Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 08-18-2012, 05:19 PM   #851
BlkWRXWag
Member#: 31821
2015 DS WRX
Try 240-250WHP for a STR S2K.
BlkWRXWag is offline   Reply With Quote
Old 08-18-2012, 05:52 PM   #852
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
hmmm ..Really??? wow.. I was going off a locals STR Build who's nationally competitive...well thats quite a bit of difference then..:/....
Thanks Max..
Old 08-18-2012, 07:39 PM   #853
purplewrx
Member#: 315291
2012 WRX
PBP
You have some proof on this ? Most str s2000 including the one I drove made 220-230 after tune with header and catback
purplewrx is offline   Reply With Quote
Old 08-18-2012, 07:53 PM   #854
BlkWRXWag
Member#: 31821
2015 DS WRX
Just what the local guys tell me they got on the dyno. Having driven one, I have no reason to not believe them.
Obviously, no dyno reads the same. The car I drove was tuned by Surgeline in the Northwest.
Old 08-18-2012, 08:06 PM   #855
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Yeah Bill is probably talking about Colin Fiedlers STR car which is certainly prepped to what the rules allow and I think it made 220whp/150ft-lbs. Obviously dynos all read differently but 240+ is a bit optimistic. Probably doable on an e85 tune if the injectors can keep up.
I think it's a little early to know what a fully prepped Toyobaru will do since headers are scarce as is tuning. The only tune with header I saw showed no gains for the header over the regular tuning. He was able to get close to 200whp on e85 with basically just tuning. Should be interesting to see developments over the next few months. I'm committed to CS next year but more power sure would be fun.
Old 08-18-2012, 10:47 PM   #856
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
^^^ Yep...thats the one
Bill
Old 08-19-2012, 12:12 PM   #857
CopperTopNWOR
Member#: 295724
2013 BRZ Limited
I have heard that 240 number from other people though. I know Matt Braun was talking about that as being the number for the STR S2000, might just be from dyno's that read high though.
CopperTopNWOR is offline   Reply With Quote
Old 08-20-2012, 08:43 PM   #858
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Mild Power mods today...
K&N panel Filter with sound Generator Delete..and a Kartboy Prototype Lightweight Pulley...= better power and noticeable torque gain coming off the corner... ME LIKEY
Old 08-20-2012, 09:53 PM   #859
MurphysLaww
Member#: 171245
99 328i
STX for 2013?
I wish my $$$ situation was different and I was going to Nats in the fully prepped 08' WRX, (and JW2 as well to showcase what the car truly had in it.) I think the 2.5 WRX probably have pretty close to the same performance potential when it comes down to it as the BRZ, if not a bit more.
All this talk of the BRZ possibly being an overdog still has to wait for anything to beat a well driven E36. Will they be in the trophy's ? No doubt, well driven and prepped, but that last second of the 2 1/2 seconds is obviously the hardest to come up with and will put you 6-8 places down this year, I'll wager(not including the aliens like Heitkotter and Tovsen)
I'll be interested to see how Todd Roberts from our club does in his MS-3.
When he switched to wider tires up front, he was pulling away, and has been performing really well in PAX locally, and our club's pretty full of people prepping for nationals.
https://axwaresystems.com/axorm/file...ug2012_pax.htm
All in all, with the addition of the BRZ, it will really make STX the most diverse, and if you want it to be, affordable class in Solo(if you'd like a car that still has the possibility of being daily driven to an extent). I'll be putting the E46 in it likely next year, with of course, no aspirations whatsoever.
MurphysLaww is offline   Reply With Quote
Old 08-20-2012, 10:32 PM   #860
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Ok..Quick review of Current ST legal mods implemented so far:
2013 BRZ limited
KW Variant 3 Coilovers with RS camber plates.
17x9 Rota DPT 42 offset
Hankook RS-3 245/40/17
Kartboy Rear Endlinks on Stock Rear Sway Bar
Stock Front Sway Bar
Kartboy Differential Bushings
Kartboy knuckleball
Kartboy Oil Cap
JW2 Muffler Delete turn-down
9lb DEKA battery
K&N Panel filter
Custom Intake tube with Sound Generator Delete
Kartboy LW Crank Pully
P&L Motorsports Stainless Brake lines
Motul Dot 5.1 Fluid
Current weight 2634...fighting weight...with 1/4 tank of gas..
Future:
Titanium catback Exhaust (Weight)
Header with hi-flo Cat
Tune
Sparco/Recaro Light-weight seats
more later...
Bill
Old 08-21-2012, 07:48 PM   #861
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Just in: SUBARU Service Bulletin: 02-132-12 dated today explains the procedure for the P0019 and other codes... Explicit instructions on how to fix/duplicate/Troubleshoot along with warranty times..
Advise from my dealer...Drive it until the light comes on again...bring it in..and they will fix it...hope it doesn't come on during my trip to Indy...
Bill
Old 08-21-2012, 11:01 PM   #862
tuskenraider
Member#: 65699
15 WRX
WR Blue
Saw the first one at a Toyota/Lexus used car alot today......thought about test driving it to see what they think it's worth.
tuskenraider is offline   Reply With Quote
Old 08-21-2012, 11:11 PM   #863
ABQautoxer
Member#: 198231
2007 Not a Subaru
Drive it. It will surprise you both good and bad. If it has under 1000 miles, dont be surprised if its even slower than you expected.
