#1 |
Member#: 304052
Vehicle:2010 WRX Black |
Does anyone ever get rocks lodged in between the rotor and brake pad?
#2 |
Member#: 217208
AKIC
Yep, or inside the ebrake drum.
#3 |
Member#: 153687
AKIC
Vehicle:2002 Black RS |
Try driving in reverse if you haven't already. Or just keep driving around until it falls out.
#4 |
Member#: 304052
It sounds like metal on metal all the time, not just when I hit the brakes.
#5 |
Member#: 285848
AKIC
Vehicle:1995 Impreza RaceCar 2007 Legacy SE OBP hers |
Happens a lot on my STi, probably just rock.
#6 |
Member#: 156712
AKIC
Vehicle:1991 Legacy SS Pearl White |
It's usually a stone stuck between the backing plate and the rotor. It sucks, it's loud. The thin metal of the backing plate seems to amplify the noise. Driving in reverse works to get the stone out most of the time.
Also, I once had a rock stuck between the brembo caliper and the bbs wheel on my 05 sti. Similar noise, but gouged the inside of the wheel a little bit before I could get to a spot to drive in reverse to get it out. Worst time I had it happen was on my 01 2.5rs, I had to take off my wheel and dislodge the stone by hand. I think I used a long screwdriver. |
#7 |
Member#: 44172
AKIC
Vehicle:2003 Lancer Evo 8 Plasti-Dip is for TOOLS |
I get it all the time, especially breakup time. I just take my wheel off and take a long skinny flathead screwdriver between the pad and rotor and knock them out. Seems to do the trick.
| Thread Tools | |
| Display Modes | |
| Loud Noise Coming from Rear | Teehsee | Newbies & FAQs | 5 | 04-28-2011 06:48 PM |
| loud noise coming from the front of the motor. | impreza062.5i | Normally Aspirated Powertrain | 8 | 01-28-2011 01:44 PM |
| VERY LOUD noise coming from engine bay | turbofox37 | Factory 2.0L Turbo Powertrain | 12 | 07-03-2010 03:26 PM |
| clunking or grinding noise coming from wheel only in turns when off the gas | csimp3 | Brakes, Steering & Suspension | 2 | 07-24-2009 03:17 PM |
| Squeaking noise coming from wheels/ brakes? | Trigun001 | Brakes, Steering & Suspension | 6 | 12-20-2006 12:21 PM |
