Mid Atlantic Impreza Club
Closed Thread
Old 08-29-2012, 12:11 PM   #2601
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
I'm always on the look out for a good deal,
I literally don't buy anything until I have researched it for a few days trying to find the best price.
EvileyeZ88 is offline
Old 08-29-2012, 12:56 PM   #2602
gaedikus
Member#: 310254
04 Forester XT
^same. i PM'd you about a set i found.
gaedikus is offline
Old 08-29-2012, 03:15 PM   #2603
Turbo18psi
Member#: 245835
07 Sti Limited UGM
05 IS300 Graphite Gray
I love mine for sure. I deff recommend them. In fact I actually have an extra BNIB SPT H brace that's for sale. Let me know if you're interested.
Turbo18psi is offline
Old 08-30-2012, 11:44 AM   #2604
gaedikus
Member#: 310254
04 Forester XT
i fixed my headlight housing issue, SB'd the engine bay, helped EvilEye with his TBE for much insanity.
gaedikus is offline
Old 08-30-2012, 05:32 PM   #2605
lilblue619
Member#: 288292
2004 sti
wrb. the blue one.
Went to change my rear diff fluid today and found out that it looks really good so I'm going to hold off for a few more thousand miles. How often do you change yours?
lilblue619 is offline
Old 08-30-2012, 06:46 PM   #2606
Turbo18psi
Member#: 245835
07 Sti Limited UGM
Every 30,000 miles, sometimes earlier.
Old 08-30-2012, 08:15 PM   #2607
Luis07STi
Member#: 271545
2011 DGM STi
RIP WRB 07 STi 44MM EWG
Installed my TWM short shifter. Sooo much back!
Luis07STi is offline
Old 08-30-2012, 08:19 PM   #2608
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
did a bunch of stuff past couple of months and finally took pics.
reflecta-gold around tmic
front grills
and jdm GC8 Sti 4 pots front and matching rear 2 pots
mhoerath is offline
Old 08-30-2012, 09:52 PM   #2609
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Realized that with all this rain and all the puddles I've gone through that my passanger side headlight has a leak causing it to fog up. Time to bake it and re-seal.
HinshawWRX is offline
Old 08-31-2012, 06:33 AM   #2610
WRX WARRIOR
Member#: 267633
It's A Zombie, Bro.
So low my rotors scrape..
Pulled radiator out.
Took out the cc module.
Gettin set up for all new hoses.
WRX WARRIOR is offline
Old 08-31-2012, 08:15 AM   #2611
gaedikus
Member#: 310254
04 Forester XT
i have DEI reflecting tape, and was thinking about doing this. do you have any recorded difference in before/after temperature of the TMIC?
also, guys, what is the part number for the female clips on an 04 STI grille? the part where the physical grill plugs into the body.
gaedikus is offline
Old 08-31-2012, 12:09 PM   #2612
WRX WARRIOR
Member#: 267633
It's A Zombie, Bro.
It clips directly into the upper radiator bracket thing.
Old 08-31-2012, 01:32 PM   #2613
sjs0433
Member#: 86061
I drove it to work. Hope to clean it this weekend.
sjs0433 is offline
Old 08-31-2012, 02:00 PM   #2614
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
My rear right caliper seized while engaged on a drive home from DC. The piston boot had a puncture and the inside became rusted and it was just a matter of time. I hobbled to an advanced auto parts and changed my caliper core on the side of the street!
Smurftastic is offline
Old 08-31-2012, 02:12 PM   #2615
gaedikus
Member#: 310254
04 Forester XT
you've earned it. *applause*
gaedikus is offline
Old 08-31-2012, 02:36 PM   #2616
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
I have the DEI silver reflective tape stuff. It made my intercooler even cooler to the touch after hard driving. No before or after with any measuring device though.
