Old 02-22-2012, 11:33 AM   #1
bangorfreeflow
Member#: 305275
Default Right rear whurring noise
I'm trying to diagnose a loud whirring noise coming from the passengers rear tire. When I'm taking sharp right hand turns (so that there is no pressure on said tire) the noise stops. I thought it could have been a warped tire, but I have since replaced all the tires and the noise is still there. The faster you go, the louder it gets.
Spindle?
Hub?
Thoughts?
bangorfreeflow is offline   Reply With Quote
Old 02-22-2012, 11:55 AM   #2
Bpatts
Member#: 288358
2005 Wrx Sedan
wheel bearing? does it get louder or quieter when you turn?
Bpatts is offline   Reply With Quote
Old 02-22-2012, 12:08 PM   #3
bangorfreeflow
Member#: 305275
It gets quieter when I turn so pressure is released from the tire(turning right), possibly louder but no significant difference between turning left.
When I jack the wheel up and push on either side of it, there isn't much wobble. I'm used to a CJ5 with 35" tires as far as wheel bearings go, where there is a lot of wobble when the wheel bearing is shot.
Old 02-22-2012, 12:56 PM   #4
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
possible bent hub or maybe take a look at your caliper if one of the pistons are stuck and dragging
fastnoypi is offline   Reply With Quote
Old 02-22-2012, 04:16 PM   #5
motohippy
Member#: 225882
2000 OBS
'88 BMW K75S
Wheel bearing. When mine went there was no play. . .but the noise went away once I replaced it. Try getting a stethoscope and listening to the knuckle as you turn the wheel. Chances are you'll hear something grating.
motohippy is offline   Reply With Quote
Old 02-22-2012, 11:34 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
this is THE CLASSIC BAD BEARING SOUND
Old 02-22-2012, 11:36 PM   #7
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
It's a wheel bearing. Time to slap a new one in.
CosmoTheCat is offline   Reply With Quote
06 WRX - Right Rear Wheel Noise - Thumping Turned to Squeal? kpluiten Newbies & FAQs 5 05-28-2007 12:22 PM
Right Rear Suspension Noise e_a_olson Brakes, Steering & Suspension 3 10-17-2005 09:28 PM
Right rear clunking noise on take off byoung Newbies & FAQs 17 12-24-2004 10:34 PM
Right rear creaking noises cnk Brakes, Steering & Suspension 0 02-01-2003 10:53 PM
Right rear suspension noise (clunk) Jim Lewandowski Brakes, Steering & Suspension 3 11-28-2001 06:29 PM
