Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum
Closed Thread
Old 04-24-2012, 05:45 PM   #1101
05EJ25
Member#: 93133
87 Foxbody
red
Originally Posted by Donzo View Post
In case any of you feel like learning anything today, read this...
http://store.forcedperformance.net/m...otor%20Oil.pdf
Too bad this isn't for our motors. 33psi on 4g63.
Ran 5-30 Castrol syntec for 75000 miles on my green and it only broke because reassembly on my new block had blocked the banjo bolt feed filter.
their map is pretty bias too. See castrol product PDS and they show none of these mean while they meet all the criteria they are looking for.
http://www.castrol.com/liveassets/bp..._Sept_2011.pdf
05EJ25 is offline
Old 04-24-2012, 05:55 PM   #1102
outphase84
Member#: 78485
2005 STi
AW
Also, Mobil 1 10w30 has terrible, awful shear properties.
It turns into water. Do not ever, ever use M1 10w30 in a turbocharged application.
outphase84 is offline
Old 04-24-2012, 05:57 PM   #1103
05EJ25
Member#: 93133
87 Foxbody
red
RP is even worse. That stuff burns even the xpr.
05EJ25 is offline
Old 04-24-2012, 06:00 PM   #1104
redpanda87
Member#: 274092
2011 wrx rip,2013WRX
Blanco
I'll stick with my rotella for now in my stock 11'...
redpanda87 is offline
Old 04-24-2012, 06:21 PM   #1105
JiveMasterT
Member#: 116666
2011 STI Limited
Looks nice, plays dirty
Originally Posted by ytirrag View Post
is there a special paint any of you guys use to get that wrinkle red look of the sti manifold, or will this do? Amazon.com: VHT SP204 Wrinkle Plus Coating Red Can - 11 oz.: Automotive
That should work. Most of us that have wrinkle red had it come on our cars from the factory
On a high level, it's definitely a good read. On a low level, don't take this advice on a daily driven STI. A 4G63 loves heavy thick oil... without it they tend to develop lifter tick.
Don't use ANY Mobil 1 on a turbo charged engine. It turns to water within the first few hundred miles. It cannot handle the heat and pressure of a turbo charged motor at all.
Truth. I had about 2 quarts vanish just driving to/from Maryland. It's overpriced garbage.
Good idea. Rotella T6 was mainly designed for diesel engines. It handles high heat and high pressure just fine. It also has magnesium additives in it which aren't great for your cat if you're burning the oil, but helps with the longevity of the oil even under higher temperatures. It meets or exceeds all of the specifications Subaru has for oil in the 2011s.
To be honest, I had a lot of problems with shearing with most synthetic oils that I tested over the last year I had my 2007. I had the best luck with Valvoline conventional oil. My 2011 runs T6 and it hasn't consumed a drop. I will of course update you all if that changes.
JiveMasterT is offline
Old 04-24-2012, 06:41 PM   #1106
JiveMasterT
Member#: 116666
2011 STI Limited
Anyone else see this?
http://www.nydailynews.com/life-styl...icle-1.1066803
Kids drinking hand sanitizer?
Please, no one ever do this. I get it. There's ethanol in there and that could get you nice and drunk. There's also isopropyl alcohol (think, rubbing alcohol) and that **** will kill you.
Sure, you could eventually get really pure ethanol from that little tiny bottle by repeatedly mixing with salt and straining it out. You're still an idiot if you consume this **** though.
Old 04-24-2012, 06:49 PM   #1107
redpanda87
Member#: 274092
Blanco
My ex was a social worker in hunts pt at a residential rehab facility and that was commonplace there... That and mouthwash. Lol
Old 04-24-2012, 07:46 PM   #1108
Jive Turkey
Member#: 219492
'13 Hachi-Roku
Discontinued.
i have been running motul in mine and sending to blackstone. so far was great stuff.
Jive Turkey is offline
Old 04-24-2012, 08:39 PM   #1109
redpanda87
Member#: 274092
Blanco
Motul = the nectar of the gods.
Old 04-24-2012, 08:40 PM   #1110
jw10583
Member#: 304602
2011 STI
Grey
jw10583 is offline
Old 04-25-2012, 11:29 AM   #1111
05EJ25
Member#: 93133
87 Foxbody
red
HMMM, wonder is e85 would be cheaper to obtain per gallon this way???
