Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 07-09-2012, 10:29 PM   #776
shane86
Member#: 67387
04 WRX - STX
05 LGT Limited Wagon
Originally Posted by Scooby South View Post
Well Played Shane..but 'this guy' was looking for you..
[INSERT PICTURE OF STUPID CAMBER TIRE CAR HERE]
Oh snap... he musta heard me talking smak about camber tires yo.. including things like "That's completely ****ing pointless on any car in a class where you can get enough camber through suspension setup like... oh, i don't know.. STU"
shane86 is offline   Reply With Quote
Old 07-09-2012, 10:36 PM   #777
Keif
Member#: 107302
Yeah, what the hell? I couldn't help but check out the website.
Keif is offline   Reply With Quote
Old 07-10-2012, 07:14 AM   #778
KC
Member#: 442
16 SS
00 S2000
SCCA Solo Rules 13.3.F...
Each tire model must be sold in at least four rim diameters with a total of at least six sizes.
CamberTire does not meet the requirements. Was that person running??? Shouldn't have. At that, those look like an R-Compound version... in STU?
--kC
KC is offline   Reply With Quote
Old 07-10-2012, 09:07 AM   #779
wrx wagone
Member#: 97301
2005 WRX Wag-Tow Rig
125 FM - QRE Invader
Wow... Cambertire is amazingly stupid.
wrx wagone is offline   Reply With Quote
Old 07-10-2012, 10:59 AM   #780
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
No offense to Bill (I probably wouldnt have done any better) and Colin is in a highly prepped S2000 but you can see why Colin is a national champ, almost no drama in that run even when he turned the wipers on. He maintained so much more speed through a lot of those corners and was able to get on the gas a lot earlier.
Old 07-10-2012, 01:50 PM   #781
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
none taken..... he is amazing smooth and his car is 'completely' setup... to be 'only' 3 secs down to him with the level of prep I have down, I feel is a feat within itself..
good stuff tho..
Bill
Old 07-10-2012, 02:48 PM   #782
Draken
Member#: 16
1968 Saab
Sonett II V4
--kC
The BRZ isn't legal in STX either, but it ran...
Draken is offline   Reply With Quote
Old 07-10-2012, 03:39 PM   #783
CopperTopNWOR
Member#: 295724
2013 BRZ Limited
The BRZ actually may be legal through the leeway they give local level usage. It isn't legal for National Tour or Pro Solo currently. However, the book allows for the NOC exemptions. Though if you went purely off the NOC given displacement he should run STC. But they figure the car will likely get moved into STR or STX not STC. Since STR doesn't have a NOC allowance that leaves the other STC, STX, STU at the discresion of the local board.
CopperTopNWOR is offline   Reply With Quote
Old 07-10-2012, 04:51 PM   #784
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Their website says they are indeed R-comps.
BeBop86 is offline   Reply With Quote
Old 07-10-2012, 07:21 PM   #785
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
My Co-driver, Bart, and his run on Sun. power seems to be the issue
and it was a Divisional, the governing body that put on the event can Class the BRZ any where they want. it seemed to be competitive in STX..
the rule in question is: Apendix A:
STX:Sedans & Coupes NOC (nonsports-car-based; 4-seat minimum; 3.1L to 5.1L normally aspirated or up to 2.0L forced induction)..Well since the BRZ is Sports Car Based... The rule doesn't distingush what is a Sports Car..
APPENDIX A - AUTOMOBILE CLASSES
It is the intention of SCCA® to class all essentially identical vehicles
from the same manufacturer (which differ only cosmetically or in nominal
marquee designation) in the same class. If a version is omitted from
the class listing, and is otherwise eligible for the category, then its classification
will be the same as the equivalent car which is listed.
All unclassified cars will compete in Super Stock (SS) until classified by
the SEB, unless covered by a “catch-all” description. To use the catchalls
at the end of the specific car classes in Appendix A, start from Super
Stock (SS) and work down the classes until a class is found. Such
unclassified cars will not be eligible for Solo® National Tours or
the Solo® National Championships. Members should look for a
Tech Bulletin in an early current-year issue of the official SCCA®
publication (Fastrack® News) for details or contact the National
office.
See the following page for vehicles which are excluded from the Stock
category.
For Stock Category vehicles, the vehicle manufacturer’s specifications
shall be used for specific wheel diameter and maximum rim width specifications.
ABBREVIATIONS:
AWD - All-wheel drive
FWD - Front wheel drive
IRS - Independent rear suspension
NOC - Not otherwise classified
N/A - Normally aspirated
RWD - Rear wheel drive
S/C - Supercharged
(n)v - refers to number (n) of valves per cylinder
V(n) - refers to number (n) of cylinders
Old 07-10-2012, 08:35 PM   #786
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
CENTDIV Results are up.
