Old 02-22-2012, 03:14 PM   #1
Getrag
Member#: 300804
Default AT fluid in oil??... SOB!
If for some stupid reason I accidentally put a couple of cap fulls worth of AT fluid down my oil filler, would it be okay just to flush it out with oil a couple of times and I'd be okay?
I used up the last of my big 5 quart jug of oil and I went for another (what I thought was half used) quart of oil... turned out to be an old quart that I filled with AT fluid when I replaced my power steering fluid. I started dumping and right as it was coming out i pulled it up... unfortunately I got a little bit in there...
Am I okay to flush it with oil, or do i need to remove the oil pan and clean it out?
I sure as hell don't dare to start the car even with a few cap fulls in there.
Getrag is offline   Reply With Quote
Old 02-22-2012, 03:20 PM   #2
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
Caps?
You're fine.... the gear oil is heavy so if it gets in the oil pan... it will sink...
Just drain it..... and get a new oil filter too. What is basically going to happen is the gear oil is going to MIX with the oil you already have. Just drain it.... completely. You'll be okay.
2cents.
DHRDAN is offline   Reply With Quote
Old 02-22-2012, 03:24 PM   #3
Getrag
Member#: 300804
Yeah, cap fulls.. as in a small cap from a quart of oil. So not that much got in there.
Its not gear oil though, Its the Auto trans fluid, the thin red stuff.
Old 02-22-2012, 03:45 PM   #4
Bochet
Member#: 155613
if you're real concerned about it, do an oil and filter change, start it up, drive it up and down the block to get everything moving, and do another oil and filter change.
it should be fine.
Bochet is offline   Reply With Quote
Old 02-22-2012, 03:50 PM   #5
i_adz
Member#: 281829
04 wrx
02 ts DD
buy a new filter. if you have atf in your motor its bad! this is what happened to the last guy who did it:
i_adz is offline   Reply With Quote
Old 02-22-2012, 04:20 PM   #6
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
The last guy set off a nuclear holocaust?
Edit: i kid i kid.
Old 02-22-2012, 04:23 PM   #7
Getrag
Member#: 300804
does oil go through the filter right after adding oil into the filler?.. Wait... now that I wrote that I see that maybe you guys thought I added it into the filter. No, I added it to the FILLER. So I don't see a need to change the filter since I haven't started the car up and the AT fluid never got that far.
I just finished flushing it out. I started with some old oil that I had. (yes this time it was actually oil)
I ran about 5 or 6 quarts to flush it out before adding new stuff.
Hopefully that helps. I'll let you know if I get a mushroom cloud though...
Old 02-22-2012, 04:26 PM   #8
rkramer
Member#: 118209
2015 WRX Limitec
I see its too late already, but in retrospect, you would have been fine...
Old 02-22-2012, 04:31 PM   #9
Getrag
Member#: 300804
Thanks for all the good quick input guys, I have read a lot of posts but this is the first time I've had to post an issue. Good community and help, thanks.
Old 02-22-2012, 04:41 PM   #10
i_adz
Member#: 281829
04 wrx
02 ts DD
ops, thought you said filter.... but a little bit of atf wont do much when its mixed with about 5qrts of oil so you should be okay
Old 02-22-2012, 07:37 PM   #11
kyleyap
Member#: 214088
1995 WRX Type RA
JDM YO!!
Ive been told you can use ATF as an engine flush
kyleyap is offline   Reply With Quote
Old 02-22-2012, 08:04 PM   #12
rallymarty
Member#: 17418
2003 4Runner
Nothing to worry about
rallymarty is offline   Reply With Quote
Old 02-22-2012, 08:16 PM   #13
ganzhimself
Member#: 252648
2010 Mini Cooper
Pepper White
ATF won't hurt anything... It's a lubricant. I've used it as an "engine flush" before, it has a high detergent profile, gets things good and clean.
ganzhimself is offline   Reply With Quote
Old 02-23-2012, 06:54 AM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
is this a real thread????
i dont believe it...
Old 02-23-2012, 01:46 PM   #15
RumblinWagon
Member#: 303383
2002 PSM Wagon Stg2+
tuned
Its true you can put a small amount of AT fluid into your motor oil and run it for a few mins and then drain the oil. It will clean out alot of sludge buildup almost instantly but I would immediately drain completely and refill using only motor oil. I've seen this done and its impressive but I wouldn't do it on my car just because I spoil it and am meticulous when it comes to fluids.
RumblinWagon is offline   Reply With Quote
Old 02-27-2012, 06:34 PM   #16
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Nope, it's all a bad dream. Now wake up before the noob stabs you!
Bacon117 is offline   Reply With Quote
ATE, Subaru LSD Oil, and Redline Fluids IN STOCK! OEM Gaskets, Oil Filters and More!! OAKOS Automotive Car Care & Detailing 164 12-14-2012 03:44 PM
Places to get rid of oil/trans fluid in Dutchess? moss Tri-State Area Forum 19 11-26-2007 11:27 AM
Rear Diff Fluid Change at 30K in STi? jsavage Service & Maintenance 5 09-07-2005 03:08 AM
Doing an AT fluid swap in a few days...do i NEED to change the filter? kaisersouse Normally Aspirated Powertrain 8 08-30-2005 10:14 PM
ATE brake fluid in DFW at reasonable $$? eta_Legacy Texas Impreza Club Forum -- TXIC 4 08-11-2005 10:12 AM
