Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 09-24-2012, 03:03 PM   #901
makofoto
Member#: 25243
2006 Legacy Outback
We had something like a total of 8 BRZ/FR-S's over our weekend of AX'ing at CA Speedway! Max was way fast with his BRZ on old 245 RS-3's and lowering springs. Some snaps and videos to follow
makofoto is offline   Reply With Quote
Old 09-24-2012, 03:10 PM   #902
ABQautoxer
Member#: 198231
'06 WRX SGM
Any with your super slick higher FPS camera?
ABQautoxer is offline   Reply With Quote
Old 09-24-2012, 03:51 PM   #903
BlkWRXWag
Member#: 31821
2006 STR MX5
WRB BRZ Limited
It certainly was impressive for just Eibach Pros and crash bolts. The car felt slow and soft compared to my normal race cars, but I don't do stock!
The balance, however, was super. I could control the car with the throttle and it was neither pushy, nor loose so I could drive very aggressively.
The best stock car I have ever driven was an MSR MX5... not sure it's in that league, so I think it may struggle in CS at the highest levels. STX - well, if I had the money, I would build it just to find out.
I still don't think it would hang in STR unless they really manage to unleash a lot more power.
BlkWRXWag is offline   Reply With Quote
Old 09-24-2012, 04:00 PM   #904
04trailsti
Member#: 179170
A lot of feed back has said that the BRZ is much more pushier than the FRS. Have y'all experienced any bad understeering.
04trailsti is offline   Reply With Quote
Old 09-24-2012, 04:00 PM   #905
ABQautoxer
Member#: 198231
'06 WRX SGM
I agree. I've driven a stock MSR on Kumho XS and my BRZ stock (with crash bolts) on Star Specs and I believe I'm measurably faster in the MSR and it feels better balanced. The problem I have in my BRZ is I get some oversteer in transitions fairly easily which I think is primarily is from engaging the rear bumpstops harshly. It can be driven around and I now will try to work on it with setup but so far I feel like the BRZ will be a bit behind the Z0K/MSR.
Mine certainly does not have understeer. Its really good on throttle and steady state. Turn-in is extraordinarily good.
Old 09-24-2012, 04:45 PM   #906
makofoto
Member#: 25243
2006 Legacy Outback
Old 09-24-2012, 04:49 PM   #907
BlkWRXWag
Member#: 31821
2006 STR MX5
WRB BRZ Limited
Holy crap - awesome!
Old 09-24-2012, 04:54 PM   #908
makofoto
Member#: 25243
2006 Legacy Outback
loose white FR-S ... not getting it to save at 60 FPS?
http://public.fotki.com/makofoto/201...s-desktop.html
Old 09-24-2012, 04:56 PM   #909
04trailsti
Member#: 179170
Cool videos man!
Old 09-24-2012, 05:04 PM   #910
BlkWRXWag
Member#: 31821
2006 STR MX5
WRB BRZ Limited
Old 09-24-2012, 05:09 PM   #911
ABQautoxer
Member#: 198231
'06 WRX SGM
I love how Max is trying to sell BRZs while on the mic in the FRS video. Very cool vids Mako.
Old 09-24-2012, 05:13 PM   #912
BlkWRXWag
Member#: 31821
2006 STR MX5
WRB BRZ Limited
Unfortunately, Mako missed my "You can tell it's an FRS because the driver has a flat-billed helmet" comment.
Old 09-24-2012, 05:25 PM   #913
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
^^^^ Hahahaha
Old 09-24-2012, 05:26 PM   #914
makofoto
Member#: 25243
2006 Legacy Outback
Old 09-24-2012, 07:07 PM   #915
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I was able to drive a car with a 93 octane Ecutek tune last night. It was an off the shelf one. The pull through the torque dip was definitely better and the power up top was noticeable as well. Not mind blowing though, I think getting a custom tune and using E85 is going to get the most out of the car. They are fairly close to adding map switching to make switching between maps easier and there was some rumbling of adding a flex fuel sensor so you wouldn't even have to run a different map specific to E85.
