Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Go Back   NASIOC > NASIOC Subaru Models > BRZ Forum
Old 02-29-2012, 07:18 AM   #26
Deslock
Member#: 7959
2013 BRZ limited
1999 Nova RTS
Thanks for posting this... I look forward to following your progress.
Deslock is offline   Reply With Quote
Old 02-29-2012, 03:08 PM   #27
saggioWRX
Member#: 18994
08 GTS
10 CTS W
in for details, and see your progress
saggioWRX is offline   Reply With Quote
Old 03-01-2012, 03:28 PM   #28
trick3d
Member#: 202146
2010 evoru
GG
Oh this is exciting.
I run the rs3's on my X in 265/35 and love them. Sub'd.
trick3d is offline   Reply With Quote
Old 03-01-2012, 06:33 PM   #29
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Annnnnd....Ordered...
CONFIRMED:
Order #23714
DZE01 PKG
Limited, 6spd manual , White ...Let the fun begin..
Bill
Old 03-01-2012, 07:41 PM   #30
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
Awesome!! Congrats!!
WRX_02_227 is offline   Reply With Quote
Old 03-01-2012, 07:56 PM   #31
trick3d
Member#: 202146
2010 evoru
GG
Congrats bill!!!!!!
Old 03-02-2012, 02:20 PM   #32
Tainen
Member#: 82251
2001 e46 330i sport
13 SWP BRZ
Got mine ordered as well 6mt SWP limited, first in line at my dealer. I will be following this thread closely...
Tainen is offline   Reply With Quote
Old 03-05-2012, 08:03 AM   #33
flu1d
Member#: 141586
07 STi
I think we all got white
flu1d is offline   Reply With Quote
Old 03-05-2012, 11:29 AM   #34
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
FT86club has a pie graph out regarding color. Of the members that preordered on that specific forum, nearly half are WRB.
OrbitalEllipses is offline   Reply With Quote
Old 03-05-2012, 08:30 PM   #35
goleee33
Member#: 301701
2012 WRX 5-Door
Still no pricing but you can pre-order?
goleee33 is offline   Reply With Quote
Old 03-06-2012, 08:24 AM   #36
Meythl
Member#: 310680
Correct. Most every dealer has done refundable deposits so you can get your cash back if you don't like the price. If you think you might want one it was a no-brainer to put an order in for the trim/color/transmission you wanted. If you don't like it, you could always pass on the car after the prices are released or the car hits the dealer.
Meythl is offline   Reply With Quote
Old 03-06-2012, 06:35 PM   #37
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Originally Posted by Scooby South View Post
-Steering is Rear Steer vs. Front Steer normally found on Subaru...so when you add camber....usually it toes' out the alignment...for general purposes...now. with the rear steer it should toe 'in'...sooo physical alignment will now become the norm at events...we'll see
What do you mean by physical alignment will be the norm at events?
I'm totally ignorant when it comes to suspension talk
DoctorNick is offline   Reply With Quote
Old 03-06-2012, 07:20 PM   #38
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Awesome! I'm excited to see how this goes!
jamesfacts is offline   Reply With Quote
Old 03-07-2012, 07:52 AM   #39
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
I think he's referring to the way you can index your camber plates on a current Subaru for the amount of camber you want for autocross and when you get to an event you simply jack the front end up, loosen the camber plates and slide the strut tops inward (and snug them down again). This adds both camber and toe-out due to the location of the steering rack. It means you can easily swap between street and track alignment settings.
The BRZ is going to require more work.
Old 03-07-2012, 08:04 AM   #40
dowroa
Member#: 17498
No More Subarus :(
Only a truck, for now. ;)
Ah.... so, we can slam the plates, and then just get the toe close with a few turns on the adjusters.
Just sounds like I will add camber and fix the toe at home to be slightly out, and then leave myself some "wiggle room" for more camber, based on the surface and conditions.
