Mid Atlantic Impreza Club
Closed Thread
Old 09-26-2012, 11:13 PM   #2926
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
RHD and it makes me smile
Thanks. Nope, not aluminum. You will have to wait and see.
ImNOrobo is offline
Old 09-27-2012, 01:31 AM   #2927
God&Sme
Member#: 256567
2002 PSM WRX - SOLD
97 GSXR = FAST
Originally Posted by mhoerath
jes led's in dome/backup/map lights. hids are brighter but to me a bit expensive and complicated, and extra weight.
Nah, I meant hid headlights? I feel like license plate leds w/reverse leds would look odd with standard headlights...
God&Sme is offline
Old 09-27-2012, 04:35 PM   #2928
Horner
Member#: 324477
2002 2.0 vf43+ meth
6mt wrb sedan
i hate waiting.......... cant wait to see it done
Horner is offline
Old 09-27-2012, 06:24 PM   #2929
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
Me too. I got the material today, I ended up with a lot more than I needed for the same price I was quoted. Got a few extra feet for free. I was thinking I needed this done by Saturday for the pence meet but that is next Saturday.
I am still hoping to have it done by Sunday, which shouldn't be a problem now. Going to try and make the first rough cuts tonight and possibly do a dry install.
ImNOrobo is offline
Old 09-27-2012, 09:01 PM   #2930
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
Here is the start. It is a rough cut for sure. I put it up test fit and make sure I was headed in the right direction and so far so good. I will continue tomorrow.
ImNOrobo is offline
Old 09-27-2012, 09:12 PM   #2931
Cheese13
Member#: 272366
2003 Evo 8 gsr
Bby
If this turns out well i want to buy one!
Cheese13 is offline
Old 09-27-2012, 09:17 PM   #2932
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
You know, I figured at least one person would say that. I might have enough material for a second one.
ImNOrobo is offline
Old 09-27-2012, 09:42 PM   #2933
butterflyx3
Member#: 293345
2003 WRX
Took the scoob to the body shop to get painted. ^_^
butterflyx3 is offline
Old 09-27-2012, 09:45 PM   #2934
96accord
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
What body shop? And WRB now instead of Silver right?
96accord is offline
Old 09-27-2012, 09:53 PM   #2935
Horner
Member#: 324477
2002 2.0 vf43+ meth
6mt wrb sedan
I'd settle for just the dimensions of it to use as a reference when I build mine
Horner is offline
Old 09-27-2012, 10:22 PM   #2936
DKDunn04
Member#: 275640
1968 Corvette-Yellow
2004 STI-Silver
Adjusted the floats on the carb on the Vette, and now its running great! Just have to adjust the throttle cable, replace the odd-ball sized rear tire, finish the wiring for the dash and engine bay, and fix the vacuum headlight system and it will be ready for the road!
DKDunn04 is offline
Old 09-27-2012, 11:14 PM   #2937
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
I'm sure I can post up the dimensions. Everything is measured out not just eyeballed. Only after it is done though.
ImNOrobo is offline
Old 09-27-2012, 11:21 PM   #2938
butterflyx3
Member#: 293345
2003 WRX
Baltimore body shop, friends family owns it so its already got started. And you'll have to see soon
Old 09-28-2012, 05:56 PM   #2939
jozeppi
Member#: 247473
2007 wrx
wrb
jozeppi is offline
Old 09-28-2012, 08:31 PM   #2940
DKDunn04
Member#: 275640
2004 STI-Silver
^^ Looks much better.
Adjusted the idle on the vette and started diagnosing the vacuum operated headlight system. What a pain in the butt.
DKDunn04 is offline
Old 09-29-2012, 03:58 PM   #2941
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
I got all the fins cut today. I threw it up to see how everything looks before I continue. I need to make a few bends and cut the ends on the back. I have watch tonight so I won't be able to finish tonight. I should def be able to finish tomorrow though. I'm pretty happy so far.
****ty pics since my phone was about to die.
ImNOrobo is offline
Old 09-29-2012, 04:03 PM   #2942
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
Looking good man
I rolled over 74,000 today, my baby is starting to get old :-/
EvileyeZ88 is offline
Old 09-29-2012, 04:39 PM   #2943
SneakySh0rty
Member#: 280516
03 WRX v9 trans
Finally got the corroded bolts out my kartboy front endlinks! Top bolts weren't too bad but the ones connected to the control arms were a PITA. Finally broke loose after some kroil oil and a swivel socket for the impact wrench.
SneakySh0rty is offline
Old 09-29-2012, 04:39 PM   #2944
STiWanabe
Member#: 41447
---- _________
swapped out the borla hush for an invidia N1. Never had a loud exhaust before. Me likey
STiWanabe is offline
Old 09-29-2012, 04:41 PM   #2945
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
replaced 3 braided and one oem brake line with 4 goodrich braided brake lines. beld the brakes.
weeks ago i replaced my calipers and did not properly dress one of the brake lines. found that out after changing into my 15" compomotive rally rims and during my 1st run...no brakes.
managed a good run but hit lots of cones bleeding speed by going sideways.
found out the different diameter of the rim rubbed through the brake line.
mhoerath is offline
Old 09-30-2012, 09:22 PM   #2946
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Took the intake scoop off and used my free thermal tape to block the heat from the bottom. Also added a bit around the oil pan where the header is. And added my plastic skid plate back to the car for if we goto the Pence meet. Also sprayed some self etching primer and black protective paint on the rusty bits in the rear.
HinshawWRX is offline
Old 09-30-2012, 10:12 PM   #2947
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
Got a late start today but I almost finished my diffuser. It should be finished tomorrow after work. This is the last mock up before mounting the fins and screwing in the diffuser.
Pics are a little dark but it is looking pretty good now.
ImNOrobo is offline
Old 09-30-2012, 10:39 PM   #2948
Cheese13
Member#: 272366
2003 Evo 8 gsr
Bby
I still want the next one!!!!
Cheese13 is offline
Old 09-30-2012, 11:08 PM   #2949
ImNOrobo
Member#: 255716
Itsa bugeye 04, V9
You pay, I make. We will talk.
ImNOrobo is offline
Old 10-01-2012, 06:08 AM   #2950
noelicious
Member#: 185468
2006 STi Stage 2
White Buffalo
^^^oooOo I wanna see this project...
noelicious is offline
Closed Thread
What did you do to your car today? Jester808 Texas Impreza Club Forum -- TXIC 3235 08-05-2013 12:55 AM
what did you do to your car today? Schrecken Bay Area Impreza Club Forum -- BAIC 11 09-25-2012 03:08 AM
What did you do to your Scoob today? Sheehan North West Impreza Club Forum -- NWIC 27 11-23-2007 12:02 PM