One interesting datapoint is John (Visconti) so far has been unable to get more power out of the car with a tune and full exhaust, once tuned the car makes the same power with an exhaust as it does without.
Old 09-24-2012, 07:40 PM   #916
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
car indexed 15th yesterday out of 151. For reference, C-Stock National Champion Chris Fenter indexed 3rd ... Car was down to him by 2.6 secs Raw..
Old 09-24-2012, 07:48 PM   #917
Subiemax
Member#: 30691
2013 FRS
RED
So, save your money and do without exhaust?
Subiemax is offline   Reply With Quote
Old 09-24-2012, 09:43 PM   #918
bdi
Member#: 66033
05 STi
Does full exhaust = headers and high-flow cat?
bdi is offline   Reply With Quote
Old 09-24-2012, 09:48 PM   #919
MNbiker
Member#: 18148
'08 Subaru WRX
Dark Gray
... and there was some rumbling of adding a flex fuel sensor so you wouldn't even have to run a different map specific to E85...
And you're using what allowance in STX to legally add a sensor?
MNbiker is offline   Reply With Quote
Old 09-24-2012, 09:50 PM   #920
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Weight savings and sound would be the two reasons I can think of to replace the exhaust.
I don't think he has tuned a car with a full exhaust and header with a high flow cat. When he tuned a car with an Agency Power catless header and stock exhaust it was the same story, the car didn't make any more power with the header than it did with just tuning.
That's just one tuner though. TheShop was able to see gains from adding parts and tuning afterwards...
Run 2(Red) - Stock
Run 12(Blue) - Tune Only (ECUTek)
Run 19(Green) - Tune w/ Catback Exhaust (Perrin)
Run 27(Purple) - Tune w/ Catback Exhaust & Intake (Perrin/Injen)
Old 09-24-2012, 10:02 PM   #921
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I'm not driving in STX Steve, I stopped keeping track of those rules like 8 years ago. It would be nice if you could add a flex fuel sensor...
Old 09-24-2012, 10:07 PM   #922
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
yes, but the rules are specific now on what type of cat you can run it has to so many Cells per inch...I sent that section of the rules to Jason at Nameless...and he indicated theirs fits the bill which is excellent news. So I am wondering exactly how much weight the car can lose and still make power with their exhaust.
Bill
Old 09-24-2012, 11:00 PM   #923
bdi
Member#: 66033
05 STi
Bill
Hrm, didnt know the rules changed. If the Milspec ones fits the bill, I recommend that one.
http://www.mil-spec.org/Universal/
They make a 100 and 200 cell. The 200 cell has been making good power on Josh and I's STU STi's problem free.
Old 09-26-2012, 01:09 PM   #924
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
For my own reference...
Replacement converters must have a minimum catalyst density of 100 cells per inch and minimum substrate length of 3 inches. (Ref... OCT 2012 Fastrack)
Old 09-26-2012, 01:35 PM   #925
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
http://i190.photobucket.com/albums/z...asvse85104.jpg
Those are the latest results for an E85 tune basically no more torque dip. And also at least with the E85 tune changing the exhaust or intake had no real effect on anything over a stock car.
Subaru BRZ STI Concept to be shown at upcoming LA Auto Show Nick NASIOC Official News, Articles and Polls 332 08-02-2012 01:11 PM
Any word on the BRZ STI? BoxingSubie News & Rumors 8 04-23-2012 10:15 AM
The BRZ STi Concept--Coming to LA Monkey_Boy BRZ Forum 108 12-27-2011 04:24 PM
BRZ STi Concept LA Auto Show Video and Pics aagorsa BRZ Forum 11 12-19-2011 09:04 PM
World Debut of Subaru BRZ STi Concept Pics aagorsa General Community 30 11-17-2011 11:08 PM
Message Board Statistics All times are GMT -4. The time now is 05:58 PM.
