Old 02-22-2012, 09:06 PM   #1
exk20z3kid
Member#: 307921
Default 2012 WRX: driving techniques for fuel economy?
Anyone have some advice? I know these cars are a blast to drive when you open them up, but eh if you all have been to the pump lately you'd know that as fun as it is it also puts a massive dent in your wallet.
I started learning stick on a 6-speed so adjusting to a 5-speed is kind of weird. Before I would use the 6th gear for highway coasting, but not really on city streets. But with this car I am catching myself coasting at 40mph in 5th gear. Do you think this is too high of a gear for that speed? I know the manual suggests shifting to 5th at 45 but I am just so used to getting in fifth on city roads.
Do you all have any other tips that would be specific to a Subaru turbocharged engine?
exk20z3kid is offline   Reply With Quote
Old 02-22-2012, 09:15 PM   #2
SubyLarry
Member#: 289426
2002 Impreza WRX
MBP
That is not a problem at all. I shift between 2 - 2.5 RPM. I make sure my vacuum does not hit boost at all; that's it. Good luck with saving gas.
All highway = 25 mpg
Combined = 23 mpg
Freaken sucks, but I have fun doing it.
SubyLarry is offline   Reply With Quote
Old 02-22-2012, 09:50 PM   #3
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
As long as you keep the RPMs above 1,700 when you coast in gear you are using zero gas for that distance...
wrxdrvr is offline   Reply With Quote
Old 02-22-2012, 09:53 PM   #4
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
shift at about 3k in each gear. you wont be in boost much at all. dont lug around a turbo engine. it isnt good at all. 45 in 5th gear is a little too low.
424wrx is offline   Reply With Quote
Old 02-23-2012, 03:59 AM   #5
furiouswrx
Member#: 283048
2011 WRX Ltd Hatch
ignore people trying to race you and stick to the speed limits...
furiouswrx is offline   Reply With Quote
Old 02-23-2012, 11:11 AM   #6
brew02wrx
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
drive like a grandma and ignore the a-holes tailing you
simply put, if you bought this car for fun, forget about gas mileage
brew02wrx is offline   Reply With Quote
Old 02-23-2012, 11:50 AM   #7
lickitysplitwrx
Member#: 276859
I shift around 2.5-3k. I usually average 25 MPG (90% highway). But I don't care about mileage, if you are that concerned you bought the wrong car.
lickitysplitwrx is offline   Reply With Quote
Old 08-28-2012, 05:42 PM   #8
OCMDWRX
Member#: 330526
2012 WRX
Plasma Blue Pearl
I shift around 2.5k to 3k and get around 24 to 25 mpg on average I am aslo stage 2
OCMDWRX is offline   Reply With Quote
Old 08-28-2012, 06:59 PM   #9
ksrumbel
Member#: 328177
Combined = 23 mpg
I do this and I'm currently at 28.8 mpg on this tank of gas (200 miles on the tank) in my 2011 WRX. Accelerate smoothly and drive the speed limit.
ksrumbel is offline   Reply With Quote
Old 08-28-2012, 08:05 PM   #10
PleiadesSTi
Member#: 194132
2009 WRX Sedan
SSM
My 09 wrx shifts best around 3k rpm range. Gotta pay to play.
PleiadesSTi is offline   Reply With Quote
Old 08-28-2012, 08:17 PM   #11
hudsonvalleybugeye
Member#: 295068
2001 forester
Buy yourself a boost gauge and stay off the brakes. Not like gas to the floor all the time, but the brake pedal will effect your gas mileage more than your gas pedal. Good luck. And concentrate!
hudsonvalleybugeye is offline   Reply With Quote
Old 08-28-2012, 08:34 PM   #12
WRXLTD
Member#: 136314
2014 Grand Cherokee
How can that be? One would think if the engine is running (even idling), you are using some gas.
WRXLTD is offline   Reply With Quote
Old 08-28-2012, 08:41 PM   #13
RM_2
Member#: 163058
'16 BRZ Limited WRB
'06 Saab 9-2X 2.5i NGM
I'm fully stock and I get combined of about 23.3 mpg. I do about 80% highway at around 70 mph. I don't usually shift into 5th until about 50 mph.
Like a bunch of people here said...if you bought the car for fuel economy, you bought the wrong car. :P
RM_2 is offline   Reply With Quote
Old 08-28-2012, 09:03 PM   #14
DontCare
Member#: 327422
2012 Subaru WRX
Plasma Blue Pearl
I have a 12' WRX with a stage 1 map from Torqued performance. But even before that I had a combined average of 24 including a few miles of 75+ on the freeway and a few quick starts from stoplights. On longer road trips i can manage 27 without trying. I usually shift between 2-3k and accelerate smoothly. I also keep my tires at max air pressure and cruise at 35-40 in 5th as long as it doesnt chug. Oh and i coast in neutral when coming to a stop like down an off ramp and down hills.
