Old 02-20-2012, 09:15 PM   #1
wrx03.4wz
Member#: 122375
03.7 I own 2 of them
White & Black
Default Just installed new injectors and now a misfire!
It started when I installed the turbo inlet pipe, I thought it was a blown injector, so I replaced them with 600cc injectors. Misfire, Misfire, Misfire!!! And now I noticed the harness to the Cyl #1 coil, the clip to keep it in is broken! What else can it be? BTW its a hybrid motor.
wrx03.4wz is offline   Reply With Quote
Old 02-20-2012, 11:36 PM   #2
wrx03.4wz
Member#: 122375
White & Black
bump status
Old 02-21-2012, 06:56 AM   #3
GhostSenshi
Member#: 279449
2004 8.78 E/T WRX
Platinum Silver
What cylinders have the misfire? If it's just one cylinder, have you tried moving the coil pack or plugs around? Doing this helps save money instead of starting off by replacing parts.
GhostSenshi is offline   Reply With Quote
Old 02-21-2012, 08:54 AM   #4
wrx03.4wz
Member#: 122375
White & Black
Cyl #1, 2, 3 misfire WTF?
Old 02-21-2012, 08:59 AM   #5
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
Check each injector in cylinder # 4. If the misfire follows the injector then u would return them for new ones likely flow issues. Also check the coil packs for correct orientation as said previously .... Black plugs to the rear and white to the front.
krambte79 is offline   Reply With Quote
Old 02-21-2012, 10:24 AM   #6
wrx03.4wz
Member#: 122375
White & Black
Did that, the injector where changed for that very reason I also have a Walbro 255lph fuel pump I will install soon as well. Also are the coil packs Cylinder Specific?
Old 02-21-2012, 01:17 PM   #7
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
No the coil packs r not but their plugs r for firing order black to the back and white to the front
Old 02-21-2012, 04:52 PM   #8
wrx03.4wz
Member#: 122375
White & Black
just installed the Walbro fuel pump on my lunch break, its still doing it I'm going nuts.
Old 02-21-2012, 05:57 PM   #9
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
R u tuned for those injectors. Did u check the coil pack plugs for white black orientation.
Old 02-21-2012, 07:32 PM   #10
wrx03.4wz
Member#: 122375
White & Black
No im not and yes I did do you think that would help "Tuning"
Old 02-21-2012, 08:24 PM   #11
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
oh my gawd......
_______________________________
stop driving the car before you blow it to smithereens
get a tune...get a clue.....get a bus pass
are there really people this dumb out there????
Old 02-21-2012, 09:20 PM   #12
wrx03.4wz
Member#: 122375
White & Black
Originally Posted by Uncle Scotty View Post
oh my gawd......
Yep There "are there really people this dumb out there" your knowoledge and ignorance has proven that thus far, anyway, A tune ok will do, a clue? is it not why I'm asking for help? No need for a bus pass player thats what the GC8 is for? But thanks anyway
Old 02-22-2012, 12:08 AM   #13
Big Joe
Member#: 3722
2002 WRX Wagon
The ECU needs to see the correct latency and scaling for those new injectors.
Big Joe is offline   Reply With Quote
Old 02-22-2012, 12:15 AM   #14
wrx03.4wz
Member#: 122375
White & Black
ok thanks Big Joe i will just order a V2 Access port this weekend
Old 02-22-2012, 11:26 PM   #15
wrx03.4wz
Member#: 122375
White & Black
Unplugged coil pack, exhuast leaks, several vacuum leaks and a loose spark all fixed NO MISFIRES thanks for all your help still getting a tune to keep it safe!
Old 02-23-2012, 02:10 AM   #16
GhostSenshi
Member#: 279449
2004 8.78 E/T WRX
Platinum Silver
You should post everything you did with the vehicle symptoms you had in the CEL sticky for everyones future ref.
Old 02-23-2012, 11:34 AM   #17
flycaster
Member#: 60142
Grey
That's not going to help you unless you take it to tuner who uses Access TunerPro. The maps included with the AP aren't set up to work with your new injectors. You need a custom tune, pronto.
flycaster is offline   Reply With Quote
Old 02-26-2012, 02:33 PM   #18
wrx03.4wz
Member#: 122375
White & Black
Make sue you torque the spark plugs to spec, a lot o hoses due to oil and cold weather cracked, so I replaced all vacuum and coolant lines with stronger heater hose. And clamped them all, also Bosch spark plugs are not good for are cars NGK's all day. I have pics of what I did I will post them tonight.
Installed new exhaust and now car smokes... MeFryRice Built Motor Discussion 6 10-31-2010 06:02 PM
Just installed my headunit and now >:( ... rideboardr Car Audio, Video & Security 7 05-16-2010 04:10 PM
Just installed silencer delete and now car "feels" slower ScoobyNubieToo! Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 37 08-28-2005 09:35 PM
Just installed new wheels and tires!!!!! rallytim888 Tire & Wheel 1 05-25-2005 05:19 PM
just installed new rotors and pads. now parking brake needs adjustment? Wagon Joe Brakes, Steering & Suspension 8 04-19-2005 01:31 PM