Old 08-31-2012, 03:03 PM   #2617
mhoerath
Member#: 131379
justablue hatch
butt dyno says no difference and didn't do a before after real dyno. Also put the tape on inside of turbo shield. I bet downpipe wrap and turbo blanket would do more to keep heat out of the engine bay.
ps also did air splitter pipes underneath intercooler.
mhoerath is offline
Old 08-31-2012, 04:31 PM   #2618
Smurftastic
Member#: 243697
02 | BLOD Founding
Damn that is dirty! Glad you removed the CC module, amazing how much space it frees up!
Why thank you, I felt good
Old 08-31-2012, 04:40 PM   #2619
WRX WARRIOR
Member#: 267633
It's A Zombie, Bro.
It is dirty.
I have a whole bunch of oem perlacenbt parts I'm getting ready to put on. New pulleys belts fluids hoses and what not.
Old 09-01-2012, 12:01 AM   #2620
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Installed the brakes from a 2nd gen CTS-V on my 1st gen. I chose to go with the pimpy yellow calipers from the Black Diamond edition. To start out with, I'm using OEM V2 rotors that I redrilled (somewhat ugly) and also had the center bore opened out by a machine shop. (Off the top of my head I don't recall the numbers, but the V2 center bore is a couple millimeters smaller than the V1.) The OEM rotors are non-serviceable 2-piece rotors (at least, that's what I would call them, since they're made of two different materials but you can't disassemble them.) I think I've seen that the newer Audis have something similar? Anyway, drilling a new bolt pattern was pretty easy with just a normal electric drill, since the center section is aluminum, but I didn't have the capability to enlarge the center hole.
In the near future I'll be buying a pair of V2 rotor rings from Racing Brake to put on the RB hats that I've already got, but that can wait for now.
A comparison of the calipers:
(Gold STI calipers turn brown, while silver CTS-V calipers turn gold. Weird.)
And the pads:
Caliper installed (and you can sorta see the 2-piece design of the rotors):
And with a 19" wheel installed:
(A couple of other folks have already verified that the 18" Team Dynamics wheels that I use on track will clear the bigger rotors/calipers.)
I need to wash the car so I can get a good profile shot to show off the yellow calipers on the Stealth Grey car.
No real change in feel with just street pads installed, which is as I expected - the brake torque math works out to ~2.5% shift in bias towards the front. I'm definitely looking forward to seeing how they do on track. With the much bigger pads (~50% larger) and beefier rotors (355x30mm vs 370x34mm) I think they should hold up better to my apparently abusive braking style.
Patrick Olsen is offline
Old 09-01-2012, 08:54 AM   #2621
theo79
Member#: 159621
2002 WRX - WRB
JDM v7 Spec C drivetrain
Yesterday I installed a group n tranny mount, whiteline steering rack bushings, kartboy rear shifter bushing, and rattlecanned my side view mirrors satin black.
theo79 is offline
Old 09-01-2012, 09:39 AM   #2622
pfinch117
Member#: 198849
2015 WRX Limited
CWP
Finally did the koji mod on my headlights, turned out pretty good. could have done a little better...
Before
After
pfinch117 is online now
Old 09-01-2012, 11:49 AM   #2623
EvileyeZ88
Member#: 233501
99 outback sport
Been working on headers, 44mm EWG, and txs turbo back.
This thing's kicking my ass. Any helping hands around today.
I have beer....annnnnnnd candy
~Evil
Old 09-01-2012, 12:55 PM   #2624
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
RHD and it makes me smile
Finally able to wash it and shine her black parts up. She is looking much better now.
I also put some copper gasket around the smaller leaks on the downpipe, hopefully that will make her a little more quiet.
Going to get some ss screws at home depot and put on a lip within the next hour or so.
ImNOrobo is offline
Old 09-01-2012, 02:15 PM   #2625
WRX WARRIOR
Member#: 267633
It's A Zombie, Bro.
~Evil
Location?
Closed Thread
What did you do to your car today? Jester808 Texas Impreza Club Forum -- TXIC 3235 08-05-2013 12:55 AM
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 03:08 AM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 12:02 PM
