need some input if you guys don't mind.
Coil overs vs piston and rods for my next upgrade?
rcny is offline
Old 10-19-2012, 01:14 PM   #3056
FreNetiC STi
Member#: 164797
It gets me from
point A-B
^^Shift knob
FreNetiC STi is offline
Old 10-19-2012, 01:17 PM   #3057
tirkish
Member#: 171886
09 WRX Premium
MurderShine
Originally Posted by FreNetiC STi View Post
^^Shift knob
^^ LED interior lights!
tirkish is offline
Old 10-19-2012, 01:20 PM   #3058
Wiznaz
Member#: 70094
GTR - Hired Driver
Depends how much power you wanna make. STI rods are fine for 450whp. Pistons are maxed stock. lol
Wiznaz is offline
Old 10-19-2012, 01:37 PM   #3059
outphase84
Member#: 78485
2005 STi
AW
Yeah, but if you're cracking the block open, you may as well do them while you're in there.
Old 10-19-2012, 01:57 PM   #3060
Donzo
Member#: 95337
2012 Jeep Overland
Depends on budget also. If you're looking at coils in the $1,000 range, don't bother. Get a quality, high end coilover in the $1,800+ range. So, if you want to spend $1k, go with pistons and rods. $2k, then pick which one you want more.
Donzo is offline
Old 10-19-2012, 02:03 PM   #3061
Soarer
Member#: 134872
2005 LGT Ltd Wagon
STi Swap w/ Mods
Didn't you sell your last car because you took it too far and it wasn't comfortable as a DD anymore? Sounds like you're going down the same road again.
Soarer is offline
Old 10-19-2012, 02:06 PM   #3062
Wiznaz
Member#: 70094
GTR - Hired Driver
There are plenty of piston motors that lasted longer than full-build motors. If you're getting a high HP motor assembled by a competent builder then do it all but IMHO it's not worth the extra $1k for someone that wants to make 400whp on a low mileage car.
Wiznaz is offline
Old 10-19-2012, 02:23 PM   #3063
rcny
Member#: 317633
2011 STi 4 Dr
Goal is ~400whp
I have 2k+ I was thinking V1s for coils
Your thinking of the wrong person? My last car was a bone stock Passat.
rcny is offline
Old 10-19-2012, 02:26 PM   #3064
rcny
Member#: 317633
2011 STi 4 Dr
Also I am going to do both eventually currently the option is which one do I want to do now since at this moment I can afford to only one of them.
rcny is offline
Old 10-19-2012, 02:50 PM   #3065
sexyyrex
Member#: 128022
2011 Infiniti G37x
Sedan
Unexpected expenses could pop up when doing the rods and pistons. Sounds like you're better off with coils.
sexyyrex is offline
Old 10-19-2012, 03:13 PM   #3066
redpanda87
Member#: 274092
2011 wrx rip,2013WRX
Blanco
Stack some more dough and do both...
Otherwise, I would Prly do suspension and brakes, before power modifications. No sense in going fast if it cannot handle or brake. One of the first things I did was get some hawks for my Wrx.
You have an Sti, so I would just do a high quality coil set up and save up for the engine components.
redpanda87 is offline
Old 10-19-2012, 07:01 PM   #3067
Donzo
Member#: 95337
2012 Jeep Overland
Rule of thumb, don't build a Subaru motor. It's a very poorly designed motor. Stage 2 and a tune is all I'll ever do power-wise. Anyone that says otherwise isn't telling you how much time, money, headaches and motors they've gone through.
Is there a specific reason you decided on 400whp? Are you competing in any races? Why 400? Why not 350 or 300? Have you driven a Subaru with 350, 375 or 400 whp? It's not the best platform for high power. Start slow. go stage 2 with a Mikey tune and see how you like it. if you're still bored, get a fuel pump, spark plugs and a larger intercooler. Try a slightly larger turbo. There's no need to jump right into a 400whp build unless you really know what you're doing and/or you have more money than common sense.
Shoulda bought an Evo.
Donzo is offline
Old 10-19-2012, 07:15 PM   #3068
redpanda87
Member#: 274092
Blanco
Rule of thumb,
shoulda bought an Evo.
^^^^This.
Old 10-19-2012, 08:36 PM   #3069
rcny
Member#: 317633
2011 STi 4 Dr
Should have, I almost did.
It's Stage 2 already.
Also I've heard and read about ringland failure for stage 2 or higher. So I want to try and prevent that. ~400whp is a gradual thing not all at once.
rcny is offline
Old 10-19-2012, 08:58 PM   #3070
sexyyrex
Member#: 128022
2011 Infiniti G37x
Sedan
Some motors hold just fine. Mikey's rallispec motor held for 80k+ miles and was daily driven with multiple turbo setups and power levels.
With that being said a motor build will cost a considerate amount of money, parts, fluids, timing belt, misc gaskets, then you have a built motor with a stage two setup. have to factor in turbo injectors intake turbo inlet possible tgv deletes fuel pump etc etc...in the end it could run you alot more then you're guessing, especially for 400whp
sexyyrex is offline
Old 10-19-2012, 09:19 PM   #3071
sexyyrex
Member#: 128022
2011 Infiniti G37x
Sedan
My car has 400+ and still runs decent with no oil consumption at this time and is pretty badly beaten whenever I take it out...40k miles, 30r sized turbo with supporting mods, stock block.
sexyyrex is offline
Old 10-19-2012, 09:28 PM   #3072
Donzo
Member#: 95337
2012 Jeep Overland
Mikey is also a tuner, has access to shop equipment, tools and staff and at a much less cost than if he was a regular customer. He eats, sleeps and breathes the business. He has so much more knowledge and experience with tese cars than most people. You can't compare the average Joe's car to a tuner's "shop car."
If a motor blows in a "shop car" the shop can have it rebuilt or a new one put in over night before anyone even knows about it and they can do it for much much less than if it was for the average Joe. Not to mention the knowledge they have. Regular maintenance is also something that's much easier for someone in the industry.
However, I've heard great things about RalliSpec blocks.
Donzo is offline
Old 10-19-2012, 09:34 PM   #3073
rcny
Member#: 317633
2011 STi 4 Dr
I figured it's an expensive thing 10-15k job all in all but this just where I wanted to start out.
However I think I'll take the advice of saving up for the "build" and go for coils sooner than later.
rcny is offline
Old 10-20-2012, 12:34 AM   #3074
Donzo
Member#: 95337
2012 Jeep Overland
$10-15k in mods... Jeez.
Donzo is offline
Old 10-20-2012, 12:46 AM   #3075
singincanary
Will mod for Guinness
Member#: 77921
'02 Foz
'07 'beca, '08 OBXT
Paying retail for those mods?
singincanary is offline
Closed Thread
FS/FT : NY- 18x8.5 +45 5x114.3 White Desmonds Marquis Promodas SOLD!! F EVOZ Wheels/Tires 4 12-06-2011 01:55 PM
Westchester, NY Area Chat 2 i<3mylegacy Tri-State Area Forum 9939 09-24-2010 05:33 PM
