Mid Atlantic Impreza Club
Closed Thread
Old 09-06-2012, 12:14 PM   #2726
Atheismo
Member#: 330983
2011 wrx sti hatch
pbp
Originally Posted by sjs0433
Only 123k and it's a Volvo. I'm hoping to get at least another 2-3 years/50k miles out of it before I retire it.
I used to have a 1983 Volvo. When I traded it in iirc it had 183,000 on it and was still going strong. I was waiting for it to die but it refused to. Still got 1800 for it. If you're taking good care of yours, and it sounds as though you are, it may keep going for a while to come.
Atheismo is offline
Old 09-06-2012, 01:37 PM   #2727
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Parked it in the garage. My list of things to do while the wife and kid are home in Illinois include:
-Pop open passenger side headlight, clean and re-seal.
-Wrap Turbo
-Clean engine bay
-Replace open end lugs with closed end
-Random crap I'll probly find to do
HinshawWRX is offline
Old 09-06-2012, 02:09 PM   #2728
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
Removed the air/oil separator from the vacuum lines hoping that it will help solve the lean running issue I'm getting. It is only at idle, which leads me to believe it is just a vacuum leak somewhere. We'll see what driving the car to softball tonight does.
Stupid thing wasn't doing my any good, anyway. If the intake ever starts to get coated with oil, I'll probably pick up a grimmspeed style of air/oil separator to solve that issue.
AJ711 is offline
Old 09-06-2012, 03:00 PM   #2729
WRX11
Member#: 26638
AJ, before you buy the Grimspeed AOS, talk to Mav1c first.
I had made a similar unit to Prova's and had bad results. I still have my test unit if you want to see it.
WRX11 is online now
Old 09-06-2012, 05:06 PM   #2730
Matt_H
Member#: 107000
2015 BMW X1
Sprayed my manifold, wanting to get some parts on the car while the wife is away and I have a second car.
Matt_H is offline
Old 09-06-2012, 05:07 PM   #2731
96accord
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
Racecar
96accord is offline
Old 09-06-2012, 05:17 PM   #2732
Matt_H
Member#: 107000
2015 BMW X1
I'll probably end up not putting anything on the car either.
Long list of parts that need to go on, all of which require codes being turned off.
Matt_H is offline
Old 09-06-2012, 05:31 PM   #2733
WRX WARRIOR
Member#: 267633
It's A Zombie, Bro.
So low my rotors scrape..
Why did you paint it? Kill the heat?
WRX WARRIOR is offline
Old 09-06-2012, 05:36 PM   #2734
Matt_H
Member#: 107000
2015 BMW X1
Protecting it from the elements and it was a little weathered already.
Matt_H is offline
Old 09-06-2012, 05:38 PM   #2735
sjs0433
Member#: 86061
What manifold is that?
sjs0433 is offline
Old 09-06-2012, 05:40 PM   #2736
Matt_H
Member#: 107000
2015 BMW X1
GT-Spec EL
Matt_H is offline
Old 09-06-2012, 09:05 PM   #2737
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Drove it from the DC area to Norfolk to check into the new job. Hit some nasty rain along the way - even with nearly new good summer tires I had to slow to below the speed limit for a stretch and could still feel the car skating around a bit. Saw 3 cars that had hydroplaned off - 1 on 95S and 2 on 295.
Patrick Olsen is offline
Old 09-06-2012, 09:19 PM   #2738
WRX WARRIOR
Member#: 267633
It's A Zombie, Bro.
Have you been to Norfolk before?
Old 09-06-2012, 09:53 PM   #2739
infinite012
Member#: 74392
2015 Forester
Polished my Greddy SE muffler. Maybe I'll get around to polishing the rest of the pipes later, but so far I'm very pleased with the Mother's Mag and Aluminum Polish.
Started to polish the muffler:
You can see where I did and didn't polish:
Half way done with cleaning (used Armor All Extreme Wheel & Tire Cleaner with 0000 steel wool):
All done (I couldn't get that connecting flange/pipe cleaned for the life of me)!
infinite012 is offline
Old 09-06-2012, 10:45 PM   #2740
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Lived here as a teenager, but that's been a couple years ago.
Looks damn good!
Old 09-07-2012, 07:16 AM   #2741
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
finished lca bushing replacement...all 4. car is tight once again.
whiteline's on the front and perrin's in the back. perrin has a stainless crush tube - and a grease port, nice bit. also came with hard and softer bushings - split so easy to swap. my replaced whiteline's had a steel tube that was very corroded on one side.
should have read perrin vs whiteline thread before i bought the whiteline - 6 yrs ago.
mhoerath is offline
Old 09-07-2012, 07:54 AM   #2742
WRX WARRIOR
Member#: 267633
It's A Zombie, Bro.
Welcome back. Hasn't gotten any better.
Old 09-07-2012, 08:51 AM   #2743
sjs0433
Member#: 86061
How bad is the bushing swap? Alignment all jacked up now? I'll slowly over time replace key bushings that I know will tighten the car up. At least you're in Richmond so you come over and do the work while I sit and point....I mean Help me do the work
On a different note I should be swapping for a wingless trunk later today. I'm hoping the color match is close enough. It's a wingless trunk off a 02 WRX with around 100k miles vs my 04 with only 17k miles and always garage kept.
sjs0433 is offline
Old 09-07-2012, 01:49 PM   #2744
dustincredible
Member#: 225766
2006 LGT
Spec B
The other day I went to court for a wreckless driving ticket. I left without paying a dime! Case was dismissed!
dustincredible is offline
Old 09-07-2012, 02:19 PM   #2745
gaedikus
Member#: 310254
04 Forester XT
^lucky.
i got pulled over last night in front of my apartment (i was so close) by two female cops in manassas for "aftermarket exhaust". fun fact: 2/3 of my exhaust is OEM (only the axleback is not, its either turboxs or cobb). they ended up bs-ing with me and gave a verbal warning.
also they gave me the right to remain sexy ;D
gaedikus is offline
Old 09-07-2012, 02:29 PM   #2746
mhoerath
Member#: 131379
justablue hatch
ha. you should have done mine so you know what to do on yours.
i've pretty much done them all. Some like subframe/diff bushings easy others take time. Especially with my lowcost bushing press.
Be gald to lend a hand jes lmk.
mhoerath is offline
Old 09-07-2012, 02:52 PM   #2747
sjs0433
Member#: 86061
I've never done any of the control arm/lateral link/trailing arm stuff but just about everything else I've touched between the first two Subarus I owned (04 wrx & 06 sti)
sjs0433 is offline
Old 09-07-2012, 10:42 PM   #2748
Cheese13
Member#: 272366
2003 Evo 8 gsr
Bby
Sold it
Cheese13 is offline
Old 09-07-2012, 10:44 PM   #2749
sjs0433
Member#: 86061
Just got done swapping trunks. Sti is wingless now. Just need to finish detailing it and order some new sti badges.
I also removed my windshield washer reservoir. Car isn't a daily and won't ever be driven in conditions in which I think I'll need it. Looks cleaner under the good too
sjs0433 is offline
Old 09-08-2012, 12:08 AM   #2750
jonathoner
Member#: 303763
'00 RS stg2 ej205
Sedona Red Pearl
Replaced a leaking/moderate play left rear axle and aligned it. Again. Glad napa has lifetime warranty axles haha
jonathoner is offline
Closed Thread
What did you do to your car today? Jester808 Texas Impreza Club Forum -- TXIC 3235 08-05-2013 01:55 AM
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 04:08 AM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 01:02 PM