CENT DIV 2 Day Results by Class
CentDiv Index Results for both days combined..
2nd and 5th in STX
53rd and 66th on index...out of 141 drivers... with some VERY prominent names leading the way.. Overall, I am very happy with the results. goal was to be in the top 50% in Class and top 50% on Index..
Old 07-11-2012, 01:07 PM   #787
KC
Member#: 442
16 SS
00 S2000
Cars can be classed wherever the local board says so for non-national events, should they so desire.
CamberTires, not legal in any class.
--kC
Old 07-11-2012, 01:08 PM   #788
KC
Member#: 442
16 SS
00 S2000
2nd and 5th in STX
2nd and 5th? Cool.
2.5 seconds behind Neil? Were you trying to sandbag the results so it goes in STX?
--kC
Old 07-11-2012, 06:44 PM   #789
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
2nd and 5th? Cool.
--kC
nope.... not at all...We decided to drive it 100% and let it fall. We adjusted on the car for all of Sat runs... and part of Sundays. It was only the last two runs between me and my co-driver did we finally figure out that everything was right with handling. The Drag Race Start on Sunday killed us by a second compared to Neal. thats ok, Pretty happy with the results thus far.
Bill
Old 07-11-2012, 06:51 PM   #790
PKer
Member#: 27647
06 MX-5-STR 03WRX
(ret), 08 Titan-Tow
--kC
Legal in Prep/Mod.
This was more interesting to me:
4 1 STS 195 Andrew Canak 1991 Mazda Miata Mariner Blue 51.245 50.781 123.370 *0.827 102.027 0.109 0.840
5 1 STC 177 Jason Frank 1989 Civic Si - Redshift Black 50.754 51.475 124.671 *0.820 102.230 0.203 1.043
I'm glad ST and STS were not combined, the top players have been consistently proving Rick Ruth right, especially this year.
PKer is offline   Reply With Quote
Old 07-12-2012, 11:06 AM   #791
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
I did record stock heights..as well as stock alignment......yeah Its pretty much a crapshoot right now...
and yeah the neg camber is wild...never had that much range before ...EVER..
Bill
Not trying to rain on anyone's parade...I love what you are doing. But i'm not sure why you have never seen this much camber before. My bugeye with Vorshlag camber plates has this much adjustment. My wife's 2011 STi with BC camber plates have .2 degrees less. I have seen many GC's with easlily this much camber.
Dunno what type of suspensions you were using before...but -4.5 isn't unheard of on any subaru with a 245 tire on it.
Squidz is offline   Reply With Quote
Old 07-12-2012, 12:13 PM   #792
CopperTopNWOR
Member#: 295724
2013 BRZ Limited
I think he is noting the range on the plates as being large. From one end of the settings to the other end being such a large difference. At least that is how I read it.
Old 07-12-2012, 12:15 PM   #793
Squidz
Member#: 142608
2003 Sonic Yellow
Ahh...that makes more sense.
Old 07-12-2012, 06:48 PM   #794
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
exactly..
Bill
Old 07-12-2012, 08:08 PM   #795
CopperTopNWOR
Member#: 295724
2013 BRZ Limited
I am now concerned. I seem to understand Bill. This can't be a good sign.
Old 07-12-2012, 09:33 PM   #796
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Old 07-13-2012, 01:09 AM   #797
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
i got to that point years ago
Old 07-13-2012, 04:05 PM   #798
CopperTopNWOR
Member#: 295724
2013 BRZ Limited
Ok, back on the real topic. When do we get more results or more pictures of things you have changed?
Old 07-13-2012, 06:28 PM   #799
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
what are you wanting???
Old 07-14-2012, 04:40 PM   #800
Zach9734
Member#: 186196
05 WRX
A BRZ of our own. That's what everyone wants.
Maybe we can take one of your pictures, use some Weird Science magic and turn it into the real thing...
Zach9734 is offline   Reply With Quote
Subaru BRZ STI Concept to be shown at upcoming LA Auto Show Nick NASIOC Official News, Articles and Polls 332 08-02-2012 01:11 PM
Any word on the BRZ STI? BoxingSubie News & Rumors 8 04-23-2012 10:15 AM
The BRZ STi Concept--Coming to LA Monkey_Boy BRZ Forum 108 12-27-2011 04:24 PM
BRZ STi Concept LA Auto Show Video and Pics aagorsa BRZ Forum 11 12-19-2011 09:04 PM
World Debut of Subaru BRZ STi Concept Pics aagorsa General Community 30 11-17-2011 11:08 PM