DontCare is offline   Reply With Quote
Old 08-28-2012, 10:00 PM   #15
rob1n1
Member#: 276425
2013 335is
Alpine White
The motor is spinning itself, essentially. It kicks in when you're about to stall though so that you can put the clutch in come to a stop.
rob1n1 is offline   Reply With Quote
Old 08-28-2012, 10:27 PM   #16
coldmm803
Member#: 229343
12 WRX SWP sedan
09 LGT RIP
I'm under the impression that neutral uses more fuel than coasting in gear. Should be able to see using an AccessPort watching the injector duty cycle.
coldmm803 is offline   Reply With Quote
Old 08-29-2012, 01:18 AM   #17
MaddMax
Member#: 9264
2016 BMW M235i 6MT
Correct, if you're trying to conserve fuel coming down a ramp or a big hill, leave it in gear. The injectors are not firing under engine braking. The sound you're hearing from the motor and muffler is merely air being pumped in and out. Not until around 1,200rpms will the ECU start firing the injectors again to keep the motor from stalling.
MaddMax is offline   Reply With Quote
Old 08-29-2012, 01:34 AM   #18
DontCare
Member#: 327422
2012 Subaru WRX
Plasma Blue Pearl
That might sound good in theory and would mean that if you downshifted as much as possible to utilize engine braking you would get even better mileage but Im pretty sure it doesnt work that well. I tried doing that for a few tanks of fuels and if i remember right i lost an mpg or two.
Old 08-29-2012, 12:35 PM   #19
stikilla
Member#: 117796
2006 Corvette
white
it works....its simply how the engine works. while coasting in gear there is no fuel consumption plain and simple. This can only lead to gas savings.
stikilla is offline   Reply With Quote
Old 08-29-2012, 12:45 PM   #20
wobbletop
Member#: 11652
'11 STI 5dr Red
'70 Porsche 914/6
Sure, but that also means you're braking, not coasting. I don't know the answer but coasting in neutral with the engine idling (using very little gas), may be better than using no gas but slowing down quicker due to engine braking, and thus having to accelerate sooner afterwards.
Maybe someone has done the math.
wobbletop is offline   Reply With Quote
Old 08-29-2012, 12:54 PM   #21
Drcujo
Member#: 307193
2009 WRX
For fuel economy, you should try to avoid being aggressive in the throttle and using the higher rpms. Engine braking is less waste then using the actual brakes.
Drcujo is offline   Reply With Quote
Old 08-29-2012, 12:57 PM   #22
briguy84
Member#: 311448
2012 WRX 5 Door
World Rally Blue
my theory is to coast in gear if possible but if i'm going down a steep hill and there is a long flat part i can't make it through the flat while coasting in gear because of the engine braking which means i have to put my car in neutral and coast my way down to reach the end of the flat part of the road.
briguy84 is offline   Reply With Quote
Old 08-29-2012, 01:04 PM   #23
lastsnare
Member#: 169539
2004 WRX sedan JBP
2013 BRZ GBS, 2000 2.5RS
Drive at the speed limit (not over)
Accelerate slowly and in the lowest gears that you can (without engine vibration/lugging)
Always coast as far as you possibly can in gear (in 5th whenever possible)
Don't use the brakes unless you have to (this is just wasting gas that you already burned and turning your kinetic energy into heat)
I got just over 400 miles on a tank a few times on my '04 using these techniques, it can work. It will vary a bit probably due to some differences in tunes over the years, but this should get you the best possible gas mileage.
Coasting in gear seems to consistently show zero injector activity unless you are going slow enough such that your RPM's would fall below your idle RPM level (and stall the engine).
I usually pop it out of gear for a stop sign or stop light at around 500-700 RPM so I don't stall.
It's not a very exciting way to drive (but a good lesson in seeing how far you can coast and not wasting momentum). It can work though.
lastsnare is offline   Reply With Quote
Old 08-29-2012, 02:12 PM   #24
WRXJunky
Member#: 296602
2012 WRX Limited
Satin White Pearl
If you bought this car for gas mileage that was the wrong reason to buy it; trade it in for a base impreza.
WRXJunky is offline   Reply With Quote
Old 08-29-2012, 06:42 PM   #25
ksrumbel
Member#: 328177
Please show me where someone said they bought their WRX for fuel economy. People are just sharing how well the car can do.
Audi to Position Q5 Diesel for Performance, Hybrid for Fuel Economy AVANTI R5 Non-Subaru News & Rumors 0 01-27-2012 04:17 PM
Best vehicles for fuel economy and acceleration AVANTI R5 Non-Subaru News & Rumors 3 08-03-2010 07:53 PM
Differences in advanced driving techniques for AWD? Netzapper Newbies & FAQs 11 01-30-2007 08:41 PM
Off the shelf Stage 2 better than stock for fuel economy. wrxpeed Engine Management & Tuning 2 09-14-2005 02:55 AM
Looking for fuel economy help Radio Flyer Normally Aspirated Powertrain 7 10-05-2003 02:25 AM