05EJ25 is offline
Old 04-25-2012, 11:50 AM   #1112
Wiznaz
Member#: 70094
GTR - Hired Driver
Stupor Silver Dassit
Oil requirements vary on the specs of the engine build and the amount of heat and pressure that it will see. The Evo comes with Mobil 1 from the factory. I ran Mobil 1 & Mobil 1 High Mileage the entire time I had the Evo. I sold it with 95k miles on the original motor making +440whp for 60k miles and +500whp for the last 30k.
Some extra reading on oil:
http://forums.evolutionm.net/evo-eng...nal-turbo.html
Also keep in mind that Forced Performance is a turbo company. They want you to run that oil so you don't blow up your turbo. They don't care about your motors. lol
Wiznaz is offline
Old 04-25-2012, 11:58 AM   #1113
05EJ25
Member#: 93133
87 Foxbody
red
^THIS
05EJ25 is offline
Old 04-25-2012, 11:59 AM   #1114
JiveMasterT
Member#: 116666
2011 STI Limited
Definitely not. By the time you factor in the amount of salt you'd need to split out the junk and the fact that the contamination levels are still unacceptable for automotive use, you'd be spending a lot more than whatever the e85 gas price is right now.
Old 04-25-2012, 12:58 PM   #1115
05EJ25
Member#: 93133
87 Foxbody
red
Tarrytown train station tonight guys. Should be a good turn out. You guys are welcome to come up.
05EJ25 is offline
Old 04-25-2012, 01:43 PM   #1116
subi2.5i
Member#: 236778
08 Impreza
I dont mean to act or sound like a troll but Ive been following this thread for a while. Purely for entertainment, the info and knowledge you guys put on here is awesome and very helpful.
I live upstate near Poughkeepsie but I wish I brought my car to work today so I could join your meet and meet you guys. I work for metro north at the Tarrytown HQ right near the station. You guys seem like a fun crowd to hang with.
subi2.5i is offline
Old 04-25-2012, 01:47 PM   #1117
05EJ25
Member#: 93133
87 Foxbody
red
That's not actually us, per say. I go to their meets but they are the SLOW guys from facebook who meet there. I've been trying to get some of these guys to come down however not many people are free so this group has meets on thurdays. Stay tuned for location.
05EJ25 is offline
Old 04-25-2012, 01:49 PM   #1118
subi2.5i
Member#: 236778
08 Impreza
Will do, thanks
subi2.5i is offline
Old 04-25-2012, 01:56 PM   #1119
outphase84
Member#: 78485
2005 STi
AW
What time? I might stop out if I'm not busy.
Old 04-25-2012, 02:31 PM   #1120
05EJ25
Member#: 93133
87 Foxbody
red
7:30 across the tracks
05EJ25 is offline
Old 04-25-2012, 03:09 PM   #1121
Jive Turkey
Member#: 219492
'13 Hachi-Roku
Discontinued.
my buddy made this for me while i wait, just so we're clear, and people don't think i actually want this turd.
Old 04-25-2012, 03:23 PM   #1122
JiveMasterT
Member#: 116666
2011 STI Limited
7:30 on the tracks
FTFY.
Old 04-25-2012, 05:35 PM   #1123
JiveMasterT
Member#: 116666
2011 STI Limited
This is a deal if I've ever heard one…
http://seattle.craigslist.org/sno/cto/2977737272.html
Old 04-25-2012, 05:53 PM   #1124
05EJ25
Member#: 93133
87 Foxbody
red
Still laughing at this gem.
05EJ25 is offline
Old 04-25-2012, 06:13 PM   #1125
.MIGS
Member#: 300663
Anyone order from htautos?
How long did it take?
.MIGS is offline
Closed Thread
FS/FT : NY- 18x8.5 +45 5x114.3 White Desmonds Marquis Promodas SOLD!! F EVOZ Wheels/Tires 4 12-06-2011 01:55 PM
Westchester, NY Area Chat 2 i<3mylegacy Tri-State Area Forum 9939 09-24-2010 05:33 PM