That, or run tons of rate and bar to eliminate a lot of dynamic camber movement (I don't know if that is possible ) and I am slightly lazy
- brian
dowroa is offline   Reply With Quote
Old 03-07-2012, 01:20 PM   #41
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
^^^^ This...
on older cars...when you cambered...the car automatically with Toe out... = Good...
now with the different steering..it will Toe in when Cambered...sooo you have to adjust it back out to get the toe correct..then adjust it back in when you want to run normal DD settings...
Bill
Old 03-07-2012, 01:22 PM   #42
dowroa
Member#: 17498
No More Subarus :(
Or... just set the camber, drive it, and don't worry about the front end camber setting as much!
(does it matter on RWD when you can get the car to rotate now?)
- brian
Old 03-07-2012, 01:29 PM   #43
onefasazn
Member#: 45574
2003 NB2 E-Street
2004 GGA - Prodrive
Where are you getting your Whiteline parts?
Just curious since there hasn't been any word from them on development.
onefasazn is offline   Reply With Quote
Old 03-07-2012, 01:52 PM   #44
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Waiting on Whiteline...supposedly they are getting one here in the next month...in the mean time...Kartboy and TIC ...
Old 03-07-2012, 02:18 PM   #45
Thongpocket
Member#: 248749
2013 BRZ Limted
Dark Grey Metallic
I wonder if we will be able to custom tune the electric steering for more or less response with aftermarket gear?
Thongpocket is offline   Reply With Quote
Old 03-08-2012, 11:17 AM   #46
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Niiiiiice....At least some Good Quality parts coming...
Old 03-08-2012, 01:27 PM   #47
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Not in Street Touring.
Old 04-17-2012, 09:21 PM   #48
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Proposed mods:
2013 Subaru BRZ Limited Satin White Pearl ????
-Wrapped in Flat White
-AST sport 2way suspension (back up KW)
-TIC/Vorshlag Camber Plates
-Whiteline Bars(In development)
-Stainless lines
-Motul Fluid
-Hawk HP+ Pads
-Catback exhaust(nameless performance/in development)
-CAI
-Kartboy shifter(in development)
-Kartboy Bushings(in development)
-17x9 Wheels
-245-40-17 Hankook Ventus RS-3 (already purchased)
-OS Giken 1.5 Rear Mech Diff(Available)
-TRD sport Seats(Available)
-STi Front lip(Available)
-TRD Sideskirts(Available)
-Standalone ECU w/tune(in development)
thats about it for now...that and trying to make it competitive..
my 2012 Helmet proposal..
well...more stuff starting to arrive...
17x9 42 offset..18.7 pds...
Old 04-26-2012, 10:36 AM   #49
kingofl337
Member#: 200340
2005 Baja Turbo
Dark Blue
Are you worried at all that putting that mutch rubber on this car will make it feel slow?
I've read multiple times that part of the reason they used Prius tires is to allow the car to be playful with it's limited power output. I'm hoping that the tuners will be able get it to around 200hp at the rears NA.
kingofl337 is offline   Reply With Quote
Old 04-26-2012, 11:38 AM   #50
Calamity Jesus
Member#: 44501
1984 That's *Sir*
He's doing this for autocross... not the street. If it feels slow he'll be doing something right.
The Prius tire thing is a bunch of BS. They're 240 treadwear tires. Not great, but not at all slippery. They are the tires from the JDM Prius sports package and aren't standard equipment on any US Prius. The BRZ is playful at the limit because Subaru did a fantastic job of tuning the car to be predictable at the limit.
5eat swap, and so it begins :) q's for subaru techs blaznc Transmission (AT/MT) & Driveline 26 05-30-2011 11:53 PM
Let the fun begin :) kmurphy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-31-2009 02:53 PM
'07 2.5i ... just the beginning :) Pirce39 Member's Car Gallery 26 10-25-2008 01:05 PM
let the odyssey begin ... actually it begins on 2-7-08 [email protected] Off-Topic 10 02-05-2008 12:17 PM
Hydra where to begin :) Sparcomx Other Engine Management 6 11-05-2005 12:47 AM