ABQautoxer is offline   Reply With Quote
Old 08-21-2012, 11:12 PM   #864
zzyzx
Member#: 815
2013 Boss 302 White
2008 S2000 CR ABP
Bill
That's great news!
Given that it's a TSB, I'd take it right in and tell them to fix it ASAP. No waiting around and no fooling around... At this point I don't know how the dealer could rationalize any other alternative.
zzyzx is offline   Reply With Quote
Old 08-22-2012, 12:19 AM   #865
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
still has to have the code present to conduct TSB...
and .... there is a flow chart
Right now I am on leg 2 of the chart... waiting to get leg 3..
Bill
Old 08-22-2012, 09:14 AM   #866
silverhks
Member#: 242402
Bill
Oooohhh! The famous THIRD leg!
silverhks is offline   Reply With Quote
Old 08-22-2012, 04:11 PM   #867
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I know I mentioned the E85 tune before but saw some new results on the ft86 forum.
http://www.ft86club.com/forums/attac...4&d=1345608361
Makes quite a bit more power than the 93 tune and the fuel system seems up to the task. This isnt tuned to the bleeding edge either.
It looks like Ecutek may be the only tuning solution on the block for some time unless you want to go piggyback or standalone. I messaged someone at Cobb I know from way back and they have no interest in building anything for the car, not even an exhaust.
Old 08-23-2012, 09:38 PM   #868
MurphysLaww
Member#: 171245
99 328i
STX for 2013?
I didn't realize they had such low torque numbers, but I guess it makes sense, being that it's a 4 cylinder and I'm comparing it in my head to 6's with at least an extra 0.5 liter.
Still, though, at under 2600 lbs, if the other lightening mods get done, I gotta guess that it will still be pretty close to a well prepped e36, when weight is traded for torque.
It will be interesting to see.
Old 08-23-2012, 10:35 PM   #869
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
That dyno sheet I linked to might be the lowest I've seen for the car. Most dynojet sheets are around 165whp/140ft-lbs. it was more about the percentage gained over stock with the tune.
The car is only rated at 151ft-lbs stock, just a 2L 4 cylinder
Old 08-23-2012, 11:26 PM   #870
lavid2002
Member#: 226864
Wow! I LOVE that new oil filter location! Subarus had one of the best filter locations to begin with, right on the bottom orthogonal to the ground. I know it's not the point of the thread but it's blowing my mind. Epic!
lavid2002 is offline   Reply With Quote
Old 08-23-2012, 11:33 PM   #871
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
Ok.. I did do a mod on Thursday. I updated my intake system, One of my first Power mods. I deleted the Factory Intake Tube with the sound Generator (-5 lbs) and replaced it with a Aluminum tube, some Silicone Ends and a K&N Panel filter... Throttle Response was noticeably more snappy and it felt like the Power band opened up a bit. and its just more efficient for flow over stock. Total Cost about $100 as a DIY project. Dyno will tell if I actually picked up any HP. but for now..I like it.
That is actually a nice intake setup for DIY. Is it legal? Can't remember if intakes were unlimited in ST.
Hrmm...i heard differently from the guys here in Texas. That was a while ago, before the car was released though.
Hope it's not true.
Squidz is online now   Reply With Quote
Old 08-24-2012, 10:40 AM   #872
KMScooby
Member#: 291745
2005 WRX STX
In street touring you can do anything you want on the inlet side of the throttle body. Can't touch the throttle body its self though. Long story short, it's legal.
KMScooby is offline   Reply With Quote
Old 08-24-2012, 05:48 PM   #873
Zach9734
Member#: 186196
05 WRX
Hope it's not true.
Its not.
http://www.cobbtuning.com/Subaru-BRZ-2013-s/70732.htm
Zach9734 is offline   Reply With Quote
Old 08-24-2012, 06:54 PM   #874
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Those are all carryover parts from other cars which happen to work on the BRZ. They haven't developed anything specific for the BRZ and according to multiple sources they won't be.
Old 08-24-2012, 06:58 PM   #875
Squidz
Member#: 142608
2003 Sonic Yellow
Find it hard to believe given their perpensity for fabrication and the production abilities they have in Austin. Not saying you are wrong...I don't know for sure...just seems like a lot of money they'd be letting slip through the cracks.
I know Treys not much for letting money slip anywhere.
Subaru BRZ STI Concept to be shown at upcoming LA Auto Show Nick NASIOC Official News, Articles and Polls 332 08-02-2012 01:11 PM
Any word on the BRZ STI? BoxingSubie News & Rumors 8 04-23-2012 10:15 AM
The BRZ STi Concept--Coming to LA Monkey_Boy BRZ Forum 108 12-27-2011 04:24 PM
BRZ STi Concept LA Auto Show Video and Pics aagorsa BRZ Forum 11 12-19-2011 09:04 PM
World Debut of Subaru BRZ STi Concept Pics aagorsa General Community 30 11-17-2011 11:08 PM
